Step 3The Forge
Cut a hole in the side of the big can about an inch from the bottom.
Make sure the pipe fits. (you could use a piece of rolled up paper or cardboard.)
Use a can opener on the bottom of the small coffee can and cut a mouse hole shaped hole in the lower side. (make sure the pipe fits)
Wrap the small can in cardboard. (this is to make it easily removable.) and cut out the mouse hole in the cardboard.
Mix the quickrete. We used 11 cups of quickrete and about 2.5 cups of water.
Pack the quickrete tightly in the bottom of the can and up to the bottom of the hole.
Place the pipe in the hole and the small can in the big can with the pipe in the mouse hole. Try to center the small can.
You want the pipe to go in diagonally. This will help create a spiral of flames. (see picture)
Fill up the sides with quickrete and pack tightly.
We let it set for a bit then put it in the oven and set it to 400.
After 30 minutes take it out and pull out the small can and the cardboard.
Put it back in the oven for 2 hours. This will help eliminate the moisture.
Use oven mitts and take it out of the oven. and bring it to our work area.
Lite the torch and stick it in the pipe.
I suggest wearing eye protection.
This first firing is just to eliminate moisture. You may see steam coming from the cement.
Let it fire for about half an hour then let it dry overnight.
We put the crucible in during the first fire to help burn off the paint.
http://www.abymc.com/Shop/Tzar_Foundry.html
