Ultrasonic Sensor Range Finder
Published
Introduction: Ultrasonic Sensor Range Finder
Introduction: Ultrasonic Range Finder Using Arduino. Ultrasonic Range Finder is a simple method of calculating distance from an obstacle from a distance without any physical contact. It employs an ultrasonic distance sensor which uses sound pulses to measure distance.
Step 1: HC Sr04 (ultrasonic Sensor)
What Is Sensor ?
A sensor is a device, module, or subsystem whose purpose is to detect events or changes in its environment and send the information to other electronics
Types of Sensors
1.The most frequently used different types of sensors are classified based on the quantities such as
2.Electric current or Potential or Magnetic or Radio sensors
3.Humidity sensor
4.Fluid velocity or Flow sensors
5.Pressure sensors
6.Thermal or Heat or Temperature sensors
7.Proximity sensors
8.Optical sensors
9.Position sensors
!!!!!!! ULTRASONIC SENSOR IS A PROXIMITY SENSOR !!!!!!!!
An Ultrasonic sensor is a device that can measure the distance to an object by using sound waves. It measures distance by sending out a sound wave at a specific frequency and listening for that sound wave to bounce back.
Step 2: Bill of Materials
1.Arduino Uno
2.Ultrasonic sensor - HC sr04
3.Batterys 3.7V
4.leds
5.Breadboard
6.Jumper cables
Step 3: Schematics and Connection
connections
1.trig PIN to PIN 12
2.echo PIN to PIN 11
3.LED (+ve) to PIN 7
4.Connect Battery (+ve to VCC , -ve to GND)
Step 4: Code
1.Install ultrasonic libraries
CLICK HERE for librarie
2.Upload The code
CLICK HERE for code
Step 5: !!!! Hope You Enjoy This Instructables!!!!!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    Hi,
    Great project ! with nice code.
    I'm not a C++ programmer but your code seems to be non blocking Function.
    Is it the case ?
    Cheer
