3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultralight Backpacking Stove Only 3/8oz. (video demo)
This stove has been made many times by many people. I have made several of them and I use it as part of my Ultralight Kitchen so I thought I would show how I do it.
Here is a link to my kitchen kit (http://www.instructables.com/id/4-34-oz-Ultra-light-Backpacking-Kitchen-video-de/)
The best fuel I have found for this stove is HEET - Gas-line Antifreeze & Water Remover. It is about $1.50 a pint and it is 99% methanol. You can get it almost anywhere, gas stations, supermarkets, parts stores. So if you are doing a long trek and you make stops in town to re-stock, you can always fuel up with no problem. As far as energy, 1 or 2 oz can usually boil 2 cups of water.
To use the stove, pour HEET in to the center section and light. Soon the methanol in the external chamber will vaporize and start to escape from the jet holes. These streams of vaporized methanol will ignite and will continue to burn until the fuel is gone. Below is a demo of this.
Step 1Gather Materials & Tools
To build this stove you will only need 2 aluminum cans. Usually I use a Guinness can for the bottom section and a coke can for the top and ring. I have found that the Guinness cans are a little heavier and that they stretch better. In this instruction I use 2 coke cans. If you decide to make this stove I would suggest using a Guinness can for the bottom.
The tools you will need are as follows:
To score and cut the cans:
  • Utility knife
  • Large "C" clamp
  • Razor blade
  • Various pieces of wood to be used as spacers.
To help with stretching the can;
  • Petroleum jelly
  • Small piece of plywood
To puncture the jet holes
  • 1 push-pin
  • hammer
104 comments
1-40 of 104next »
Jun 10, 2011. 4:32 AMprofjaykay42 says:
Instead of a JB weld and tape, I used a paper clip. Just thought that that would be a good cheap and simple alternative.
Feb 26, 2011. 2:31 AM.Hexx. says:
Can I make the stove a bit longer for more burn time?
Aug 17, 2010. 7:21 PMMatrix-technician says:
So do you just pour the fuel into the center hole?
May 27, 2010. 3:31 PM5tinkymouse says:
 12oz  guinness? or does it matter?
May 14, 2010. 5:45 AMRadd28 says:
Saples work better than the glue. One in the top about 3/16'' down and the same on the bottom but 3/16'' up. Use needle nose pliers to compress the legs of the staples to flaten  them after you staple and then just bend the staple top to comform with the radius of the inner circle. You are done and it's permanent and you don't have to mix the epoxy and you don't have to wait for it to dry.
Jun 28, 2009. 12:17 PMtrf says:
A small hint....i have built 1 of these and a real nuisance in it is the spill of the fuel.It can leak alot through the jet ports. What i have done is added cotton swabs and packed them in.Pour the fuel into the cotton and it keeps it contained and it works just as well.
May 10, 2010. 12:01 PMfn06afranci says:
yeah i had the same problem so i cut off the bottom off another can and used it as a cap to stop it from leaking and to smother it to put it out
Dec 6, 2009. 12:50 PMzimitt says:
Thanks for this twist on the can stove. I love the open pit system better than the preheating type. I made mine without the epoxy. I cut the interior wall without cutting the can up the side so I was left with a ring 1.5" high. I then folded the ring to create a tuck to make it fit in the grove in the can bottom. This eliminated the need for gluing the edges. Then the whole thing fit together so perfectly and snug that I didnt need any further glue thanks to your exact measurements.
Thanks again for a great instructable.
Oct 28, 2009. 6:44 PMjunits15 says:
Where did you buy your heet?
as you can see here www.instructables.com/community/i-have-to-be-18-to-buy-heet/  i had a problem.
Oct 29, 2009. 1:21 PMjunits15 says:
I think I'll have to do that, because i have bought acetone and al sorts of gluees at lowes without problems, I dont think they will wory to much about denatured alcohol.  I mean its denatured so I'm not planning on drinking any of that any time soon.
Sep 28, 2009. 4:00 PMZem says:
Cool! I have one question though, wouldn't the stove warp a bit with the heat?
Sep 28, 2009. 5:27 PMZem says:
Awesome, thanks!
Jun 26, 2009. 6:36 PMchopstx says:
i noticed the can is un opened in the last pic., how is that possible?
Jun 26, 2009. 8:38 PMHands Without Shadows says:
The can was simply never opened......
Jun 27, 2009. 3:00 PMchopstx says:
oh. whoops. lol
Sep 12, 2009. 7:36 AMjmeister15 says:
Thats why it "gets messy".
Sep 12, 2009. 3:19 PMchopstx says:
Yeah. Dumb me.
Sep 12, 2009. 7:51 AMjmeister15 says:
Could you make a grill by putting a cookie cooling sheet thing over a few of these?
Jun 29, 2009. 2:22 PMbegnbezzy says:
how cool whats the health risk in using HEET to cook on ?
Jul 5, 2009. 4:13 PMDoko says:
HEET is nearly pure Methanol. If you just burn it, it is OK. But Methanol IS A VERY POWERFULL POISON. IF INGESTED OR ABSORBED BY THE SKIN, LITLE AMOUNTS CAN CAUSE BLINDNESS AND MANY TYPES OF NEUROLOGICAL DAMAGES. An ingestion of just 10ml (10 cubic centimeters) will cause irreversible blindness in 50% of the population if not treated fast. In my oppinion, it is not a smart idea to mix methanol and anything used to prepare food (mainly if there are kids arround). The risk of contamination and/or incidental ingestion is just too big. I don't know if it will work in this case, but ethanol is almost harmless and generates nearly the same amount of heat.
Jul 12, 2009. 5:38 AMAlgor_Langeaux says:
If the issue is methanol, one could simply replace it with ethanol. Everclear (or another potable GNS) is available for sale everywhere in the US except Pennsylvania, Washington, Oregon, and California, and would work as well as Heet.
Jul 12, 2009. 8:24 PMDoko says:
Yes, Ethanol is a much safer fuel. It is so safe that I love to ingest some small amounts of it (beer is about 5% Ethanol...). I didn't mention earlier, but the main problem with Methanol is acidental ingestion. Ethanol and Methanol have about the same taste, and the first is component of all alcoholic beverages. People will not drink Coleman fuel, gas or kerosene. The taste and smell of this things are horrible and easy to perceive. But people will drink Methanol and think that there is nothing wrong. Think about a packpac, it is basically a big bag where a lot of things from food to clothes go mixed and shaking in your back for hours. The possibility of fuel leaking from the fuel bottle is very real, mainly if you use an improper bottle (I usually have simple water bottles for fuel). Imagine that some leaked Methanol soak slightly your bread or your dried meat. The taste of this mix is not so bad, the temptation of ingesting it anyway is not small for most of the people... Another posibility is that someone can get confused about botles and drink fuel thinking that it is vodka or some sort of moonshine. A minimum amout of Methanol swallowed will do horrible things in the body if not treated in the next 4 hours (and remember, you can be in a wild area very far from rescue). I live in Brazil and here there is a distilled beverage produced from suggarcane that has a taste very similar with pure Methanol, the Cachassa. Due to this, every year there are hundreds of cases of people poisoned by acidental ingestion of Methanol (mainly alcoholics that find bottles with methanol or people that try to make "moonshine cachassa" and end up distiling Methanol), any brazilian emergency doctor is familiar with this situation. So, just to be in the safe side, go with Ethanol. You don't have to worry if there is fuel leakages or even if any stupid friend prepare a drink with your fuel...
Sep 5, 2009. 5:16 PMbaneat says:
You know your stuff. I ask if naphtha (coleman's) will work in one of these stoves?
Jun 29, 2009. 4:11 PMSabata says:
I can't say for sure, but the risks should be minimal. HEET is simply methanol and people cook on alcohol stoves all over the world. Many boats have alcohol stoves as well. AAMOF, look at a bottle of denatured or solvent alcohol in the paint section of your local hardware store or home improvement center. They often say for use in marine and/or camp stoves on the label.
Jun 30, 2009. 7:53 AMbegnbezzy says:
OTAY seems clear tryin it Flea Mkts seem have overstock on the HEET see if I can find larger can to try. Anyone ever try cooking w different fuels on the ole fashion campstove by coleman ? You know the kind you pump the canister w a plunger then lite?
Jun 29, 2009. 4:16 PMSabata says:
One more thing. Here is a list of international fuel names for reference.
http://members.iinet.net.au/~mbuckler/fuel/index.shtml
Jun 30, 2009. 3:04 AMcountable says:
Cooking on methanol is no problem at all. Drinking it, however, is.
May 17, 2011. 4:56 AMKelticpaddler says:
Oh cr*p! I used to fire breathe with methanol!!
NOW you tell me!!
May 18, 2011. 10:12 AMcountable says:
If you used it for firebreathing, I can't imagine you swallowed much of it (it probably tasted foul anyway).
Most firebreathers I knew drank milk before they started, to line their stomaches.
Jul 27, 2009. 12:51 AMjeradhoy424 says:
Is the apoxy neccesary? Could it work fine without using it
Sep 5, 2009. 5:14 PMbaneat says:
Not needed, I used superglue
Sep 5, 2009. 3:26 PMWillmeister says:
no heet is methanol or how ever u spell that word and rubbing alcohol is 70-99 percent that alcohol that starts with an I methanol can make u go blind
1-40 of 104next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:thatoneguydavid
