Introduction: Ultrasonic Gesture Based TV Remote Control
This is a fairly simple project that is designed to introduce key components to a new Arduino user. I created this in a few hours of tinkering using existing Arduino libraries and a SainSmart starter kit. Real world applications could include users who have difficulty using remote controls or are in food preparation areas etc.
The IR code is configured for use with a Sony TV, the library is courtesy of http://www.righto.com/2009/08/multi-protocol-infrared-remote-library.html
I also took some IR codes for the TV from here: http://www.openremote.org/pages/viewpage.action?pageId=15532260
Everything else uses the built in Arduino functions and libraries or my own work.
Step 1: Materials
You will need:
1. An Arduino UNO.
2. An HC-SR04 ultrasonic module
3. An Infra-red LED
4. An appropriate resistor for your Infra-red LED (I used 220R but the signal is quite weak!)
5. An RGB LED (and resistors if they aren't built in).
6. A breadboard and wires.
Step 2: The Electronics
The configuration is straight forward.
1. Connect the IR LED to pin 3 via an appropriate resistor, and then connect the cathode to GND.
2. Connect the ultrasonic sensor to 5v and GND where the pins specify. Connect the trigger pin to pin 8 and the echo pin to 7. You can configure these pins in the sketch.
3. Connect the RGB LED to GND and pins 11 (red), 10 (green), 9 (blue). These pins are also configurable.
NOTE: Make sure your LED module has built in resistors or you will damage the LED.
Step 3: The Sketch
The following code should be uploaded to the Arduino.
/* Swipe Remote Control
This sketch uses an ultrasonic rangefinder to determine the user's gesture and outputs an IR signal to a sony TV based on the command given.
- High swipe (> 10in) = Channel Up
- Low swipe = Channel Down
- High hold (> 10in) = Volume Up
- Low hold = Volume Down
- Cover sensor (< 3in) = Turn On / Off
Created by Dan Nicholson.
This example code is in the public domain.
This code uses the IRremote library (https://github.com/shirriff/Arduino-IRremote)
#include <IRremote.h>
// Defines for control functions
#define CONTROL_CH 1 // Channel change
#define CONTROL_VOL 2 // Volume
#define CONTROL_POW 3 // Power
#define CONTROL_UP 1
#define CONTROL_DOWN -1
#define DIST_MAX 20 // Maximum distance in inches, anything above is ignored.
#define DIST_DOWN 10 // Threshold for up/down commands. If higher, command is "up". If lower, "down".
#define DIST_POW 3 // Threshold for power command, lower than = power on/off
// IR PIN
const int irPin = 3; // this is defined in the library, this var is just a reminder. CHANGING THIS WILL NOT CHANGE PIN IN LIBRARY
// 2 Pin Ping Sensor
const int pingPin = 8;
const int echoPin = 7;
// Confirmation LED Pins
const int led = 13; //internal LED for up/down debugging
const int ledR = 11;
const int ledG = 10;
const int ledB = 9;
// LED on timer
unsigned long timer;
// IR transmitter object
IRsend irsend;
// Power confirmation flag (needs two swipes to send signal)
boolean powerConfirmed = false;
void setup() {
// initialize serial communication and set pins
Serial.begin(9600);
pinMode(led, OUTPUT);
pinMode(ledR, OUTPUT);
pinMode(ledG, OUTPUT);
pinMode(ledB, OUTPUT);
pinMode(pingPin, OUTPUT);
pinMode(echoPin, INPUT);
timer = millis();
void loop()
// Serial.println(millis());
long duration, inches;
int value;
// Check for a reading
duration = doPing();
// Timer to confirm actions (currently only power)
if (timer && timer < (millis() - 5000) && (millis() > 5000))
Serial.println("timer reset");
timer = false;
digitalWrite(led, LOW);
setColor(0, 0, 0); // off
// convert the time into a distance
inches = microsecondsToInches(duration);
// If less than max inches away, act
if (inches < DIST_MAX)
// Debug output
Serial.print(inches);
Serial.println("in");
// If very close, it is a "power" signal
if (inches < DIST_POW)
Serial.println(timer);
// on or off
if (timer)
doIR(CONTROL_POW, 0);
timer = false;
delay(2000); // don't want to be sending this more than once. 2 second delay
else
Serial.println("power flag set");
timer = millis();
setColor(255,50,50);
delay(500);
else // is volume or channel
// Distance determines control direction
value = handleDist(inches);
// wait half a second
delay(300);
// check again, has hand disappeared?
if (microsecondsToInches(doPing()) > DIST_MAX)
doIR(CONTROL_CH, value); // swipe
else
// volume
int d = 500; // first delay is longer for single volume change
// repeat until hand is removed
while (inches < DIST_MAX)
value = handleDist(inches); // is up or down?
doIR(CONTROL_VOL, value); // fire off IR signal
delay(d); // wait
inches = microsecondsToInches(doPing()); // check for hand again
d = 100; // delays are shorter for quick multiple volume adjustment
delay(500); // this stops accidental channel change after volume adjustment
delay(50); // Short enough to detect all swipes.
* If distance is within threshold, mark as 'up' and turn on corresponding LED.
int handleDist(int inches)
if (inches > DIST_DOWN)
digitalWrite(led, HIGH);
return CONTROL_UP;
else
return CONTROL_DOWN;
* Fire off correct IR code
void doIR(int control, int val)
switch(control)
case CONTROL_POW:
// power
Serial.println("power on / off 0xa90");
for (int i = 0; i < 3; i++)
setColor(255, 0, 0);
irsend.sendSony(0xa90, 12); // Sony TV power code
delay(40);
break;
case CONTROL_CH:
setColor(0, 255, 0);
// output 'channel up / down' depending on val
if (val == CONTROL_UP)
irsend.sendSony(0x90, 12);
delay(40);
Serial.println("channel up 0xD00A");
else // down
irsend.sendSony(0x890, 12);
delay(40);
Serial.println("channel down 0x3002");
break;
case CONTROL_VOL:
setColor(0, 0, 255);
// output 'volume up / down' depending on val
irsend.sendSony(0x490, 12);
delay(40);
Serial.println("volume up 0x490");
else //down
irsend.sendSony(0xC90, 12);
delay(40);
Serial.println("volume down 0xC90");
break;
void setColor(int red, int green, int blue)
analogWrite(ledR, red);
analogWrite(ledG, green);
analogWrite(ledB, blue);
long doPing()
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
return pulseIn(echoPin, HIGH);
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
Step 4: Let It Run!
Controls
The controls are explained in the video, and are as follows:
Power
Swiping over the sensor within 3 inches will cause the LED to flash purple. This is the confirmation that a 'turn on / off' signal is ready to be sent. To prevent it accidentally turning the TV off I have made the sketch wait for a second swipe within 5 seconds of the first to confirm. At this point the signal is sent to the TV to turn on or off.
Channel
Swiping within 10 inches of the sensor (but not within 3) will cause the channel to change down. Swiping between 10 and 20 inches will cause the channel to change up.
Volume
Holding your hand within 10 inches of the sensor (but not within 3) will cause the volume to change down. Holding between 10 and 20 inches will cause the volume to change up. The volume will continue to change (up or down) until your hand is removed.
Arduino Contest
