3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate Ikea DJ Unit
Step 2Putting it all Together
The first thing I did was to place the back up against the tabletop and insert some large screws (pre-drilled and countersunk). This goes straight into the supporting beams inside the wood, so is vital if you want a sturdy unit! I then added a few brackets on the inside where they wouldn't be seen, to give a little extra support.
Next I put the side pieces in place and inserted two of the large screws on each side to make another strong joint, then added the extra brakets towards the front to stop any movement.
The front isn't bolted down like the others, instead I just attached lots of brackets everywhere to keep it in place. You could drill from underneith if you really wanted, but I didn't think it was worth the extra hastle.
Now just place the last bit ontop and you're done (for this section anyway).
I am going to revisit this bit at some point, fill in the front panel and then add some self adhesive rubber around the tops for a better fit. It's not really needed, but I'm slightly on the obsessive side!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:monstamusic(Monsta Music)
MONSTA is a London based DJ and technology nut. This site covers all aspects of his music life including Mixes, Gigs, Ideas, Projects and other Monstarous activies.
