Step 5Now What?
I figure we could cast some blanks that can be worked in a tiny lathe but that's for later.
We'll Make an instructible on casting aluminum when we get it down to a simple science.
We hope you enjoyed this instructible and happy smelting.
I considered the build-my-own approach, but I wanted to make some stuff, besides the lathe itself, and I am glad I bought the lathe. Once I had the lathe, I did a lot of little things that were really fun and easy. I doubt I would have finished the Gingery lathe. It is a pretty big project in itself, and I notice that you can find lots of web pages showing the start of a Gingery lathe, but last time I looked, I could not find ANY of a finished Gingery lathe and something made with it.
But I will STILL stand by the basic idea. Only go in for a Gingery Lathe project if you really want to build the lathe. If you want to turn metal, a few months of part-time work, say $750, will get you a better lathe, with a 3 jaw and a 4 jaw chuck and a selection of cutters, boring bars, a dial indicator set and a few other starter items.
Oh yeah, with a little effort and talking to your favorite garage saler / flea market fanatic and you might get a call on a saturday morning...
also, ceramic and graphite crucibles
@All - a couple years ago, I took 600 cans to the recycling center, I got $6 for 'em. A penny apiece. Of course, the center has to make money, I'd bet they got $.02/ea for 'em... and the foundry probably gets $.04/ea after melting them into ingots... at most, I believe my 600 cans might have represented $24 worth of aluminum.
Part of the problem is that the cans are so thin. All aluminum forms a layer of alumina (aluminum oxide, clay) on the surface. Take a can, hang it from a hot dog stick, near the glowing coals of a hot campfire. The aluminum will melt & flow, forming a bulge at the bottom of the can. The oxide coating will not melt. By this, you can see how much of the can's mass is oxide. If your goal is to cast aluminum parts, you're much better off to buy/melt solid shapes of specific alloys - with bar stock, a MUCH smaller percentage of mass is oxide.
You're right about wanting to eliminate moisture -- even one small drop (even, say trapped soda), if it's below the melting aluminum, will most likely create a large explosion firing molten aluminum, slag, and most likely bits of forge everywhere.
I've heard of carts being blown to pieces and wheels thrown through/into metal walls. So be careful!
I'm not sure how your speed quench will affect the strength (or weakness) of the aluminum - often times too fast will create metal that's brittle -- weakened by the thermal shock. And then there's the possibility for slight explosions - you're right about it being dangerous, but it can also negatively affect the metal - I'd do some research on the topic before continuing with my impatience ;)
Great Instructable though!
If you were to slice one of your ingots and polish the edge (really really polish it down to at least 600 grit sand paper and either polish it with some diamond slurry or etch it with a hydroxide or HF(can be purchased in solutions for stained glass hobbies), Then examine it in a microscope, you would definitely see those iron precipitates as little black specks scattered around the sample.
For casting ingots or small DIY simple castings, there is not an issue with the alloy. Pot metal works for just about anything you want. (although the shrinkage is horrific and fluidity sucks without a great deal of superheat)
The downside to this is that you are slowly eating your crucible. So try to get as much of the post-pour metal out to inspect the crucible for pitting. This will be a rough surface that looks eaten away. Some time down the road, this might create a leak in your steel crucible (or worse).
Ranking furnaces from 1-10, 1 being coffee-can DIY, 3 being hobby, 5 being small scale production... 1-2 is pretty cheap (as you know). 3-4 is going to be anywhere from a well designed DIY setup costing ~$200 to $1000.
All said and done, the furnace I use most often now cost around $5000. not to mention having a 2 inch natgas line installed to run the thing. This is a Mifco furnace. you can check out other mifco products from http://www.mifco.com.
This unit can melt a lot. It can supposedly melt white cast iron (this is one of the lower melting point cast irons), but I have not really tried it yet.
one last thing:
assuming you cant weld... You can still create your own tools by using the exhaust gasses from your furnace to heat up steel to a plastic working temperature. You dont need an anvil or anything. just a pair of hammers. Secure 1 large (like 4 lb) masonry hammer (that is not precious to you) to a table or tree stump and this is effectively an anvil. Be sure to strike the face of the hammer, not the sides. You can now heat up scrap steel rods, and pull them off the top to hammer. This is how you can create some better tongs and crucible yokes.
Harbor Fright carries some good stuff (by good i mean, it didnt pass inspection to be sold as a brand name, but while full of defects, still useful and very affordable. Stay away from the vises and anvils from there though. They tend to use grey cast iron bodies with a capped high carbon steel face. This stuff probably already has cracks in it. it wont hold up to long use.
