3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate Game Console Cooler
This Instructable is for the Ultimate Game Console Cooler.  After having my PS3 and Xbox 360 sent in for repairs (repeatedly), I decided that I had to come up with a better way to keep the heat down in these expensive gaming consoles.
As gaming fans can verify, all consoles create a lot of heat and the add on fans that are available do move more air thru the case.  The problems with fans are that they are NOISY and they do not “cool” the game console at all.
With that in mind, I created this device that keeps my gaming consoles cool AND whisper quiet all of the time. I can now spend several hours of gaming and my consoles will still be under 80 degrees Farenheit!
Yes, this is over the top – but I have a reason. I have 2 Xbox 360’s that are out of warranty and no longer work and my PS3 has also been “repaired” and is no longer under warranty. I purchased a new MW2 branded Xbox 360 and want to keep it and the repaired PS3 in the best possible environment so they will last as long as possible.
Clarification - I did not connect the Nintendo Wii to the AV Switching unit as the Wii does not support Digital Audio.  The switching unit requires all of the attached devices to use the same connectors - so connecting the Wii was out.  I simply ran the RCA cables for the Wii out the vent and directly to the TV.
3/17/2010 Update - cooler runs consistently around 48 to 50 degrees when no game consoles are on, upwards of 80 degrees after several hours of playing XBox 360, 90 degrees watching a Blue Ray movie (2 hours) on the PS3.  Temperature is measured at the inside top of the cooler - it will be colder at the bottom.
Monitoring the moisture closely, no moisture in or on any of the game consoles.  Smal amounts of ice in photos were from the previous 6 months when cooler was running in the garage.  No ice has formed since this was moved into the living room and rice / silica gel was used.
Step 1Materials
Materials
To make an Ultimate Game Console Cooler, you will need:
·         Game Consoles or other electronics that need to be cooled down
·         A wine chiller that has the removal air vent in the back
·         An AV Switching unit to connect all of the electronics to your TV / Receiver with one set of cables
·         A power strip that has enough slots for the number of devices you have
·         A small network hub or switch
·         Miscellaneous cabling (CAT-5, Audio Video cables, etc)
·         Space near your entertainment center for the wine chiller.
15 comments
Mar 15, 2010. 1:38 PMlemonie says:
Had you thought of (at least partially) removing the console cases to achieve better heat-transfer?
L
May 4, 2011. 1:48 PMlemonie says:
These things do have a tendency to overheat so it seems, using the warranty is worth doing.
L
Dec 11, 2010. 2:06 AMjessedr says:
that will probably burn ur systems out from the condensation.
Mar 15, 2010. 7:10 PMComputothought says:
That is a neat idea. The only fear I have is if it is too cool you might have water condensing inside the unit and shorting everything out.
Mar 15, 2010. 5:15 AMunrealfan89 says:
 If your running the cooler be careful, there is a lot of moisture in those. Moisture is the worst thing for computers and game systems.
Mar 15, 2010. 12:32 PMJoe Martin says:
Did you read the Instructable at all?
In the final steps he/she mentions that he has uncooked rice and silica gel in the bottom of the fridge to absorb the moisture, though to be honest with you I would still be concerned and moisture was my first thought when I saw the title.
I suppose that if the rice and silica gel was dried out regularly it would be fine!
Mar 15, 2010. 1:17 PMunrealfan89 says:
 I did read the instructable.
I'm still concerned that having that in there won't completely remove the moisture in the cooler and it will slowly start killing the machines.
I think having a de-humidifier in there if you can find one small enough would be a better option and you won't have to keep buying rice and gel for it.
Mar 15, 2010. 3:11 PMvalhallas_end says:
In lieu of a de-humidifier (which frankly, I've found to be highly ineffective in cold storage units), basement dessicants might work even better than rice and silica.  I know AS&S sells military-grade dessicant, and we've had great success in keeping a notoriously wet spot in my basement dry with one we found at Lowe's.  The nice thing about most is the reactivation allowance - silica may need to be replaced, but the ones we use are in a mesh bag that you can toss in an oven and reactivate about 20 or so times (they work well for about 3 weeks).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:cmolle
