I have had a couple of these inexpensive bug-zappers that can run off battery or through a plug-in power supply.
These things work pretty good, until the UV fluorescent bulb burns out!
I seem to get maybe 2 years out of these bulbs and then finding a replacement bulb can be tricky and expensive!
So, when my father was looking for an alternative to the replacement black fluorescent bulb for $12, I suggested UV LEDS from Radio Shack.
These UV LEDs have several advantages;
1) easy to get and fairly cheap and should never burn out!
(Radio Shack Catalog #: 276-014 $1.69 for a pack of 2),
2) they use less power then the bulb, so the battery should last longer, GREEN!
3) they don't contain any mercury like the fluorescent bulb does, GREENER!
My father and i had two different types of Zappers that had the same type of dead fluorescent bulb. Since they come apart quite differently we went about putting the LEDs in there differently too. I've got more pictures of my modification so i'll use that one as the example.
You Will Need
2 packs of 2 Ultraviolet LEDs from Radio Shack, Catalog #276-014
1 pack of 68 ohm 1/2W 5% Carbon Film Resistor pk/5, Catalog #: 271-1106
1 Battery operated Bug Zapper, otherwise there might not be low voltage DC inside to drive the UV LEDs.
also the basic soldering equipment including
Soldering pencil,
Solder,
Wire Cutters,
Black Electrical tape,
Heat shrink tubing would be nice
Remove these ads by
Signing UpStep 1Safety First!
remember this:
1: There can be high voltage when it's unplugged, or even when it's off!
Build a shorting rod of some sorts. I used a bamboo skewer and put a couple inches of Aluminum tape at the end. I tap it against the screen to see if it's hot, and also to short it out after I shut it off again.
2: Remove the battery leads, and make sure they don't accidentally touch the battery contacts again. But you will have to power it up sometime...
3: Be Careful! This stuff can hurt you. Even if the voltage itself doesn't cause real harm, and it might, you could get hurt by falling off the chair or hitting your arm against something as it snaps back. NO FUN. Don't play with things you shouldn't.
9
comments
Add Comment
dark sponge
says:
aristide202
says:
dark sponge
says:
thearchitect
says:
Add Comment
