Ultimate Grim Reaper Costume
33,106
391
58
Posted
Introduction: Ultimate Grim Reaper Costume
Halloween Costume Contest
Fourth Prize in the
[10/27/14 Update: A friend took some shots of me at a local Halloween parade and then asked me to do a photo shoot. Add a fog machine and a backlit window and OMG this thing looks terrifying! I also want to thank everyone for the great comments.]
In 1998 we started having Halloween parties for our kids and
over the years I had constructed a customized Grim Reaper costume that lasted over 15 years. Even took 2nd place at a major Halloween party in Salem Massachusetts. I’ve always wanted to improve on my Reaper but it was never worth it until I started working for a local haunt in Massachusetts last year. Last year I introduced my old reaper costume to the masses and it was a major hit at this park and I finally had the motivation I needed to build Grim Reaper 2.0.
The First Goal: Make Reaper 2.0 extremely intimidating! Some people are just not afraid of the dark so this needs to either intimidate or highly impress the brave souls first. Height – 8 feet tall, 3.5 feet wide, exposed bones, accurate proportions (cannot look goofy, must look like a giant skeleton), make sure there is no human qualities visible.
The Second Goal: Make Reaper 2.0 scare everyone else without ever having to make a sound. Yelling and screaming does scare a few but mostly startles people. I want to see FEAR!!! Have to be able to move quickly and quietly with good visibility so you can seemingly appear out of no where.
How I achieved this…
Planning is critical. You need to determine how to do all of this with what you have lying around your house or plan on spending a lot of money to get the materials you need. Building something like this does take an investment and I budgeted about $500 for this costume and built everything from scratch. THIS is the key! Building something from the ground up is truly unique and you never have to worry about running into anyone wearing the same costume.
Download several images from the internet as reference for the ribcage, skull, arms and overall look that you want to achieve. I used a mix of real images and some artist’s drawings that had that scary look I wanted to replicate.
Things you will need to
· Alice backpack frame
· PVC pipe 1” and ¾ “
· Duct tape
· Liquid latex – black, 1 gallon
· Aluminum crutches
· Black burlap – roughly 30 yards
· Several other black materials that you want to add to your costume
· Wire hangers
· led lights, battery packs and wiring to enhance this if you want
· Tools used: Dremel and various bits, Drill, rivet gun, hot knife, saws, utility knife, utility brushes, air brush, spray paints.
Step 1: Frame and Rib Cage
Build a PVC stand to build everything to size. Mount the Alice pack frame on the stand so it
is at the same height when it will be worn. Disassemble a pair of aluminum crutches and size up the aluminum poles to be used as extensions on the Alice pack to raise the shoulder level higher than your head. I used the existing poles that have 1” extension settings so the shoulder height can be adjusted up or down by 1”.
Attached the PVC pipes to establish the shoulder width and use the flexible PVC pipes to build and shape a frame for the ribcage. This is a trial and error process because you have to plan for how this will fit around you and how you will get in and out of the costume. I used several paper templates to establish the exact size of the ribs, arms, neck and skull to get the exact proportions I wanted for this. I carefully positioned the location for the shoulder joints using ringlets screwed into the PVC. Everything else will be based on this so take your time and make sure you can fit well in this before continuing.
This is where you need to have some artistic abilities. I never attempted something like this before
so I’m pretty surprised at how well this came out but I just took my time and kept referring to reference images and constantly adjusting. The paper templates make it easy.
The ribcage was challenging because it had to be shaped around the frame, be flexible but also durable. There’s probably better materials to use but this is what I had available. I decided to carve the actual ribs out of white Styrofoam and covered it with several layers of liquid latex so I would have something light and flexible. Using the template, I simply shaped the front of the ribs in the foam using a utility knife, rasp and sandpaper then covered the front with latex to hold it together. Next, using the hot knife, I removed the back of the Styrofoam until I got the depth of the ribs that I wanted. A good hot knife is NOT cheap. I own one and it was perfect to make quick work with the foam. It would take more time but the extra material can be removed with rasps, wire brushes and utility knifes. Once I had the thickness of the ribs I wanted, I coated the back with one coat of latex to totally encase the Styrofoam in rubber.
I then used duct tape to secure the ribs to the PVC frame and to hold everything in place. Once satisfied with that, I covered the entire ribcage and frame in 3 – 4 coats of latex rubber making the entire ribcage durable enough to take years of abuse.
Step 2: Sculpting the Skull
The skull took an entire weekend to sculpt. I started by gluing several pieces of dense
wall insulation foam board together. You can use some spray glues or spray foam insulation to glue foam together. At this point I held my breath and hoped for the best.
The first thing was to get the basic size of the skull that would work on the reaper. It had to be bigger than any human head but not so big that it looks goofy. This part involved hand saws, rasps and wire brushes. At this point, the skull is still bigger than I wanted but I knew it would be reduced in size as I continued to sculpt the details. Better to start big.
The dense foam was difficult to work with and I tried using several tools to figure out what worked best. I found that I had to use a Dremel rotary tool to work with this foam. Anything else simply caused damage to the material. I used a combination of small grinding bits and various wire brush attachments for the Dremel which worked great. For my first attempt at creating a skull out of foam board, I don't think it would be possible to get this level of detail without a Dremel. And if you think about it, this is the MOST important part of the costume. Love my Dremel.
By the way, if you don’t already own a dust collector, it’s a good investment for a project like this. The amount of foam dust is insane and will cover every inch of your body. The final step for the skull was to coat it with a special epoxy coating I ordered online.
Step 3: Assembly
This was a challenge because you have to put aside any
reference drawings and start looking at what will look good in the costume. What you want to show and what you want to hide will determine how much work you put into this. I wanted as much of the ribs to show as possible without seeing a person inside.
The construction here involved the same process as above. I used various pieces of foam and PVC to build the shapes and then covered with the black latex rubber to hold all together and still allow some flexibility where it was needed. I also covered all of the bones with a base coat of off white or antique spray paint so all the bones have a uniform color.
I also added the lower arms and hands to the frame. I don’t have instructions for these because I
had made them years ago using wire hangers, PVC tubes, duct tape, pen tubes and latex rubber. They were the perfect size for this project and with a little paint, they went from monster hands to skeleton hands very quickly.
Step 4: Creating the Cloak
After extensive searches on the internet for the best
looking reaper cloak, I settled on a Jedi or rather Sith cloak for this costume. This was a perfect choice because I wanted the cloak to flow in the wind as I moved around. Having a single piece of material wrapped around you looks like you’re wearing a dress and isn’t very scary. There are plenty of plans on the internet on how to create this robe. The hard part was sizing it for the Reaper. At 8’ tall, it took close to 24 yards of black burlap and I had to spread the material out in my driveway to mark it out and make the cuts.
Ok, I’m no seamstress and I don’t own a sewing machine so I had to sew this cloak entirely by hand. Buy a large needle and some strong black string and give up a weekend or two and you’ll be satisfied with the results.
Under the cloak, I found a great nylon stretchy material that was heavy and hangs like a drape creating a great covering for my body. The stretchiness of the material makes it easy to move around and it hangs so well under the ribs that it almost appears as if there’s no body underneath. Oh, and I had to hand sew this as well so I took the easy way out. I bought 4 yards of material, cut a hole in the center for my head and draped it over my body covering my front and back. Then I only had to stich up about four feet on each side to create a makeshift dress. Yes, I’m wearing a dress and it looks good!
Step 5: Finishing Touches
Once I was finished with the cloak and ‘dress’, I removed it
to paint the bones. It would be difficult to get a great old bone look without airbrushing this and where I want the bones to show, I had to go into a lot of detail here. I took the approach of making the bones darker than I originally planned so it would look very evil in daylight and even scarier at night.
I also mounted some red LED lights for the eyes. Basic setup with a switch and battery and
there’s plenty of instructions online for lighting so I’ll leave this to your own imagination. However, while walking through an auto store, I came across some red LED light strips for a car and bought a few to shin up from the collar bone to light the skull from below and the second strip shined down lighting behind the ribcage making it appear there is nothing behind the ribs. These light strips were easy and perfect. They come prepackaged with batteries and a button. I only had to stick them in place and extend the wires so I could press the buttons at will.
I also used the handle from the crutches to create a nice
grip to manipulate the arms just below the elbows. All the wires ran to the back of the frame and I created some areas behind the shoulders that would fill out the back of the costume and hold the batteries. I have very good visibility inside this costume and I wear a black nylon hood over my face so even when the red lights are on, you cannot see any details behind the ribs creating a wonderful hollow effect behind the ribs.
Step 6: The OMG Moment
Putting this all together took another weekend because I
spent a lot of time tweaking many little details, velcro’ing the cloak to key points of the frame and I even extended a rod up through the PVC neck pipe into the base of the skull. I attached a “U” shaped wire to this rod that wraps around the back of my head when I wear the costume. This allows me to turn the head left and right just enough to look cool.
Stepping back and looking at this thing fully assembled
simply blows you away. I’m 6’2” and you simply want to step back away from this reaper to take him all in.
I recently took him out at the Halloween Event I work at last weekend and this was a major hit at the park. Up close or far away, this costume makes a great impression. I’m standing next to a giant clown head entrance (which I also created for this event) and the wall of that structure is 8’ tall so you can see the size of it. I’m also standing next to two other characters who are 6’ tall and the girl is 5’4”.
Hope you like my first Instructables project. Happy Haunting!
2 People Made This Project!
  • This is it!! Friday ...-monkaboo
    monkaboo made it!
  • I am 85% done. Will ...-monkaboo
    monkaboo made it!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
56 Comments
Great work. I have started my setup. I know it is only March, but I want to make it really amazing. My question to you is, the hands. How do you work them? What I mean is, I get the alice frame is on your back and that brings the Reaper head and shoulders up, but the arms you work with and they are probably up by your ears. So how do you work the arms comfortably? Could you take a photo on what inside the cloak looks like? I can only picture you grabbing the "elbow" of the costume and being in a semi permanent "Birdie Dance" pose. I hope that makes sense on what I am asking you. How do you work the arms when they appear to be up by your head? Also, do you think there is a way to set it up to make the head moveable? Meaning, when you turn your head to the right, the Reaper does as well?
Awesome, cannot wait to see how yours comes out.
I'll take it out of storage soon so I can attach some photos of how it fits on me without the cloak. I'm actually standing upright and it's very comfortable considering the size of this thing. The alice pack gives it that hunched over look.
When you extend the Alice pack, I used aluminum poles from old crutches and riveted them on the pack and made the height of the costume shoulders just above my head. I then used pvc to create the shoulders about 8 inches wider than my own shoulder width. This allows for the arms to hang down right inline with my own arms. The arm length is proportionate with the overall height of the costume. Your hands probably reach down to about mid-thigh so if you adjust the arm length like this, the appearance looks more realistic.
You also need to consider the rib construction to make sure you have plenty of room to move your own arms around while inside the costume. With the handles attached just below the elbows, it was pretty easy to manipulate the arms. Also consider the arm holes in your cloak. It needs to be long enough so that you can easily put your arms through the sleeves too.
once youve articulated the hands do you plan on a equally large sythe? Also if yes anyway to incorporate some (drywall) stilts into it make it even taller?! If you cant tell I've wanted to do something simular for a while! Oh AWESOME JOB!!
Thanks and YES I already have an equally large scythe. Made one years ago for my old reaper costume and it still works very well with this one. Adding an old image with my previous reaper costume.
I found this beautiful, worm ridden oak branch in my yard one day and couldn't stop myself from turning it into this scythe. The blade is made out of 1/2" plywood with rude etchings I made with my dremel. The construction utilized mortise and tenons to attach the handle and blade. Add in some old twin string and a rubber skull on top and you have one creepy scythe.
I plan on taking a video of the costume in action this weekend and will also add some pictures with the Scythe.
i have a question gpetit1. Whats your favorite part of the costume :o
Interesting question... I have to say the Ribcage is my favorite part of the costume. It had to be just right to pull this off and everything else connects to it. If the proportions were wrong here, it might look a bit goofy but when people see this thing, even in daylight, they have a lot of difficulty trying to figure out what's inside. I keep hearing, "is he really that tall?", "is he on stilts?", "is he inside the ribs?", etc... which tells me that I got the proportions just right and I can keep them guessing. For many, it's also the first thing they see before looking up so I wanted the ribs to look as good as I could make them.
Oh my hell that thing would be terrifying.
Well, you were not kidding; this is truly the ULTIMATE!!! Grim Reaper Costume. For years, I have contemplated the idea of making me one of these. Great inspirational material, that's for certain!
Terrifyingly AWESOME!!! You really hit the mark with your build! That skull sculpture is superb!
