Step 10Strain relief the wiring
first, i covered my entire wiring with a sheath from a 3/16" rope. if you've used very durable wire to begin with this may be overkill.
next, i made a strain relief where the wiring attaches to the headlamp, so that it won't get tangled or ripped when the lamp angle is changed, or the battery is dropped.
make an overhand knot in the wire, then glue it to the base plate. the knot gives much better grip to the sheath and the glue.
Literally, it is barely adequate for a single 3W LED. I have built plenty of LED lights for years and speak from a great deal of experience in light longevity and the effects of overheating.
- LED Type : Luxeon K2
- # of LEDs : 4 (+$21.00)
- Color : Cyan
- Drive Current : 1000mA
- BuckPuck Options : Dimming w/ Pot.
- Power-Supply : 12vdc2.5a
How large of a Heat sink will I need?Thanks in advance.
Actually ambient temperature could easily be higher or the same, unless you live on an climate controlled planet?
Keep in mind also that you aren't always riding the bike, sometimes you need to stop or slow down but would still need to see, and even when you are riding it is still a small heatsink for the low volume of airflow you'd achieve.
I agree in some uses the light won't overheat, but my point was it will overheat in others. I don't feel any light that requires you keep moving to not overheat is a good design although others may feel differently.
see http://www.instructables.com/id/E4IY4TQD5QEPD7R06P/
