While the lack of light never stopped us from riding, the glory of having a MEAN bike light was calling me out.
The main problem I found with all the bike lights out there to build was the battery and housing.
- Recharge battery packs cost some money and having another charger in the house was something I didn't want.
- Housing is always an issue with DIY projects. I think 95% of my dads circuit boards lived in little blue hobby boxes. Sure they worked but didn't look so hot. I didn't want my new bike light sitting in a big ball of black tape.
http://www.instructables.com/id/E3BGQT6Y7PEP286N6P
This gave me a pretty good looking and durable housing but what about the batteries? The answer was already sitting in my charger!
1 18v Ryobi Battery Pack
http://www.oneplustools.com/
http://www.ryobitools.com/index.php
I had already bitten off on the 18v series. My collection consists of the drill, saw, dust-buster, chainsaw (yup) and light.
This light is the one that we'll be using to create our 18v monster.
QUESTION - Why not just use the light that came with it? My friend tried this and it turns out that while the 18v light does give off OK lighting (and lasts awhile) it doesn't even come close to what we are building here. When you're doing you'll see what I mean.
WARNING - please please be aware that the bulb we are using here is a 12v NOT an 18v which means we are pushing (beyond) the limits of this bulb. This is a risk from a heat+safety standpoint. You can reduce the volts using various methods (one that I'm exploring right now) but in this project we push the 18v straight to the bulb.
Remove these ads by
Signing UpStep 1Shopping List
HomeDepot Purchases:
- PVC Trap adapter 1 1/2 x 1 1/4
- Female Cap VPVC Sch 40 1 1/4 (threaded)
- No Hub Coupling 1 1/2" to 1 1/2"
- Switch - 3A+ SPST (Single Pole Single Throw)
- 12v 20w Halogen Light
- Conduit Hanger 1/2 inch to 1 inch (size depends on the thickness of your handlebars)
- Ballcock Shank Rubber Washer (used as a cushion between the light and hanger)
- MR16 Socket (bulb {2} pins plug in to) - (some HomeDepots have this; mine did not so look below for links or google it)
- Ryobi 18v Light, Battery and Charger
- Water Bottle (plastic)
- Black Tape
- Soldering Iron
- Wire - min of 16 guage (3amp+).
- I used a chopped up extension cord for my wiring. It can handle the amps, has 3 wires (we only need 2) and has a protective sheathing around it (this protects my wires during my many falls)
- The socket that I bought online came with no wires but had some quick/push-in sockets. The pictures I show are off of EBAY and show the ones that have the wires. Either will work.
- You can def use a smaller pipe clamp around the light and hanger. The one I show turned out to be HUGE.
- If you do get a larger hanger for your handlebars, you might have to insert some foam (like we did) or rubber to get it to be tight around the handlebars.
superbrightleds.com
MR16/MR11 Socket - GX5.3/G40 Universal Ceramic 2-Pin base GX5.3 or GU5.3 / G40 oval pin slots fits all of our MR16 and MR11 bulbs Your power wires plug and lock into holes in the bottom of the socket - $ 1.95
Info about Wire and Sizing:
Wire Gauge Tables
got to luv harbor fright!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93440
I am still building the light but will step down my volts a bit to get some more run-time. Looking at this battery as posted in the VeggieCycle thread.
battery
This screwdriver USED TO use the Versapack battery...
http://i18.photobucket.com/albums/b103/klee27x/dsa.jpg
Now it runs on 3.6V x 4,400 mAh li ion battery.
