3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Personal Portable Spot Cooler
Here a smaller version of from my last version of air conditioner.
do check it out its really cool and TRENDY
haha its really portable all you need to do is charge and go.
because the ice stored in it will last and stay frozen with only a fraction of melting for hours! then just pop it out. and turn it on.Its really great and super portable anywhere everywhere.
So far this is the coolest! haha..
DONT underestimate this thing.. it produces up to 108CFMs under only 7.2v that will blow you down for 2 straight hours. that is 50mins for cool and rest for fan LOL. haha hope you guys will like this. thanks for the figure! you know who you are.
Step 1Getting parts and CUTTING!
Heres what you need,
styrofoam board,a firm container, any battery source(rechargeables..go green!)
a pc case fan some cardboard and some time.
First, insulate the container by having walls of the styrofoam at all sides. all you need is Cut here and there and finally place a thin layer of plastic to contain water and make it leak proof.
65 comments
1-40 of 65next »
May 16, 2012. 10:17 AMsharadholani says:
How to attach the fan to it? how to give it support?
Jul 10, 2008. 6:02 PMDipankar says:
Very cool man, Why didn't I think of this before, but the name is misleading it is an air cooler and not an air conditioner.
Jan 25, 2012. 3:39 PMeyeintheskyakagod says:
anything which changes the state of the air whether that be temperature or humidity is conditining that air so i am sorry to say but it is an air CONDITIONER
Jul 11, 2008. 5:31 AMDipankar says:
Yeh.....Personal spot cooler is more like it.
Apr 28, 2009. 3:31 AMjovenhatsjr says:
Can you kindly show how is it wired, i mean the power from batteries , am really poor in electricity but i really love the innovation. I've tried to make one but the batteries is becoming increasingly hot as i switch on .
Nov 28, 2009. 8:56 PM68autobug says:
it sounds like you are shorting a battery or batteries which will overheat the batteries...
make sure you have all the positive+ terminals red wires hooked together
and all the negative- black wires hooked together
just connect up to the fan...  if the fan blows the wrong way
just reverse the wires to the fan....
You can place a switch in either wire...  just cut a wire and connect to a switch... so the power goes thru the switch....
I have a 1968 VW beetle without air con...
this looks like a sure way to keep it cool during the summer months...
cheers
LEE   VK2LEE   in Australia
Jul 18, 2011. 4:09 AMtech53 says:
Yay for HAMS!!!
DE KF5EGM EM15gp
Aug 11, 2010. 6:21 PM_Scratch_ says:
(removed by author or community request)
Dec 2, 2010. 8:53 PMtinstructable says:
Electronics only draw the power in amperages they need. A car battery would not hurt the fan at all. You could hook a fan like this up to 400 car batteries wired in parallel and nothing fancy would happen other than that fan would be going for a long time. If you wired up 400 car batteries in series, you would definitely obliterate the fan. So yes.
Aug 6, 2011. 7:40 AMdevilmaycry says:
Yeah right!!! i had xbox360 2 in 1 fan and i hooked it up with 2 x 18 v batteries and suddenly the fans exploded and the smoke came out!
Aug 6, 2011. 1:58 PMtinstructable says:
Wired in series, or parallel? You probably over-volted it. 12v is the normal rating for fans like that, so 1 18v battery probably destroyed it. I am right, go look it up.
Oct 19, 2010. 4:32 PMElectroinnovation says:
haha well i should try hooking up a car battery to my air conditioner...i used an old rc car motor LOL
May 2, 2011. 4:53 AMterrilein says:
I'm totally oblivious to the electronics aspect. Can someone please explain to/show me how the fan is attached to the batteries???
Mar 12, 2011. 6:42 AMashashank says:
couldnt 1 simply use a cellphone charger to power the fan?
Mar 12, 2011. 6:41 AMashashank says:
Jul 12, 2010. 3:13 PMmarcusm73 says:
how about adding salt to the ice water to drop the temp even more.
Nov 14, 2010. 7:47 AMMoonlight27 says:
I agree...
Jul 12, 2010. 8:11 AMwingl says:
This seems like a great project. A possibility is to wire it to power off a USB port. Any possibility to explain how this could be done?
Oct 19, 2010. 4:34 PMElectroinnovation says:
yea thats easy just get an old usb cable and cut it open. I would test the wires to see which is the positive and negetive because i forget. the 3 volts from a usb cable would be enough to power it but it would not be very powerful.
Aug 17, 2010. 3:06 AMjvan0907 says:
Could it be wired to 5v eg usb 500 mah?
Jul 15, 2010. 6:54 AMducktape100 says:
what kind of box are you youing
Jul 14, 2010. 5:01 AMnutsandbolts_64 says:
doubles as a swamp cooler lol
Jul 12, 2010. 3:17 PMicedude007 says:
Nice instructable (: I'm going to try this and power it with a usb port. Knowing your in singapore was helpful as it also gets very humid here in Hong Kong. Thanks man (:
Jul 9, 2010. 11:39 PMthe dudemaster says:
you know if you changed the innards up a bit it might work better. . . i would try this but i just don't have the time before i go on vacation. . . just take a food can (after using the food and washing the can out would probably be preferable) and drill some holes in it below the preferred ice level and put it directly below the fan and seal any gaps . . . .this would probably work better with just ice instead of ice water. . . i don't know if it would work but if anyone could find the time to try it it wouldn't hurt. . .
Jul 12, 2010. 11:28 AMmikemmcmeans says:
pc fans move alot of air at low pressure (opposite of an air compressor) the fan would not be able to push enough air under the water
Jul 11, 2010. 7:51 AMendolith says:
Put copper pipes in the ice water for the air to flow through, like a radiator
May 25, 2010. 9:15 PMchecho5123 says:
 Hey man one question, which method works better, using the radiator like u did in the big one or just using the cold air that the watter gives off?? i know the small one probably cools less because of the size but which method works better overall??
Feb 4, 2010. 6:44 PMPretty Idiot Productions says:
This is great.. I think i'm gonna use the freezable ice packs in the cooler instead of ice and water. When they thaw out, i'll just throw them back in the freezer and switch 'em with new ones.
Jul 13, 2008. 3:12 PMBridel568 says:
dude drop the 1.5v just use 2 or 3 9v`s they make rechargeable 1s but I don't know were to get them. but wow! the fan really has a kick. I got the tip of my finger in it(it really hurt) but thankfully it wasn't my whole finger. yes it maybe a 12v fan but I connected 2 new 9v`s and a used 9v and man does this cool you off it might make ur acp work better
Nov 28, 2009. 8:49 PM68autobug says:
Use 9 Volt batteries in Parallel so its still 9 volts..
the more You use the longer they will last...
and rechargeable ones would be excellent...
just have all the Positive+ terminals hooked together
and all the Negative- terminals together
all equals 9 VOLTS...
Lee   VK2LEE
Jul 31, 2009. 12:47 PMReCreate says:
i once over powered it with about 60 Volts worth of 9V batteries before XD
Oct 14, 2008. 4:25 PMjunits15 says:
try putting some dry ice in it it will be alot cooler and last alot longer it is realy cheap if u know where to look!
Oct 28, 2008. 6:24 AMnolte919 says:
soooooo... where do you look for cheap dry ice? Inquiring minds want to know.
Oct 14, 2009. 2:33 PMZaphod Beeblebrox says:
i seed it at grocereys storeses sometimeses........
Oct 28, 2008. 2:04 PMjunits15 says:
well that really depends on where u live and your local laws ect. ANYWAY you have to try and find a local distributer near you because dry ice costs ALOT more when shipped, because you have to pay for the dry ice that subliminates while being shipped. (the ice that turns into a gas during shipping has to be paied extra for)and sometime gas dirstributers will sell it, because dry ice's only ingredient is co2. and usually the cost of dry ice is somewere between $1-2 per pound.
Jun 25, 2009. 12:58 AMhughscott5 says:
You should check local super markets, I used to work at one and they usually have it on hand in case of a power outage, to keep the frozen food from going bad. The one near me sells it for $1 per pound. If you do use dry ice, make sure you are in a well ventilated room. As junits15 said it's just co2, too much of it can cause oxygen to displace, which can lead to sickness or even suffocation. You should be OK with a window open and a fan blowing. Great Instructable by the way!!
Jun 25, 2009. 1:53 PMjunits15 says:
Really? Thats good to know, what brand store it the one that you are talking about. So I would just ask someone behind the counter?
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:farhanians
