3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate DeskSquid / Helping Hand
Step 3Alligator Clip Arms
Alligator Clip Arms
This step is largely determined by your materials, I had two USB LED lights that were identical that I got as promotional schwag, which worked out great for this project. I decided to go with gooseneck for a couple reasons:
1) it's cheaper
2) it's more flexible (this is a tradeoff on strength, but since I mostly use it to hold wires or components it was worthwhile)
So, for my DeskSquid all I did was take out the LED and mount a 1" 6/32 screw upside down in the hole with some epoxy, and I used a nut to help me get it center and make it look cleaner. You only need about 1/4" of exposed thread for the alligator clip or other accessory. Get creative with what you've got, some wire, more coolant hose, etc.
To attach these to my main arm I used my #7 bit again to drill holes in the double female connector, the gooseneck actually threads in after cutting off the USB connector, and then I used a small nylon spacer and more epoxy to hold everything in place. This is a little chinsy but it's not a high stress joint so it seems to work fine. I thought about cutting down the length of the arms but it's easy enough to move them, I think you could probably get by with 6" or so of flexible material.
*If you look at the mini-squid you'll notice it too has an alligator clip, I found that a 6/32 screw will actually thread through a 1/8" nozzle, so if you find the right length screw all that remains is to thread on the alligator clip.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:BioZone
