3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate Night Vision Headlamp - 500+ lumens with only 8 watts
Step 11Make the battery pack
make the battery pack
the "Buckpuck" lets you use pretty much any battery pack. The buckpuck is just an efficient (90-95%) DC-to-DC step-down converter, so it will always output the correct voltage and current to the LED's no matter what the input voltage is. The LED's may need up to about 7V to run them, and you need to add 2V overhead for the Buckpuck - so any battery pack above 9V will work. 8 x NiMH cells will be 9.6V, 3 x lithium-ion cells will be 11.1V, and 10 x NiMH cells will be 12.0V. those are all good choices.
I used 8 x NiMH cells, AA size. These are 2700mAh cells, which yielded about 3 hours runtime at maximum power, and 24 hours runtime at minimum (1/8) power.
12 comments
Oct 26, 2010. 3:10 PMmrsayao says:
Hi Dan, I have a crap load of 9V batteries at my disposal. They're duracell alkaline... will they work? Would I be able to use 2 of the batteries to account for the overhead, since the buckpuck is regulating the voltage to the LEDS? Also, will I burn out the main big switch since it's rated at 14v? Great work!!
Jun 27, 2009. 4:28 PMkarlosantana says:
And if you want a REALLY kick butt battery pack go on ebay and search for Li-Po. It stands for lithium Polymer. It is one of the best battery packs I've ever used! Oh and cheers for this Instructable its awesome I've done three headlamps now one in red for hunting which works really well. Thanks again Dan Kyle
Jun 27, 2009. 4:54 PMKasaron says:
Don't LiPo's Explode when Overcharged?
Jun 28, 2009. 5:34 AMkarlosantana says:
Any battery will explode when it's overcharged but you have to buy a special charger for LiPo's that cut off when the battery is full, :D
Mar 21, 2010. 8:07 AMjumpfroggy says:
Where'd you find a li-po charger?  Thanks.
Mar 21, 2010. 9:29 AMthinkdunson says:
 i got mine from www.towerhobbies.com, but i'm sure there are hundreds of places.
Dec 22, 2009. 8:05 PMWestCoast says:
I'm quite intrigued by this light and I'm getting ready to start gathering the supplies.  I was wondering if any one knows if I can I run more that 4 LED's with this setup.  Say maybe 8 for around 1000 lumens?
Mar 28, 2007. 2:17 PMpringelsfan007 says:
One thing to remember with a voltage limiter circuit, the higher the overvoltage the more heat and wasted power one will observe. As mentioned a two to three volt overvoltage is all that is needed to get the DC - DC converter to work properly. Any more cells in the battery pack than is needed is a waste of weight and space. Cheers! ;-)
Jul 20, 2009. 7:45 AMshepco says:
Thank you pringelsfan007, I was wondering if Two packs of 8 AA should be run in series (24v) or parallel (12v).
Mar 26, 2008. 6:20 PMburna10 says:
Great project. I'm going to build one with the view of turning it into a dive light. The driving voltage has got me a bit stumped tho'. These 1 W luxeons, they have a driving voltage of 3-3.27 volts don't they? That would mean you'd need 12-13.08 volts to run them. Or have I got this arsed up somewhere?
Apr 3, 2008. 11:07 PMburna10 says:
Ahhhh, penny has dropped! You're running parallel pairs!
Dec 19, 2007. 11:20 AMfjguilfoyle says:
HI there, Where did you get the pack that links all your batteries together? Thanks john
Feb 10, 2008. 6:55 PMdaniel333 says:
How do you recharge the batteries? Do you have to take all the batteries out and recharge them separately? thanks, Daniel
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
525
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
