3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate Night Vision Headlamp - 500+ lumens with only 8 watts
Headlamp flashlight technology takes a quantum leap! You can have it all: * Intense brightness * Lightweight * Long life * Low cost * Rechargeable * Unbreakable * Small * Waterproof * Unique shocking turquoise color
Race proven! I put the light to the ultimate test by competing in the Gold Rush 24-hour Adventure endurance race in the Sierra Nevada mountains of California. Many of the other competitors had $500 HID lamps from NiteRider, Light & Motion, etc, yet throughout the race nearly everyone that saw my light commented as to its extreme brightness or asked where they could get one. It was that much brighter than anything else.
Specs:
brightness: 500+ lumens / 7 million+ mcd @ 15 degree
weight: 120 gram headlamp + 60 gram electronics + 280 gram battery pack = 460 gram total
cost: $60 including batteries
lifetime: 3, 6, 12, 24 hours (4 brightness settings)
size: headlamp portion 5cm x 5cm x 2.5cm
rechargeable: Ni-MH or Lithium-Ion batteries (your choice)
unbreakable: LED technology
Tech:
- Cyan (or Green) high power/high efficiency LED's
- high-transmittance TIR lenses
- high-efficiency DC/DC step-down converter
None of this was possible just a couple years ago, but now it can be done easily with inexpensive components you assemble yourself!
i've got several other power-LED instructables too, check those out for other notes & ideas.
This article is brought to you by MonkeyLectric and the Monkey Light bike ilght.
Step 1What's so special here?
Your eye! Remember back to biology class - your eye has "rods" and "cones". these are the sensing cells in your eye that detect images. the cones are your daylight & color vision, but they are less sensitive than the rods. Now the part you didn't learn in school:
(1) The rods are about 2.5 times more sensitive to light than the cones. That's why they are your night vision.
(2) The rods and the cones are not equally sensitive to all colors (wavelengths) of light. The wavelength of maximum sensitivity for your rods is 507nm, or blue-green. Why? Moonlight is more bluish than sunlight. The color of maximum sensitivity for your cones is 555nm green, about the color of plants. (more info)
To get the best possible vision at night, we'd like to build a lamp that puts out the most light at the 507nm that our rods are most sensitive to. This gets us the best vision at night for the least power used. If we had a white light instead, it would take much more power to get as much visibility.
Thanks to our friend the LED, this weird pure turquose light is possible! The latest LED technology is much more efficient than a standard light bulb to begin with, but using the special turquose color gives us even much better night vision than white, and is more efficient than even the fanciest HID lights.
573 comments
1-40 of 573next »
Nov 21, 2011. 11:47 PMOimi says:
End result for light intensity appears to be fantastic. Is there a way to make this more attractive and weather/batter proof? It all looks a bit fragile because everything is exposed.
Oct 13, 2011. 4:55 PMOrienteeringGuy says:
From my experience with night orienteering, I found that a red light is worthless because green plants absorb the red light. Thus, they appear black like the rest of the night. A green light should reflect well from the leaves, making them easy to see. However, the green light may not reflect well from other color surfaces. White light has all the colors and will reflect off of any colored surface. I would like to see this headlamp made with white LEDs.
Oct 3, 2011. 3:26 AMbsangpulnak says:
Mr.Dan, If I want to put an ac power supply to your project by using a ADC converter, what should I do so that I still get that monstrous lighting capability?
Jul 27, 2011. 2:30 PMcamaxwelljr says:
tto F'n cool!
Jun 29, 2011. 6:34 AMJoell says:
Hey good job with this project. I especially like the design decisions to use specific wavelength LED's to take advantage of characteristics of the eye. Well done! :)
I found this instructable because I'm trying to make an illuminator for a basketball court for night playing. Would it be sufficient to just omit the lenses because the LED's would still be putting out 45 lumens/watt from your datasheets wouldn't they? Plus the light would be more diffused and wouldn't be blinding to look at i imagine.
Basically this design is appealing because of the contained batter pack and stuff; there isn't a readily available power socket nearby.
Thanks in advance :)
Jun 15, 2011. 12:22 PMPinaki Tarafder says:
Hy! Gr8 job....
I like 2 Try this...
Mar 21, 2010. 12:16 PMThat Inventor Dude says:
Couldn't you just use red?or a cyan/red
why red? because red photons(light particles)do not affect your night vision(as far as I know)
so your eyes will still be able to see in the dark sort of if the light dies and as
Lol loy1 said the rod receptors will still work when you turn off the light.
Mar 22, 2010. 3:25 AMKryptonite says:
This is for brightness, not truly a "night vision" headlamp.
Apr 4, 2010. 1:43 PMThat Inventor Dude says:
you did actually read the title, fool,
its called a "Ultimate Night Vision Headlamp" so it is for night vision
although not necessarily as i was saying if the light fails then your night vision would remeain active
Apr 5, 2010. 3:07 AMKryptonite says:
The author is saying this is for seeing at night, not seeing in the dark.
Mar 26, 2011. 10:27 AMThat Inventor Dude says:
yet you fail again, it is dark at night therefore my argument stands. let me rephrase this... the human eyes are adapted to see(ish) at night if they need to. this is done by opening the pupil to allow more light in. it is dark at night, yes? the human adaption to light levels is known as NIGHT VISION seeing as nighttime is dark. you can test the pupil thing in a dark room with a torch. However i was saying it would be good to be red as red light unlike all other light does not interfere with human night vision other colors would disrupt dark seeing abilities ... if i had a torch (not red) and it failed (batteries?) and i had no way to recharge the torch my eyes would be adapted to the ample levels of light but red light would not make ur eyes used to high light levels so it would illuminate while allowing your "night vision" to maintain itself even if the torch dies.
Jun 27, 2010. 1:08 PMSaturn V says:
You're right about the red light not affecting your natural night vision, but night vision equipment allows you to see without casting light over the area.  This is basically a very bright head lamp, not true night vision.
Jun 29, 2010. 12:58 PMThat Inventor Dude says:
yes but if its batteries failed then if the lights where red your natural dark seeing type style abilities would not be compromised. also i never meant night vision as in splinter cell type things i meant seeing in the dark without a light source.
Jul 11, 2010. 9:02 PMKryptonite says:
Hopefully one's batteries won't die, and if they do, then it will take ~1 minute for your eyes to fully adjust.
Aug 23, 2010. 8:13 AMThat Inventor Dude says:
So? I was just giving a simple idea to potentially improve the design. seeing as you think ideas to be foolish i think I'll go do something else
Aug 23, 2010. 8:09 AMThat Inventor Dude says:
well your certainly optimistic. i was i only pointing out a simple way it could be improved but seeing as potential improvements and ideas are such foolish ideas to you i think I'll go and do something else
Aug 24, 2010. 5:56 AMThat Inventor Dude says:
sorry about double post the reply didnt seem to work first time
Aug 24, 2010. 3:21 AMKryptonite says:
I appreciate your ideas, but in this particular Instructable the author is trying to attain as much brightness (for our eyes) as possible, and using a red light would decrease that. For your own project you could make a red one easily.
Aug 24, 2010. 5:54 AMThat Inventor Dude says:
why would red decrease that?
Apr 12, 2010. 3:43 AMkill.cactus says:
 FLAME WAR FLAME WAR FLAME WAR!
Thanks a lot for all the instructions on this. Very well done :)
Apr 13, 2010. 3:08 AMKryptonite says:
:D
Feb 19, 2011. 8:21 AMbbennett2 says:
Is there a way to use 2 turquoise, and 2 red leds on this model, and then use one of the buttons to switch in between the 2 colors? I'd like a headlamp with red led's so that I do not lose my natural night vision when hiking at night; however it would also be nice to have the turquise lights for times when I want a more traditional headlamp... any suggestions?
May 22, 2011. 8:42 PMnutsandbolts_64 says:
Turquoise-colored light is still within the range of your night vision, so you don't need to switch to red.
May 23, 2011. 2:25 PMcrobson says:
hey. was wondering what sort of lumens i would get off white ones. as i would like to build one for work... and white would be better.
thanks.
Mar 30, 2011. 12:12 PMsnotty says:
I made mine solar powered.
Someone asked me "Is that solar powered?" I had my solar charger at home but the question prompted me to make my helmet solar charged.
40 minutes later I had a thin film panel and a diode on there and it's working fine so far.
Now to make a charge level indicator.
May 22, 2008. 6:04 PMblacknkhak says:
i like the idea a whole lot. here are a few suggestions . watch band instead of head band puts the light where your hands are which is extremely helpful for construction related applications. a simple automotive rheostat switch with a single resistor would vastly improve light intensity issues and provide a moonglo effect for periods when only tiny light is necessary. another fact is more bulbs don't mean more light. the intensity of the flashlight does not increase with more bulbs and the light spread increases only modestly while battery life is diminished greatly. four widely spaced bulb would work better than four closely grouped ones.
Jun 5, 2008. 4:06 PMbrad says:
I'm sorry, I have to disagree no almost everything you said. 1) This was built to be a bike light. A watch band bike light wouldn't be useful. You want to put it on your wrist, that's fine. 2) An automotive rheostat would significantly reduce the efficiency of the circuit. While running at low power you'd be losing large amounts of power to the "dimming" circuit. Truth be told, cutting power to individual lights would be a better way to dim this unit. 3) More bulbs DOES mean more brightness, provided the system has enough power drive all four. If you want more spread (not really useful for bike riding), then you can angle yours differently. If multiple lights in the same place didn't "add" brightness, you wouldn't be able to see city lights from space.
Jun 6, 2008. 9:09 AMblacknkhak says:
does having four tires on a bike make it go faster? if this idea was meant to be strictly for one application then why call it head lamp and not bike light? all modern rheostat circuitry is identical to your "buck puck" only undoubtedly clunkier. finally , a significant problem most people have with very bright and focused lights in dark areas is blindness, creating a bike light with a less tight beam would allow for a general field of vision that would undoubtedly allow for natural eye movement that occurs autonomous of the head's orientation. PLEASE UNDERSTAND your creative undertaking is first rate in my view my suggestions are only intended to illustrate enthusiasm.
Jan 17, 2011. 10:27 AMsnotty says:
Maybe someone already mentioned this but I think brightness is added logarithmically which means twice the number of bulbs does not mean twice the amount of perceived light. Sound volume works this way; you need way more (maybe 10 times more?) for it to sound twice as loud for our ears. And I think our eyes see in the same way. Maybe someone who really knows can tell us if we need 10 times more LED to increase perceived brightness 2x.
Jun 6, 2008. 9:28 AMblacknkhak says:
oops , peripheral blindness. sorry
Oct 27, 2010. 10:04 AMmrsayao says:
Hey Dan, Great work, I've been meaning to pick up this project for several years now and here I am, you're truly an inspiration!! I was able to source most of the parts, the only difference is that I'm using a single 9v alkaline battery due to portability needed. How would I calculate the resistors I need? I'm using 4 green LEDs that are spec'ed similar to the cyans. I'm not using this setup for a headlamp, so I don't need the full brightness, yet I'd still like to use resistors to lower the brightness further. I purchased a buckpuck rated for 1000mA. With 4 LED's hooked up @300mA each (1200mA total), does that mean I don't need the resistors since the buckpuck will only output 1000mA max? Each LED would be receiving 1.75v @ 300mA (2v accounted for the buckpuck).... Please please correct me if I'm wrong! I have a somewhat basic understanding of all this, but I don't have a teacher to tell me otherwise! Thanks!
Dec 9, 2010. 7:53 AMGavin.Perry says:
For 9V use 3 LEDs in series (if Vf of LEDs is <3V) or 2 parallel pairs of 2 LEDs each. In general you want the power supply voltage a few volts more than the batteries. Now you can use a simple resistor to set the current. Say your forward voltage is 6.8V, at 9V in you have to drop 2.2V so for example 220mA, you need 2.2/0.22 or 10 ohms. For power it's V*I so 2.2*0.22 <0.5W use two 20 ohm 1/4W resistors in parallel if you don't have 1/2W R's, or 3 30 ohm, or 5 47 ohm etc. see below for why to use more larger Rs (small wattage).
The brightness will dim slowly as the battery power drains and the voltage drops, I consider this a good thing, rather than suddenly running out of light. For more fun (and a bit more work) you can arrange a set of switches that add in one 47-50 ohm resistor in parallel, for each switch (little DIP switches are good for this) Each switch will add in 40mA or so. Thus you can cheaply and easily adjust the brightness to the need at the time. Your eyes adjust to a huge range of brightness, often 40mA of light is all you need if you aren't trying to read and want to stay somewhat dark adapted. There is no need to have the light on "full blast" when you don't need to waste that power. And it's a lot cheaper than a IC current regulator.
Look up series and parallel if you aren't sure which is which.
I hope this helps, I love having cheap LED lights that I can adjust to the need at the time. I also do a similar trick with an LM317 wired as a current regulator, but that's another story.
Dec 9, 2010. 8:21 AMmrsayao says:
Hi Gavin, thanks for the info! I studied hard and was able to complete
my project, http://www.instructables.com/id/LED-Light-Up-Sims-PlumbBob-That-green-pylon-above/ . I ended up using 3 LEDs with a buckpuck like how Dan did because of my own limited experience with electronics. He does use a LM317 in a different istable. Can you check out my istable and let me know what I can improve on? I decided on not using any switches to control the current, I bought a 1000mA buckpuck but only needed 750mA to achieve the best efficiency, so I calculated the resistor value and put some in parallel in order to get closest to 750mA. Thanks again!!
Oct 26, 2010. 3:10 PMmrsayao says:
Hi Dan, I have a crap load of 9V batteries at my disposal. They're duracell alkaline... will they work? Would I be able to use 2 of the batteries to account for the overhead, since the buckpuck is regulating the voltage to the LEDS? Also, will I burn out the main big switch since it's rated at 14v? Great work!!
Oct 25, 2010. 6:27 AMgatorbill says:
great diy project,dan!!.....very detailed,and complete. i am going to check out your other articules. thanks so much for posting!!
Oct 10, 2010. 10:56 AMinstruct39 says:
i have 3 words for you, and they are SHOOP DA WHOOP!!!!!!!!!!!!!!!!!
Aug 15, 2010. 1:16 PMRhodesA6 says:
Rondos you are right in my opinion as it is dangerous however if you are a sensible rider a helmet would be worn and the mount for the light would cover most of the fins, also a piece of foam could be stuck on the back. I hope this helps
Jul 31, 2010. 5:39 PMVick Jr says:
I like the color, and love the 'ible, but I thought it was funny that this was named "the worst possible night vision light you can have" by flashlightreviews.com. You can see excelently with it, just don't turn it off! (it would be very good for blinding people at night though)
In any case, I will definitly make this if I can get the parts.
Jul 19, 2010. 4:03 AMnutsandbolts_64 says:
The first image sort of looks epic! Nice headlight by the way.
1-40 of 573next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
525
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
