Ultrasonic Sensor Test Plan for Chicken Coop Door (CL)
124
Posted
Introduction: Ultrasonic Sensor Test Plan for Chicken Coop Door (CL)
The goal of the following test plan on a ultrasonic or sonar sensor is to detect if the door of the chicken coop is closed. In this Intsructable you will learn step by step how to detect if a door is opened or closed. Below are instructions on how to properly wire the ultrasonic sensor to an Arduino UNO. Then you will learn how to program it, calibrate it, and test it out!
Step 1: Gathering Materials
In order to wire the sonar sensor you will need to lay out the materials listed below:
    - Breadboard
    - Ultrasonic Sensor
    - USB cable
    - Laptop
    - wires
    - Arduino Uno microcontroller
    - Arduino
    -LEDs
    Step 2: Wiring the Sensor
    After you have successfully gathered all the materials you might wonder what's next? In this step you will connect the sonar sensor to the Arduino Uno microcrontroller. The picture depicts the different ports of the sonar sensor. You should follow the diagram and connect the wires as such:
    Connect wires from...
    GND to GROUND
    Echo to pin 10 (INPUT)
    VCC to 5V
    Trig to pin 11 (OUTPUT)
    Step 3: Programming Arduino
    Now that you have wired the sonar sensor to the Arduino Uno microcontroller, connect it to your laptop using the USB cable. Open Arduino and create a new file. This step will help you program, verify, and upload your code onto the microcontroller in order to start measuring distances! You can either copy the following code directly onto your file or play around with it. The pins in the code may vary from the ones you decide to use so keep that in mind because it might cause your code not to run.
    int trig = 11; // Initializes variable trig and sets it to pin 11
    int echo = 10; // Initializes variable echo and sets it to pin 10
    float duration; //Creates float variable
    void setup() { //Starts code
    // put your setup code here, to run once:
    pinMode(trig, OUTPUT); //makes variable trig an output
    pinMode(echo, INPUT); // makes variable echo an input
    Serial.begin(9600);
    void loop() { // put your main code here, to run repeatedly:
    digitalWrite(trig, LOW); //sets variable trig as low
    delayMicroseconds(2); // Delays for 2 microseconds
    digitalWrite(trig, HIGH); // Sets variable trig to high
    delayMicroseconds(10); // Delays for 10 microseconds
    duration = pulseIn (echo, HIGH); // this sets the “duration” as the time it takes the pulse to be
    received.
    delay(250); // Delays for 250 microseconds
    Serial.println(duration); // Prints output for variable called duration
    Step 4: Recording the Calibration Data
    The next step after uploading your code is to test it out and see if it is functional. Open terminal from Arduino. You will notice that various numbers pop up. The closer you are changes how big the numbers are. These values are to be made into inches.
    The function in the code "pulseln()" triggers a pulse which is then detected. It uses the speed of sound and will be converted to distance using time.
    Insert this code into your main loop:
    long duration, inches, cm;
    Step 5: After Calibrating
    We will now work with LEDs to show when the door is open or closed.
    Obtain two different color LEDs. One of these will be set to light up when the door is opened and the other will light when the door is fully closed.
    Image source: https://www.instructables.com/id/How-to-make-A-light-up-distance-sensor/
    • Epilog Challenge 9
      Epilog Challenge 9
    • Gluten Free Challenge
    That's a neat idea, I'd love to see it once the project is done :)
