Introduction: Hanging Drill Bit Organizer (Made From Styrofoam!)
Picture of Hanging Drill Bit Organizer (Made From Styrofoam!)
Almost all of us have this problem: Organizing our drill-bits...
In the last couple months, I found that I've been using my drill almost everyday to drill holes. I have a container that holds different sized drill bits, But it's always a mess, And I can't stand things that aren't organized! The box takes up space in my room, Which is pretty small. I decided that I need to find a way to get my drill-bits Off my table, Off my shelves, And off my floor!
I've been searching a pretty long time for a good way to store my drill-bits. After a few weeks of thinking and searching on the internet, To my luck, I stumbled across a "Family Handyman" article that shows an absolutely genius way to store them: In a block of styrofoam!
There were no instructions on how to make it, So I thought I would share the process of me making mine with the Instructables Community.
Step 1: What You'll Need:
Picture of What You'll Need:
Materials:
Thick Styrofoam Board Insulation Material (I found it for free, But I don't think it should be expensive)
Spray Paint (I had only black)
Double Sided Tape
Tools:
A Candle or a Torch
Drill Bits (The ones that you're going to mount...)
Caliper (For measuring the size of your drill-bits)
Utility Knife (It has to be extremely sharp)
A long Ruler (30cm / 12")
Black Permanent Marker
Why: Organize Your Drill Bits! No More Mess!
Protection Gear Needed: A ventilated area to work in, Fire Extinguisher, Preferably also a Respirator
Cost (for me): FREE!
Needed Skills: Not being scared of fire...
Approximate Time: 1.5 hours (You probably have more drill bits than me)
Step 2: Sorting the Drill Bits
Picture of Sorting the Drill Bits
I use only Spur-bits (wood), And Twist-bits (metal), I also have one Countersink bit that I want to hang because it looks like something I could use in the future.
This means that I chose to keep: 4, 5, 6, 8, 10mm Spur-bits (Yup, This is all I have)
And 2, 3, 4, 5, 6, 7, 8, 10mm Twist-bits.
All of the other bits have stayed in the box (Such as Masonry concrete bits), Because I don't use them.
Step 3: Heat the Drill Bit & Make a Hole
Picture of Heat the Drill Bit & Make a Hole
I found out that sticking a drill bit into styrofoam doesn't work very well. The thick drill bits can't crush the styrofoam and make a hole. I tried to drill them in, But that only made the styrofoam crumble, So that was a fail too... I decided to try melting the styrofoam and it worked! Another good thing about melting it is that it coats the hole with hardened polystyrene, Which strengthens it a bit.
I chose to use a 2mm drill bit to make all of the holes for the drill bits.
First, I Heated the drill bit for around a minute.
After that, I inserted the drill-bit into the styrofoam at a ~30 degree angle. You should see the styrofoam melt and disappear when it touches the drill bit. Do this slowly and carefully, You don't want to mess up. For bigger drill-bits, I widened the hole a bit more, This is pretty easy to do
WARNING: Do this in a ventilated area, The fumes given off when burning styrofoam probably aren't something you want to be breathing in(Though they do have a nice sweet & sour smell)
Step 4: Whoops, I Made a Mistake! | How to Fix It
Picture of Whoops, I Made a Mistake! | How to Fix It
If you made a mistake (I made only one), This is how you can fix it:
If it's a small mistake, You can fill the hole with PVA "Elmers School Glue", I tried that, But it wasn't good enough for me.
I decided to glue a tiny magnet* to the top of the hole with clear silicone adhesive. This worked well for me because my drill bit can get magnetized.
Now that it is straight, You can move on to the next step...
*I salvaged this magnet out a small speaker, You can salvage magnets from speakers for free too!
Step 5: Cutting the Styrofoam to a Good Size
Picture of Cutting the Styrofoam to a Good Size
First, I marked the size that I wanted it to be with a Sharpie, After that, I used a Utility Knife to cut the styrofoam to the size I wanted. To help cut the styrofoam straight, I used the ruler as a guide, Similar to how a fence works on a table-saw.
The styrofoam I used is pretty stiff, And doesn't make a lot of noise when cut, But softer kinds make an awfully annoying sound. You can put on headphones with music so it won't annoy you. AAARGH!
I'm planning on buying spade bits (If they aren't too expensive) in the future for drilling bigger holes into wood, This isn't a problem because I can always add another piece of styrofoam if I want to add more storage space
Step 6: Painting It Black W/ Spray Paint
Picture of Painting It Black W/ Spray Paint
I found out have we have a really old can of spray paint, And to my luck, It was full. I painted it black because it was the only color of spray paint that I had, But I think green would look better for my room.
WARNING: Not only should you do this in a well ventilated area, But I also tested out this spray paint on a leftover piece, It it looked like the spray-paint dissolved the styrofoam if I put a dark coat. But if I put a light coat, Then it is okay. I guess it still looks better than before with only a light coat
Step 7: Mounting It Onto the Wall (Closet... in My Case)
Picture of Mounting It Onto the Wall (Closet... in My Case)
I put some double sided tape onto the back, And mounted it onto my closet. I think there are adhesives that are meant specifically for styrofoam, But double sided tape sticks strong to styrofoam.
DONE!
Don't forget to Follow me on Instructables & Let me know if you make one, They are really easy to make!
Yonatan24 (author)2016-01-31
UPDATE!!!
The first member that makes a hanging styrofoam drill-bit holder receives a FREE Pro-Membership to Instructables!
It has to look like something that you made for storing your drill-bits, Not for getting the free membership. (I have the right to not give it, If I don't like how it looks)
What you have to do to be able to receive the free membership:
1. Follow me on Instructables
2. Reply to this message with a picture (And any explanations, If you want)
3. Nothing! I will PM you the free code
Come-on, Let's make something!
Yonatan24 (author)2017-02-01
See another interesting styrofoam tool holder: https://www.instructables.com/id/Redneck-Drawer-Too...
deluges (author)2016-02-04
Hey, I like the concept and had a question : why not use a piece of wood instead of styrofoam, and drill the holes at a 45° angle using the individual drill bit every time ? I think it would look better and be sturdier.
Yonatan24 (author)deluges2016-02-04
That was my original plan, But I didn't have any wood so I used styrofoam instead.
I might make a wooden one to replace this one soon, But I'm really busy and I have so many projects right now, So I probably won't make a wooden one anytime soon...
anasdad (author)2016-01-30
Very nice. I just took your concept and simplified it. I have several projects that use different drill bits, and I had them neatly in small boxes. I took a drill bit that was bigger than the biggest in each box, heated it up, and "burned" my way into several didfferent blocks of styrofoam.
Yonatan24 (author)anasdad2016-01-31
Awesome! Did you make something like this?
(A picture from a different "Family Handyman" one?)
Sorry, hit the enter button before I finished my comment. Now they are easy to get to. Great post and thanks for the idea!
About This Instructable
3,612views
23favorites
License:
Bio: 15 year old, sick with a deadly disease called DIY-itis!
More by Yonatan24:60+ Unusual Uses for Workshop Tools & Materials! the Ultimate Collection!Workshop Tips, Tricks, & Hacks to Save You Time & Money!My Top Instructables of 2017 - Yonatan24
Add instructable to:
