Ultimate Hot Plate
655
Posted
Introduction: Ultimate Hot Plate
ultra hot hotplate
Step 1: Materials
the base is fire brick
the wire is canthol or resistance wire... sometimes called nichrome... whatever the name i got it from a vape store on ebay
Step 2: Selection
your personal preferences do apply in this application. How hot do you want it?
What will you use it for?
How much power do you want to feed it?
PLEASE DO YOUR HOMEWORK AND PURCHASE YOUR MATERIALS CAREFULLY
Step 3: Modification of a Perfectly Good Fire Brick
i used a full brick.
i guess they have halve bricks available. your choice.
i used a concrete saw from work to make the cuts in the brick make sure the cuts are large enough for what you have in mind...
WARNING THIS IS AN ELECTRICAL CIRCUIT. YOU CAN SHORT IT OUT. WITH COOKING DEVICES LIKE POTS AND PANS... ANYTHING METALLIC.
with that said i cut my grooves deep and the wire never contacted anything while pressed safely inside
Step 4: Wire Wrap
i wrapped the wire of an old tent stake... the metal kind... but depending on how you want this set up you can decide... make your wraps good and tight... you can stretch it out later
Step 5: Assembly
i took my perfectly measured and ohm tested resistance wire coil and press fitted it into the grooves of the brick trying to be as careful as possible to ensure even coil spacing and deep seating.
i did the math and it drew 10 amps continuously so i just wired a high temp wire to it and plugged it in.
too much or two less wire can result in an overloaded circuit.
be sure you use a nut and bolt at your splice points... it will melt copper wire and refuse to work
Step 6: Enjoy
ive used this in my bbq to burn wood in a oxygen free environment to get a really good flavor
also will melt aluminum... don't just set a pop can on it to see what it will do...
i use a furnace made like this to melt aluminum for casting... and as a kiln...
just do your math right to avoid expensive power supplies.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Trash to Treasure
      Trash to Treasure
    2 Comments
    thanks. I'm sorry it was an old project and i don't have better pics
