Introduction: Ultrabright LED Emergency Lamp (Rechargeable!)
Step 1: Gathering Tools & Materials
Since this was a "Macgyver" type of assembly, the parts needed to come from recycled parts. Most of them came from my scrap radio on the other hand my 3W LED came from an old 220v LED Bulb. Materials: - 3W Ultrabright LED (Radioshack or AC LED Bulbs) - Red LED Indicator (Recycled Parts) - BL-5C Nokia Battery (Old Nokia Phone) - 1N4007 Recitifer Diode (Recycled Parts) - 470 ohm Resistor (Radioshack or Recycled Parts) - On/ Off switch (Recycled Parts) - DC Power Jack (Recycled Parts) - Scotch Mounting Strips Tools & Equipment: - Soldering Iron - Hot Glue Gun - Leatherman - Portable Drill
Step 2: Scavenging for Parts
- Broken Radios, CFL Bulbs, Toys
- Busted Flashlights, AC LED Bulbs
- Old Nokia Phones (I have no use for my Nokia)
- Home Inventory
- Resistors, Switches, DC Plugs, LED Indicators
- Some Working High Powered LEDs (cuz it's in series)
- Li-Ion Batteries (ex. BL-5C)
- Glass Jar, Utility Knife, Tape, Gluegun
Step 3: Hot Glue the Parts in Place
1st.) Drill two holes (6mm) for your "Charger's Plug" and for the "Slider Switch" 2nd.) Solder two wires to your BL-5C's positive and negative terminals. 3rd.) Hot glue everything In place! 4th.) Use a small strip of Scotch's mounting pads to mount the 3W LED (BTW, they don't melt)Want To Make It Waterproof? Don't drill holes, just hot glue the socket and switch inside the jar/ lid. Just unscrew the lid to charge!
Step 4: Optional: Adding a USB Lithium USB Charger
Trickle charging isn't the best way to charge lithium batteries. When overcharged, they have the tendency to explode, that is if you forget to unplug it for an hour. If you plan to use this in long terms, I would recommend to attach this module for safety. To install this circuit, simply connect the Bat+ and Bat- parallel to the battery's respective terminals. You can buy it here for $1.70! "1A Lithium Battery Charging Module - Blue" Red Light = Charging Green Light = Fully Charged
Step 5: The Schematic Diagram
One thing you must know BL-5C batteries, they have a voltage protection circuit inside them. You can trickle charge these batteries at 5 volts, just limit the charge time for an hour. If you want to take precaution, there are Lithium battery chargers available out there.How Does The Circuit Work? This is a very simple circuit that doesn't require circuit boards. All it does is trickle charge the battery, a rectifier diode was added to prevent the backflow of current. I added a LED charging indicator just to show whether the jar is charging or not.
Step 6: Solder Everything in Place
Just follow the circuit diagram and you are good to go! A perf board isn't necessary but if you insist then go ahead.
Step 7: Charge Testing
Cool! If you've done it right, the jar should glow red when the charging. You can also charge this with my previous project: the "DIY Portable USB Solar Charger".
Step 8: You're Done!
How about let's go camping!
Step 9: Dentita's Version
Dentita, a fellow instructable member, made his awesome version of the Jar.
Runner Up in the
Instructables Outdoor Projects Contest
Build My Lab Contest
Make It Glow Contest
