3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate Helping Hands/Station
Well we just finished our project for the ultimate helping hands, just exactly what is the Ultimate Helping Hand Station? well it's a soldering station that pretty much does everything. Hold your iron, cleans it, tins it, holds ur project, illuminates your working area, etc etc etc. Take a look at our video to see what were talking about I hope you enjoy this and leave us some feedback.
HM-Innovations
Step 1Gathering The Parts
Gathering The Parts
  • last photo ←
You're going to need the following supplies for your helping hands.
4 pieces of  6" 12 gauge copper wire segments
4  alligator clips, make sure they are not to strong or to weak, after all they will be your helpers.
1 piece  of metal sheeting (you pick your preferred size, ours came out of a project box lid we didn't use)
a  5mm 3.6v LED
a  210 ohm resistor
a  3/4 of an inch pience of plywood the same size as your metal sheet.
a  9v battery
a  9v battery connection
1  Switch
Tinner and Cleaner for your soldering tip
1" x 3/4" pience of PVC pipe.
1  Metal cleaner to scrape extra solder from your gun
1 Altoid Can
1  Lighter Cap
and
a LOT of aluminum Tape.
24 comments
Mar 22, 2012. 12:16 PMoferamal says:
Dear friends, thanks a lot for this amazing group of information, I work sometimes with electronic and I had some problems with the soldering process and you exposed the solution here. Congratulations. Thanks again.
Mar 3, 2012. 8:02 PMseraine says:
Instead of making a holder from a altoids tin, take a 3/4" dowel or piece of pvc that's about 1' long. Drill a 1/8" hole about 1" from either end. Then get 2' of bare 12 gauge copper wire or heavy steel wire. Stick about 3" through the drilled hole, and bend it at a right angle. Wrap the wire around the dowel, so that it looks a bit like a spring. It makes a nice and cheap soldering iron holder, that's pretty easy to attach.
Oct 17, 2011. 8:18 AMdracorabbid says:
I made one of these to make one of these
Aug 6, 2011. 1:29 PMagis68 says:
awsome......the perfect assistant tool
Jul 26, 2011. 11:32 PMSinAmos says:
Your add is annoying. 1 star.
Jul 26, 2011. 4:49 AMMr.Sanchez says:
the Lighter part give it a fine touch...awesome...thx 4 share
Jun 22, 2011. 8:07 PMzgordon1 says:
you are a genious! i dont have one of those metal board things laying around the house so where would i get one and for how much? but if its on any regular household item, what would it be?
Jul 25, 2011. 6:37 PMLeumasYrrep says:
You might be better off finding a sheet of aluminum and cutting it to size. You should be able to find a sheet at your hardware store or order online from onlinemetals.
Speaking of the aluminum sheet it would be a lot better if you placed screws in each corner of the sheet instead of one in the center. That way the sheet is held down more securely and will not rotate.
Jul 24, 2011. 10:30 PMfrank26080115 says:
Sweet, I need to make one now. I'll look into adding a fume extractor.
Mar 6, 2011. 6:17 AMtareko says:
Greate DIY!
I hardly dare to suggest:
This is mainly for a soldering station. So, why not include a plug for the soldering iron and, drain from it the electricity for the led lamp? With the proper diode and resistor, it would save using the battery.
Also, instead of copper wire, I’d probably try steel cable from an old bike brake. It would be more flexible, and the tension from the four arms would make a stable hold, still allowing some downward flexibility, should you use too much pressure with the iron.
Jan 6, 2011. 6:08 PMkayla9 says:
Hi i think i will make this for my science project and i'd like to know about how much it would cost. So if anyone knows the answer please respond. thank you!
Aug 30, 2010. 6:53 PMsephiroth67 says:
It seems like cutting the same thing but out of wood, then covering it in something that doesn't burn would be a better solution. I guess the best we could get is non-conductive, non-flammable, and easy to clean (maybe). If anyone wants to expand the idea, please do. Would love to see someone actually do it. Sorry for the thread jack xD.
Jun 5, 2010. 5:08 PMKrb686 says:
That looks amazing! Good work!
May 22, 2010. 12:57 PMtech123456789 says:
 it's spelled solder not sauder .
just thought you might want to know.
May 21, 2010. 11:27 PMfruitkid101 says:
Hang on. Here you go, http://www.instructables.com/id/Helping-Hands-Hack/ check it out!
May 21, 2010. 12:01 PMnadav says:
 The lighter tip on the led is a great Idea.
May 11, 2010. 3:19 PMidontcar3 says:
 just finished mine.. but i added a mignifyer glass :D.. cool project :D.. it was fun
Mar 29, 2010. 2:37 AMpheer says:
i heard 'aluminum tape' and thought this was going to end cheesy and crappy loopking, but it turned out great, especially for a home cheapy station that works well... awesome job! chances are i'll be making something similar soon!
Feb 1, 2010. 3:06 PMjgeorge06 says:
 Forgive my ignorance, but it's the first time I've done anything like this. How do you connect the LED to the switch?
Jan 13, 2010. 1:44 PMPatented says:
Hey your project is so awesome! its like the luxury of soldering station! its look very nice with everything cover in aluminium tape, and what is coll is that you used household object so its very easy to do it at home. Everything from the clip to the light is very well done!
Thanks a lot!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
145
Author:HM-Innovations(HM-Innovations.com)
We are a group of Engineers, Tinkerers, Designers, Programers, and Nerds ! ---- and Since April 2011 We also have a Cupcake Maker
