3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate DeskSquid / Helping Hand
Step 4LED Light
LED Light
What good is all this without some direct illumination?? Fortunately I had one last USB LED light. To mount it I stripped off the USB connection, careful to preserve the wires, and then drilled a #7 hole again in the surface mount where I bolted on the Panavise. If you get the angle right you can thread the gooseneck right into the 3/4" hose, and then simply run wires through the main arm to a battery (I have yet to wire this but it should be easy).
With a little creativity you might be able to install a switch near the base and have the batteries inside the main arm.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:BioZone
