Step 4The foam insert
iImage Information
Cut out a foam rectangle a few mm shorter on each side than the credit card, and cut a 20mm diameter hole into the middle of one end as shown - exactly where isn't crucial, but it should be close to one end. A scalpel will help with this. I cheated and did my prototypes like this, but ran off the rest on my laser cutter. You can also cut out a notch as shown about the same width as the LED, but this isn't crucial. To make it easier if cutting out with a scalpel, it actually works just as well if you make the 20mm cutout a square (with sides 20mm) rather than a circle. Have also attached a PDF of the pattern I used if that helps anyone.
Now you'll need to stick the foam onto the card - I used two strips of special high-strength double-sided tape, but for most people a glue gun will be a better choice. It works best just putting adhesive along the two long edges I've found. If you've designed your card with a picture of a button on it like mine, you'll want to make sure the cutout hole is behind the printed button!
