3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Daylight Visible Bike Light - Front/Rear Combo - 100 Lumens on 2 AA's
Step 15Its done!
its done!
now put the batteries in, attach to bike and go make the cars feel your presence!
4 comments
Mar 27, 2010. 10:00 PMtltaylorsw says:
Nice light, I am a bike paramedic and would like to use a PIC (16F628A) in place of the 555 to provide 2 alternating flashing lights. would the same moset placement work for me?
Thanks in advance
Jul 27, 2008. 8:27 AMGopher says:
Can I use the same components and run the circuit on 4AA 2700mha Rechargeable and thus have more power from the 3W luxeons? IE will the extra power available simply make the LED brighter with no ill effect on components, obviously the led will need heat sink but what about the FET? or should it be heatsinked anyway for safety Basically I just want a single 3W led to blink at as high a brightness as possible from 4AA batteries
May 14, 2008. 5:02 AMcivilpd says:
I think I am going to build your light. What are the possibilities of using one the radio sh*ck 7.2v or 9.6v NiCad rechargeables? Would it overheat the LEDs or have other negative results?
Apr 25, 2008. 7:27 PMshortman says:
This is good and you could also use a bike light generator th keep batteries charged as you drive. You would only need voltage reducer from 6 volts to 3.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
525
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
