ATTN! If you like this guide please rate it with a 1-5 star rating to the right of this text and leave comments with constructive criticism :) Thanks :)
Intro:
This is a guide to building a 2 different great "EarthBox" systems for next to nothing in relation to the $50 commercial version. The smaller is a more experimental idea and may just be TOO small... the larger will work as well or better than the commercial counterpart. This instructable will cost you about $10 for EVERYTHING for the smaller and about $15 for the larger... I recommend building 2 of which ever you chose to bring down cost... or build 2 of each like i did :)
Name:
EarthBox is a commercial version of a "self contained gardening systems". From here on out i will call mine TeraHydro Boxes... lol... my own brand... lol
TeraHydro Box explains exactly what it is tho... it is basically a hydro system for growing plants that also incorporates a small amount of dirt for plant stability and fertilizer delivery. Further explanation of the science is in the first step of this project.
Advantages:
The advantages of growing plants in a TeraHydro Box are abundant.
-A place to grow for those without "real dirt" aka large yards
-Requires much less space
-Saves huge amounts of water
-Easy to keep plants well watered
-Almost maintenance free all season after planting
-Huge crop yields
-Easy to grow organic or "regular"
Update!! BOTH the small and large TeraHydro Boxes worked excellent. The Large TeraHydro Box worked much better than the original Earth Box even!! I harvested gallons and gallons of salsa. Way to much in fact, haha... While I still recommend 6 tomato plants for the large THB, 2 would be better for the small one. Six plants was just to much vegetation for such a small area and the plant were a little small from not getting enough light. Check my account soon for more garden projects in 2010! :)
Step 1: How it Works
Essentially, you have a large plastic tub, with a water reservoir in the bottom, dirt on top with a huge strip of fertilizer, and the whole thing acts similar to a hydro system for growing plants and vegetables. If you don't know what hydro growing is, the short and sweet version is: it it a growing system with no dirt, that allows the roots to grow in a large bucket of fertilized water. After taking apart an Earthbox after a season of growth i discovered all of the roots had reached the water reservoir and were doing just that. NOTE: whether you use my build design or not there are two things i know are very important that most other guides overlook. In order for the "hydro" part of the earth box to work the water reservoir has to be absolutely dark, to promote roots and discourage algae, and there also must be tons of hole in whatever device you use to separate the water and dirt. Other wise you end up with wet dirt, like you needed, but root bound plants which is not as good for plant health.
Earthbox is a good system. A great system even. Just wayyy overpriced. My TetraHydro Box is based off the same principles, and i deviate in a few small ways, but usually will tell why i did and what Earthbox recommends instead. For example... Earth boxes recommends only 2 tomato plants per box, yet i have grown 6, even in their box, with tons of success so that is how i do it now. Perhaps they have a reason, or think they have a reason for why you should only plant 2 plants, but i think its just to sell more boxes... lol... alot of the things they recommend doesn't seem like there is a real solid reason tho... i think they pushed the product to market as fast as possible and did not get real exact on how or why you should plant things a certain way. The majority seems like educated guesses from smart people, so i use their instructions as a guide and experiment with my own ideas too :)
Step 2: Material List
If you are new to this goring system... just skip the experimental small box, build the large and be amazed!! :)
Everything is nationally available and purchasable at Wallmart and Home Depot. First is the list for each box system and below is a more detail description with important notes on items like the fertilizer and dirt.
Large TetraHydro Box:
-Large 18 gallon storage bin (Wallmart $4)
-Steralyte plastic basket w/ holes (Wallmart 2 for $3)
-2 cubic feet of potting soil (this brand at Lowe's $5, but find it at Home Depot also)
-2 cups of fertilizer (Home Depot $12 for HUGE 15lbs. bag, you can buy way smaller)
-2 cups of garden lime (Home Depot 10 cup bag $3.50)
-About 1 foot of 1 inch pvc each (Home Depot $2.5 for 10 feet)
-6 scrap of any rubber tubing for drain
-Large trash bag
-Veggies!
Small TetraHydro Box:
-Small 18 quart dish bin (Wallmart $3)
-Drawer organizer plastic basket w/ holes (Wallmart 2 for $1)
-1/2 cubic foot of potting soil (this brand at Lowe's $2.5 for 1ft, but find it at Home Depot also)
-1 cups of fertilizer (Home Depot $12 for HUGE 15lbs. bag, you can buy way smaller)
-1 cups of garden lime (Home Depot 10 cup bag $3.50)
-Large trash bag
-Veggies!
Details:
-Box
Nothing to specific make sure its large enough and will hold the basket with holes in it upside down. If you don't buy the suggested bin you will have a good understanding of how to pick your own by the end of the guide.
-Basket:
Make sure it fits in your box upside down. you are going to drill holes in the bottom later so it will act as a membrane between dirt and water but allow the roots to penetrate.
-Dirt:
Earthbox recommends or more requires that you only use potting MIX... i use SOIL... either is fine... mix just costs more. Earthbox says the difference is that soil contains rocks and mix does not. I have no idea where they came up with that idea. I have never seen a rock in potting soil, and so what if there was a few is it worth double the price? The difference i do know of tho is that potting MIX has already been fertilized and they add perlite. Perhaps that is worth paying double for, i don't know tho. I've used them both in separate boxes simultaneously and noticed no difference.
-Fertilizer:
Earthbox says any fertilizer will work as long as the numbers are 15 or less, as in 5-8-12 or some combination. The one i am using is 16-16-16. I guess I am just defiant... lol :)
-Garden lime
Very hard to find! Strange considering how important it is for gardening tho. Earthbox recommends you use dolomite or hydrated lime. I understand that the lime used for concrete can also be used but may burn plants. The brand I found at home depot was cheap enough and has way more benefits too. The purpose is too raise the soil ph as most vegtables need more acidic soil and also to fortify the soil with calcium. Without your plants may suffer from what is called blossom end rot and it ruins you crop. I have seen it personally years ago and would add the vitamin tablets of calcium or crushed egg shells after ward, but the garden lime i found has tons of other vitamins and minerals too.
Step 3: Begin! Drill Holes
Ignore the etra steps already don on the large one... we'll get there :)
Step 4: Cut PVC, and bgin assembly
Next put your basket into your box upside down and cut a corner of the basket to penetrate the pvc through.
Sorry no pic of the large bin because if forgot till i had added some dirt! lol...
Step 5: Drain hole
forget the dirt in the small one... lol.. the drain hose was a last minute mod :)
Step 6: DIRT! :)
For the large boxes the take 1 cubic feet of dirt that means add a whole 1 cubic foot bag right now, and for the smaller boxes it only takes 1/4 cubic foot.
Next, fill the reservoir with water till it starts coming out your drain hole. Then thoroughly soak the dirt down for at least 60 seconds so it is completely drenched throughout. You can even "massage" the dirt a little with your hands to get it to soak in everywhere.
Now add 1/2 the garden lime for the large TetraHydro Box, 1 cup, and all of it for the small box,. also 1 cup.
Next, add the rest of the dirt to top off your box and soak the dirt for another 60 seconds.
Step 7: Fertalizer Strip
In any case... dig your small trench and add all of the fertilizer. Cover the fertilizer again and when you add the plants try not to disturb the fertilizer strip at all.
The Earthbox recommendations are attached as a pic.
Step 8: Add cover
Step 9: Add your vegatbles! :)
Enjoy your veggies! :)
Visit Our Store »
Go Pro Today »
We used one box for herbs (basil, chive, cilantro, rosemary) and the other for veggies (peppers, carrots and cucumbers). Thanks for posting the instructions!
One question. In the begining, when the roots are still making their way down to the water, do we need to water from the top? I'm worried about things drying out.
I think that a cheap fabric mulch cover would help keep the dirt out of the reservoir, but still allow the water to wick to the soil. I get rolls of the stuff from a dollar store for $5. It's only meant for one season anyway. Good for tops, too.
1) Does this system work well with starting from seed? ie, could you leave it open and sow seed in there and thin and transfer? Or only with small established plants?
2) if using a pre used bin, how should one clean it to prep it? Pretty sure it has only been used for yard work, But it is pretty dusty and dirty.
BTW you are now my new favorite person. I am going to make 2 a week until I can do my whole yard in these... Well maybe not the whole yard. But definitely the back patio.
2) I would try to use only water to wash the bin starting with boiling water to kill anything that might harm your plants, then give it a good scrub with just warm clean water and finally when it looks clean a final rinse with boiling water. There may be some plant safe products out there you can buy but boiling water will do the job just as well.
Have fun and post some picture when you get going let us all see how you are doing.
Going to make several of these right away.
I do have a question tho. What is the purpose of the 1" pvc in the corner. Would you use it to replenish the nutrient rich water?
Also I am reluctant to drill a hole for drainage, unless I plumb the drain line to recycle the spilled nutrients.
For this set up, what would you say would be the minimum required amount of sunlight per day? Thanks,
As a way to prevent the dirt from dropping through the reservoir holes when filling up the box, you could cover the grate with non bleached household paper. Once the dirt is thoroughly soaked, the paper will quickly disingrate and allow root propagation.
A question, though...When you say 'add the plants', how big are the plants you are using? Seeds, little sprouts, or the baby-sized plants like you get in a pot from Home Depot?
How often do you water them? Does it really need to be filled every day as the earth box instructions say? I though the point of having a "self-watering" system is not having to water all the time.
Is it bad to use soil based mix? Square foot gardening recommends 1/3 compost, 1/3 peat, 1/3 vermiculite, but earth box says no compost and 75-80% peat. Could I use something in between these two recipes? I was hoping to take advantage of the town's free compost, and also rather not use that much peat as it is not renewable. I know I could use coir but not sure if there is a local source and the shipping is expensive for it.
Thanks
In regards to your soil question... There needs to be better soil options, yes.
I will be working on a new recipe for the spring of 2011. I am growing organically now and would like the still use my boxes. The organic potting mix and organic dry all purpose fertilizers are an option, but would cost over $20 a box and not an option for me. The reason earth box tells you not to use compost is because it makes to dense of a soil. this system only works with "light" dirt, lots of airspace, and well draining. Compost sops up and holds moisture. So there is my challenge, but I promise I will have a solution for 2011.
I am guessing that 1/3 compost, 1/3 peat, 1/3 vermiculite would work, but would also be expensive. And... peat is not renewable, you are right, however there are alternatives to peat available such as composted tree barks or other regionally available options. Google some :)
What would you consider as a "too small basket"?
Very good and clear 'ible'
Keep updating please.
Chefmichel
In the large boxes there is a variable amount of dirt space from approximately 1 inch all the way to 3 inches as you reach the top of the baskets. That seems to work well and leaves plenty of room for a large reservoir. Big baskets are good for the same reason. Large reservoir. I wouldn't use any smaller baskets than I did for the large box, and while the small box works it seems less worth the effort.
