Step 8Solder brightness resistors
R1 = 680 ohm (blue gray brown)
R2 = 1200 ohm (brown red red)
these values worked for my buckpuck despite a somewhat misleading note in the datasheet, so test your resistor values before soldering.
these values give you FOUR overall power settings:
- both switches off: full power
- one switch on: 1/2 power
- other switch on: 1/4 power
- both switches on: 1/8 power
1) heat resistor lead and melt a small blob of solder to it ("tinning" it)
2) heat the switch lead and melt a small blob of solder to it also
3) now hold the resistor lead against the switch lead and melt the two solder blobs together, without needing to add any new solder.
this is good soldering practice in general anytime you are soldering something that is heat sensitive (such as the battery holders)
The brightness will dim slowly as the battery power drains and the voltage drops, I consider this a good thing, rather than suddenly running out of light. For more fun (and a bit more work) you can arrange a set of switches that add in one 47-50 ohm resistor in parallel, for each switch (little DIP switches are good for this) Each switch will add in 40mA or so. Thus you can cheaply and easily adjust the brightness to the need at the time. Your eyes adjust to a huge range of brightness, often 40mA of light is all you need if you aren't trying to read and want to stay somewhat dark adapted. There is no need to have the light on "full blast" when you don't need to waste that power. And it's a lot cheaper than a IC current regulator.
Look up series and parallel if you aren't sure which is which.
I hope this helps, I love having cheap LED lights that I can adjust to the need at the time. I also do a similar trick with an LM317 wired as a current regulator, but that's another story.
my project, http://www.instructables.com/id/LED-Light-Up-Sims-PlumbBob-That-green-pylon-above/ . I ended up using 3 LEDs with a buckpuck like how Dan did because of my own limited experience with electronics. He does use a LM317 in a different istable. Can you check out my istable and let me know what I can improve on? I decided on not using any switches to control the current, I bought a 1000mA buckpuck but only needed 750mA to achieve the best efficiency, so I calculated the resistor value and put some in parallel in order to get closest to 750mA. Thanks again!!
