Step 3: Your first project.
Note: for the board you want to use the arduino uno with the arduino board. With the Osepp, you want to use the with atmel328
Here is the code in case you do not have the examples.
Blink.pde:
[code]
* Blink
* The basic Arduino example. Turns on an LED on for one second,
* then off for one second, and so on... We use pin 13 because,
* depending on your Arduino board, it has either a built-in LED
* or a built-in resistor so that you need only an LED.
* http://www.arduino.cc/en/Tutorial/Blink
int ledPin = 13; // LED connected to digital pin 13
void setup() // run once, when the sketch starts
pinMode(ledPin, OUTPUT); // sets the digital pin as output
void loop() // run over and over again
digitalWrite(ledPin, HIGH); // sets the LED on
delay(1000); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
[/code]So run the IDE program
Choose your board.
Choose the port to use.
You should not have to do this again unless your hardware changes.
Load Blink.pde
Compile it.
Upload it to the board.
Watch the light blink.
Not spectacular, but it is an awesome start!
On to bigger and better things.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
