3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultralight Backpacking Stove Only 3/8oz. (video demo)
Step 7Assembly of the Ring
Glue the ring together:
1. Do a dry fit to see that the ring links properly and that it fits in to the groove in the bottom section
2. Mix a small amount of JB weld epoxy adhesive and apply it to the end of the ring strip.
3. Link the ring together and tape it while you move to the next step.
1 comment
May 14, 2010. 5:45 AMRadd28 says:
Saples work better than the glue. One in the top about 3/16'' down and the same on the bottom but 3/16'' up. Use needle nose pliers to compress the legs of the staples to flaten  them after you staple and then just bend the staple top to comform with the radius of the inner circle. You are done and it's permanent and you don't have to mix the epoxy and you don't have to wait for it to dry.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:thatoneguydavid
