Introduction: Ultrasonic Motion Detector Light Starter : THE WATCHER
Picture of Ultrasonic Motion Detector Light Starter : THE WATCHER
this is simple motion detector with ultrasonic sensor. It detects the person and trigger the relay which leads to light for 30 seconds for each trigger.
Step 1: the Components
Picture of  the Components
for THE WATCHER
1. arduino
2. 5v relay
3. ultrasonic sensor
4. usb wire
5. plastic box
6. 5v power supply
these components are required for the THE WATCHER
Step 2: The Coding
Picture of The Coding
In this project coding is very easy. You can download the code for the link below and you have to change the distance as your room. keep distance 5 less than the length of the room.
here is the link for my video >>>> https://youtu.be/iMs63-4nVs8 <<<<
Step 3: Connections
Picture of Connections
the ultrasonic sensor connected as
trig pin -> pin 8
echo pin -> pin 7
vcc- > 5v pin
gdd -> gdd
the relay connections
signal pin (INT) -> pin 3
vcc-> vin
gdd to gdd
power supply to arduino by the usb cable and mobile charger 5v 1amp
*the simulation software ultrasonic sensor has only 3 pin but i have used hc-sr04 which has 4 pin so connect the ultrasonic sensor as i describe above to arduino pin.
DIY Hacks and How Tos (author)2016-07-05
Cool Sensor project.
About This Instructable
315views
4favorites
Bio: hey, this is Neel. and i like to play with electronics to make world better place.
More by neeld6:Home Security System (AEGIS)Home Automation Via Bluetooth by Phone With ArduinoUltrasonic motion detector light starter : THE WATCHER
Add instructable to:
