After much veiwing of instructables I wanted to make a hybrid. I would mount a spindle for wire, soldering Iron rest and a helping hands onto a 10' x 16' x 1/4' copper plate.
The soldering station would still have room to tinker on though, plus it also would have little feet to keep the heat off you desk.
See the Soldering Group for more Ideas
I also used Build a Pair of Helping hands
Remove these ads by
Signing UpStep 1The surface
Its best to have a larger surface then you think you would need because the soldering station is very easy to upgrade.
I used at 10"x16"x1/4" copper plate.
When my dad gave me the piece it was super sharp and the edges were covered in burs. I used a sander to round and remove the burs. The corners were very pokey too so I got a file and rounded them off.
A smooth wooden cutting board may even do the trick for you. I could see an end grain board not being too bad.
Even if the tool was of the highest quality, and it obviously isn't, under pivot strippers are very awkward to use.
My solder station looks like this:
http://i.imgur.com/peQxb.jpg
As you may be able to see I use a stainless steel plate for my surface. Oh and a dirty old mouse pad too which I've recently, since that picture was taken, cleaned somewhat. It came up pretty good.
Before I used this steel plate I used to use a piece of tempered glass but solder that fell onto it pitted it and I didn't care for that with my vacuum vise.
I wouldn't call my setup the ultimate but it suits me and we all use what we have right? If that plate of yours really is solid copper I think you can use it for better things though. I know I would.
You can see a little more of my setup here:
http://www.instructables.com/id/Pauls-Electronics-Pit/
My little slice of paradise ...
The last place I used some of my copper plate:
http://i.imgur.com/JpnK1.jpg
You can see a little strip poking out from under that breaker in the lower left hand corner of it. It lives here now:
http://i.imgur.com/01rFH.jpg
Can you see it?
