loading
Step 2: Measure & trim
The first thing you'll need to do is trim down your elastic to about a 4.5" length.
Very cool, I used an even more low budget approach. I stacked the cards I carry daily to include driver and work ID's. I put a business card on top and bottom of the stack, I then single wrapped (you can wrap 2X for more durability) with Gorilla tape, you'll need to do an upper and lower wrap if wrapping width-wise. This allows me to access/stash cards from top and bottom or side to side depending on how you carry.
You can also use duct tape but I prefer the black of Gorilla tape.
Cool! Nice practical design :)
Thanks! It had been too long since my last able.
Agreed :) You should enter this into the <a href="https://www.instructables.com/contest/holidaygifts2012">Holiday Gifts Contest</a>!
Where do I get this Industrial Elastic?
http://www.youtube.com/watch?v=rh0UvrR8UM4
U are worthy of the Nobel Prize for simplicity and usefulness!
You are too kind haha. Looks like I'm not the only person who arrived at this design though, as whatcansixdoforyou pointed out below.
You can give yourself extra fray-prevention backup by applying a substance known as &quot;Fray Check&quot;. Basically, it's a fabric glue which, well, stops fabric from fraying.
Only thing is, I don't think Fray Chek stretches very well. It might crack and peel off the elastic. It's great for non-stretchy cloth, though.
Good point. :]
This does remind me of the &quot;TGT wallets&quot; (http://www.kickstarter.com/projects/jacksutter/tgt-tight-a-new-kind-of-wallet) that have just come out. Two people who have the same problem arrive to the same conclusion. Great instructable though.
I just saw it had been mentioned further down. sorry
It's funny, the reason I arrived at this form factor was because it allowed unique accessibility to every card simply by spreading them within the band. I checked out the TGT wallets yesterday for the first time and at no point is this feature advertised. I think they are missing a big feature of this design! For me it was about making a wallet that functioned as well in hand as it did in a pocket.
Nice! Useful, good looking, simple to make. Perfect! Thanks!
Nice instructable! Huge market for these based on the 317k raised in 30 days on Kickstarter... a little clever marketing goes a long way ;) <br>Here is the link &gt; http://www.kickstarter.com/projects/jacksutter/tgt-tight-a-new-kind-of-wallet?ref=users
Whoa! Didn't even know about that one! Thanks for sharing.
Handsome, but how is this functionally better than the rubber band I use?
Elastic is rubber covered by polyester. They both stretch but elastic is soft. This makes for a friendlier pocket material that won't snag against fabric, and allows cards to be inserted under the band much easier. This wide elastic is also more comfortable in the hand and far more durable than a rubber band. But if that's not enough added functionality, it is also handsome, as you mentioned. :]
Do you find that it works better with the edges end-to-end instead of overlapping (or have you tried it with the ends overlapping yet)? The issue of &quot;how do you sew that with a machine&quot; aside, I wonder if there'd be fewer opportunities for things to catch on the seam if it were flat-sewn.
I did sketch a few different construction methods, including an end-over-end version just to see the difference. The end-to-end method was the best choice in my opinion. It helps prevent fraying and results in a much cleaner, machined seam. The elastic really has a very tight grip; I haven't had any trouble with it catching on anything :).
that answers my question, thanks!
Quick, simple, and good instructions.
Thanks Crabby!
Ohhhhh I like this one - much better for cash. :D
Thanks! It's funny I just made mine yesterday and found out that you had made your version just a few days earlier. It was cool to see we arrived at similar techniques for construction.
So where does one get &quot;industrial&quot; elastic?
I found mine at the local fabric store. You can also fine it online at amazon here http://www.amazon.com/Stretchrite-2-Inch-10-Yard-Stretch-Elastic/dp/B0018N5MS8/ref=sr_1_1?ie=UTF8&amp;qid=1354846409&amp;sr=8-1&amp;keywords=2+inch+elastic. The advantage of going to the store is that you can get it cut off the spool.
About This Instructable
37,884views
226favorites
License:
More by timwikander:What it's like to be an Artist in Residence at Instructables How to 3D Print Molds for Small Batch Concrete Casting Corkedo
Add instructable to:
