3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultra low cost solar-rechargeable persistence of vision display
This device produces a bright and eye catching display to write text and small images through the air. It uses under £2 (approx $3.20 US at the time of writing) of parts, and is a nice little weekend project to impress your friends and family.
It uses the PIC10F206 from microchip, the tiniest microcontroller I have ever seen. Its advantages are that its small, fast and reliable and has a built in RC clock so there is no need to mess around with crystals and resonators. Its downside is that it only has 6 pins, 2 of which are taken up by power and ground! The way to get around this is to use shift registers to give yourself more outputs as you will see in the next few pages.
It also uses a small rechargeable battery and solar cell, which are typically pricey items, but currently there is a huge flood of keyring-sized cheap solar powered torches from china, which can be bought from the pound shop in England, or had very cheaply on eBay. I have even seen these for sale in petrol stations.
Step 1You will need:
You will need:
Materials:
A solar powered keyring torch
A 'wooden plant label' or other suitable handle.
Small scraps of wire
HEF4794 shift register in an SOIC package
10F206 in an SOT23-6 package
8x Surface mount LEDs of your choice - I used blue in 1206 package
8x Resistors of your choice - I used 320 ohms in 0603 package
1x 10k resistor in an 0603 package
1x 68nF capacitor in an 003 package
Copper-clad board
Tools:
A drill or veroboard cutter
Needle file (or some method of making square holes)
Soldering iron with a fine tip, preferably temperature controlled
Thin solder
Desoldering braid or a way to remove excess solder from the torch PCB
Tweezers for placing small components
Glue gun or double sided tape
PIC programmer that supports PIC10F206 - I used the PICKIT2
Optional:
Flux
Hot air soldering station
Method of producing PCBs
Cleaning alcohol -methylated spirit or isopropanol will do
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pyromaniac303
