Ultra-cheap router lift
Though the real solution for a router table involves a lift kit, there's little point in spending $200 to tie up my good Dewalt router for possibly infrequent use.. A sale at Harbor Freight netted me a 1.75hp plunge router for $40, and Amazon delivered me a Rousseau Router Base Plate for $39. All that was left was to make my router lift on the cheap. The only visible damage I'll do to the router is two small (1/16) holes drilled into the motor assembly near the depth stop.
This is not as robust as a lift kit with a professional grade router, but can be assembled for under $100 (As low as $70. One commentor has noted that HF also sells an identical plate for about $20 +$7 S&H.)
(Note: As usual, this will probably void your warranty.)
Step 1Design Overview
Design Overview
The plan is to replace this fixed, rudimentary height adjuster with a setup that will compress the plunge router motor (and bit) upward toward it's base with accurate height adjustments. Instead of the height adjustment preventing compression beyond the nut, we'll use it to crank the motor upward like a normal lift system.
30 comments
Jan 4, 2010. 5:29 PMscavanger says:
 Nice instructable.
I did something very similar with my Porter Cable router a few years ago.
Some of you may find it helpful so I posted a link. Not all the nice detail that Vetus posted here, but a few photos on my blog you may find useful.
Hope it gives you a few more ideas to work with.
Homemade router lift mechanism
Aug 10, 2011. 4:50 AMscavanger says:
The above link is broken I'm Just updating it here: Homemade Router Lift Mechanism For a 3HP Porter-Cable
Some great idea here, thanks to all for sharing.
Jun 12, 2011. 11:37 PMpfred2 says:
If you'd just bought the Hitachi you'd have gotten a lift accessory thrown in the deal. At least I did. Look familiar?
http://www.comparestoreprices.co.uk/images/hi/hitachi-m12v.jpg
The lift is the knob sticking up on the left. That and you'd have gotten a full power balanced tool too.
Jun 13, 2011. 2:01 PMpfred2 says:
I think the old model is discontinued today. I paid $120 for mine years ago. The big ugly green machine. It is nice though electronic soft start, variable speed, smooth, gobs of power. It even came with a decent 1/2" straight carbide bit just to get you started. I'm not sure if they all came with the lift accessory or not but mine did. When I was in the market for a good tool it was the cheapest "real" 1/2" plunge router going.
The biggest complaint anyone ever had about them was the dumb base ears to hold guides stopped you from running the largest bits. But some folks just knocked those ears off. You could almost buy 3 M12Vs for what most other routers in its class cost.
I haven't always been the kindest to mine either
http://img263.imageshack.us/img263/3937/hitachilog.jpg
Feb 19, 2011. 8:28 PMdyril says:
Thanks for this Instructable. Being new to woodworking I ended up getting a DeWalt 618PK but then shortly kicked myself for not having researched router-table-friendly routers. So I just modded the 618's plunge base like so (how lucky that I could find a nice spot to drill holes). Remove unnecessary things such as springs and plastic casing. Cut a 3/8"-16 socket-head bolt and graft onto another sawed-off bolt, joining with a connector nut. I couldn't find teenuts, so I carefully tapped the sliding portion (using the bolt).
Jun 3, 2011. 6:50 AMair-v says:
Hello,
I've got POF1400 Bosch Router, and i would try your tips. Do you think it will be possible ?
Thanks
Oct 9, 2010. 6:01 PMdrab84 says:
Thanks for this, I have the exact router you do, and wasn't about to spend another 100 bucks for a lift system. You've saved me a lot of crawling under the table.
Dec 15, 2010. 5:11 AMdrab84 says:
Sorry it took so long to get back to you. Project got delayed, but it does work great! I used the JB Weld method on the tee nut (mostly since I broke a drill bit the other way), and it worked, but was hard to line up. All in all it works great, and much much cheaper than the alternative. Thanks again!
Aug 30, 2010. 3:26 AMpatrick kane says:
looks great
Jul 9, 2009. 8:03 AMgarymuto says:
Cool set up. I got a router raizer kit for ~$20 at Rockler on clearance and thought it was a steal since it retailed for $90. It has a few more novelties like a dust cap for the hole in the router plate and an Z shaped allen wrench (speed wrench) with a handle and a small magnet to remove the dust cap when adjusting. Not bad for $20 until I see that I could' ve done it for about $8. I set up my 3-1/2 HP Craftsman router and it works well. I thought about doing this to my P-C 690 but only had one kit and the craftsman is so bulky I chose that one for the Raizer. Maybe I'll set up my 690 so I can have 2 routers with above table adjustment.
Jul 31, 2008. 10:26 PMJillB says:
thanks Vestus. Any chance of posting photos / pictures of the hardware used at the base? We don't seem to have anything like it in Australia regards, Jill
Jul 31, 2008. 11:17 PMJillB says:
Found them - they are referred to here as knock down fittings for furniture
http://www.timbecon.com.au/products/knock-down-fittings-433_1.aspx
Jill
Jul 31, 2008. 6:22 PMJillB says:
Nicely done, Vesta, and great to hear it works well. I want to do a similiar thing to my Hitachi TR-12 router, which is almost idential to yours. Could you please clarify what you have done at the base? I don't understand how the allen key arrangement is done, and what keeps the router body from sliding back down the slide posts. regards, Jill
Jan 6, 2008. 6:23 PMJiminPA says:
To make it even better, Harbor Freight has a very similar router plate for--last time I checked--around $20. Check the online catalog.
Dec 27, 2007. 5:13 PMauntnana says:
Just what I've been looking for! Great instructable!The head of my connector bolt just happened to be the exact same diameter as the depth adjustment socket so couldn't countersink. I used a spade bit to trim the socket down a bit then grinded smooth and flat with a Dremel tool so it would fit under the base. Have to be careful and slow so that the trimming is even and level. Info could be just a teensy bit clearer on what's to be lubed and what's to be locktite-d. Also had to use JB Weld as the nails didn't cut it. Great job!
Dec 12, 2007. 6:01 PMleonmcd says:
How hard is it to change bits? Do you just crank for a long time or do you pop the router and plate out of the table?
Dec 1, 2007. 4:41 PMsysiphus says:
Awesome idea. I have a cheap plunge router that has been sitting unused due to a design flaw. Reading this, I suddenly see how I can have it back in service, work around/correct the design flaw, and have the router table I've been craving. Wow. This is exactly why I love Instructables. Thank you for posting this!
Nov 29, 2007. 9:41 PMSpritegeezer says:
I like the idea. Actually I use my good router on my router table as I can't do a thing with it free hand. One question. Why did you choose to us a plunge router? Wouldn't a standard router work just as well without the mods? Is it to make adjustments easier?
Nov 30, 2007. 11:15 AMSpritegeezer says:
That was my assumption. I just wanted to be certain I wasn't missing something else. Thanks!
Nov 30, 2007. 4:59 AMlochlanmasters says:
When he is adjusting the height of the router in the table he is plunging up and down. If he hadn't used a plunge router he would have had to fabricate an up and down slide.
Nov 25, 2007. 2:21 PMbleachworthy says:
good job!not many people modify their tools like this, good craftsmanship!
Nov 25, 2007. 11:50 AMGorillazMiko says:
awesome instructable :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Vestus
