Step 11Build up the led & lens assembly
- drill a hole next to the led to route the wires through, use 18-22 gauge durable flexible wires 6-8 inches long. these wires will flex every time you change the battery.
- solder flexible stranded wires to the led, then check that the lens mount still fits properly on the led, if your solder blobs are too large the mount will not sit flat
- route cable through the hole, then simultaneously glue down the wires and glue on the lens mount (without lens inserted)
- probably want to leave the lens out of the mount until you are all done.
Add Comment
![Voltage Regulated [5v] Bicycle Dynamo Light & USB Charger](http://img.instructables.com/files/deriv/FKR/TCHO/GSEEJZIP/FKRTCHOGSEEJZIP.SQUARE.jpg)
