3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultra-cheap router lift
Step 5Construct the compression bolt.
(Final view, after assembly)
-With the base still separate, attach the Tee nut to the motor flange. (I drilled two 1/16 holes and hammered two brass nails through the Tee nut flange into the motor flange. JB weld may work just as well.
-Join the 1/4-20 threaded rod to the connector bolt projecting through the base with the coupling nut.
-Reassemble the base to the motor*, with the threaded rod through the Tee nut to compress the motor towards the base. (*Only replace the plunge springs in the tube nearest the new compression bolt, as both are unnecessary with it in an inverted position under the table.)
The complete assembly order should be: Phenolic plate, Connector bolt, Router base, Coupling nut, Motor flange, Tee nut. (Skip the washer I added, it's unnecessary once under tension.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Vestus
