loading
Step 7: Clean stopper and drain
Now you can pull the stopper our and find all those wonders to clean!
Then push your toothbrush down into the drain and force the refugee masses down into your tub.
<p>Thank you so much for sharing. That is the most disgusting thing I've ever seen. and im so excited to go do the same with my bathroom sink. I have a feeling i may be in for real treat and see something even worse. I am truly scared of whats going to come out of there! Now this may not apply to very many, if any one else but it happened to my house so im gonna throw it out there any ways. When my house was being built (in 1963) the original plumbing, was not done by a licensed plumber. I'm talking about the pipes that are inside the walls. All drains, no matter where they start:kitchen or bathroom(s) come together eventually after making several turns and connections to one big drain that goes out to the &quot;street&quot; and city water works. Where those inside pipes turn corners are called slopes because they should be a curved pipes that make a downward slope to allow gravity to work so the water drains out. They should not be made with perfectly horizontal pipies that have 90 degree angles which allow water to stand in them and make sharp turns that are easy to clog, like mine are. It makes for endless plumbing problems as well as issues with the drywall and sheet rock that must be cut into to reach the corners that need replacing with slopes. However i must say at least the guy knew how to be thrifty and save a few dollars by doing it himself. Thats as nice as i can be.</p>
Baking soda and vinegar are chemicals you know...<br /> How about just tipping carbonated water (or coke) down the sink if carbonic acid is the cleaning agent?<br /> Hot vinegar fumes are irritating chemical-vapour, you should take precautions against exposure.<br /> <br /> L<br />
Water is a chemical. :)
<p>Thanks Lemonie. People&nbsp;who have respiratory problems should do this with good ventilation.&nbsp; Baking soda and vinegar are often used in grade school projects to demonstrate reactions so&nbsp;it's relatively safe. The by-products of the reaction are water and carbon dioxide, but the vinegar is strong smelling before the reaction is complete. <br /> <br /> Note: Do not add vinegar/baking soda&nbsp;if you have already poured a commercial drain cleaner down your clogged drain.&nbsp;Commercial drain cleaners may contains chemicals that, when mixed with vinegar, can cause noxious fumes.&nbsp;&nbsp;</p>
You're right there, e.g. bleach.<br /> <br /> L<br />
<p>Most commercial drain cleaners contain sodium hydroxide (commonly known as lye). It is a powerful alkali and will react violently with the acetic acid in vinegar. Any time one uses commercial drain cleaners, the drains should be flushed thoroughly with lots and lots of cold water.</p>
Shouldn't the hot water and vinegar burn your pipes
<p>This absolutely works but it took 3 tries and triple vinegar and tons of boiling water. It was still better than a chemical dangerous product or a very expensive plumber.</p>
<p>I will try to comment again. I first poured baking soda down drain followed by vinegar which I did not boil, Drain remained clogged. Following morning, after I read this script, I boiled vinegar, poured into sink and it started to boil over and cleared drain. Followed this with hot water to clear. </p>
<p>This method (with a few modifications) worked to unclog my bathroom sink. I thought this was gonna be a hassle and cost me $ and trips to Home Depot. It took about an hour to do, and now, the drain has this hollow flushing sound, which is so rewarding! Thanks for posting the pictures and instructions--I feel a great sense of pride that I can do this myself and not have to pay a plumber!</p>
<p>Thanks for the Instrucitons, You made declogging my drains a lot easier than I thought it was gonna be!</p>
<p>This is a great article which worked fantastic to clean the pipe. Once cleaned I ordered a Bathroom sink filter. The company is just starting to sell the unit and I received what they called a early release.. Paid $15 instead of 20 for the unit. The filter is part of the stopper. You just twist the cap and the unit comes out and so does all the hair and even lost items like your diamond. Thought it was very cool and wanted to share the info as the company is just starting up. </p>
Step 12. Throw out toothbrush to avoid accidently using it.
<p><em>I just got done doing this and IT WORKED AWESOME. My sink works better now then when I moved in.</em></p>
<p>I just got done doing this. AWESOME!!!!!!!!!!! Works better then when I moved in!!!!!!!!!!!</p>
<p>Thanks for all your help! problem solve :)</p>
<h3>MATNOOK</h3> <br /> Have you ever tried wet and dry vacuum. I have done it many times. It is the fastest and the most effective.Close all holes except he sink hole.use a powerful vacuum.Small vacuum&nbsp; would not work. It need power to suck out the uuuugh!!!. No mess to fix the plumbing again<br />
<p>I like your idea1</p>
<p>I am not sure why I didn't think of that. I just went under our sink and took the pipes off by hand. I then made a little hook from a metal hanger and pulled all the hair out of the drain. The pipes are clear to drain again....</p>
<p>Thank you! I did this and it worked after hours of trying to figure out how to unclog my bathroom sink. </p>
<p>Very helpful. My efforts looked pretty much exactly like this. Drain is all drain-y now!</p>
Ok, how do you people get the spacing in your comments?! *quietly weeps*
Thank you for this instructable. My comment isn't directed at this instructable. This comment is for people searching and might want not want to try this instructable until they try the wimpier way first. * If it's a bathroom sink or tub, the most likely culprit is hair. Try getting as much hair out by using a wire hanger, straightened out. Someone already mentioned that, I just wanted all the notes in one comment. Bring some white vinegar or apple cider (I have always that as I cook with it) to a simmer. I never measure but I'd suggest 1 to 1 1/2 cups of vinegar. Pour some baking soda (sorry, again I never measure) into the drain. Let&rsquo;s estimate 1/2 cup. Use a wooden spoon or your hands, or whatever to get all the soda into the drain. Then pour the hot vinegar into the drain. It will foam and bubble up. Let that do it's thing for a while, let's estimate 15 minutes. While the timer is ticking, boil some water. Pour the boiling water down the drain. This may take a few applications before one will see results. It is suggested by some to do this on a regular basis as preventative maintenance. I suspect it depends on how hairy the people and how many people share these drains. Why not add it to your spring and fall cleaning schedule so at least it's being done twice a year. * Now, for kitchen sinks. The culprit is most likely grease. I've actually seen recipes that say to drain hamburger in the sink, (and then pour boiling water down the sink) for example. I suspect some people do not realize how much oil and grease they are dumping down the drain over a period of time. Buy some ubber cheap degreasing dish washing liquid. You can save the more expensive one for your dishes. Measure out 1 cup of the degreasing type dishwashing liquid and pour down the drain. Let it sit there as long as possible. Boils some water and pour that down the drain. From now on, pour any hot grease or oil into a can, I saved a tuna can for this purpose but one may need a larger can depending on their cooking habits. Once the grease has cooled, use paper towels, news paper (I get those ads once a week in the mail), or paper bags if you prefer to be a wee bit green and at least get a second use out of them, to wipe out the grease and toss. (Can you say &ldquo;run on sentence.&rdquo;?) Or if you eat a lot of tuna, just throw out the whole can.
&nbsp;Great 'ible, thanks! I just did it and it worked great, it was disgusting, but it drains now :-) thanks again!
I can do it without removing the trap,providing the trap is in good shape.
<br /> Great job!&nbsp; Plunging the sink would have removed the majority of the buildup especially when using lots of hot water.<br /> <br /> Outstanding instructable with great photos.&nbsp; Well done.<br /> <br /> <br />
Oo, nice. I wonder if this will work with a stubborn tub drain? That thing is driving me nuts. The drain can't completely close and then when you want it to drain, it takes ages. <br />
If it's hair clogging the drain you can use a straightened clothes hanger with a hook at the end to pull the hair out.&nbsp; If it's just buildup you can use a plunger. &nbsp;Plug the drain, fill the tub with hot water and while covering the tub overflow with a wet towel, vigorously plunge the drain.<br /> <br /> I work as college dormitory maintenance. &nbsp;Tub, toilet and sink clogs are our #1 calls.&nbsp; We've learned the easy way to unclog them without chemicals as they are expensive and no matter what the bottle says... they all damage the pipes in the long run.<br />
Hey all, I&nbsp;am 3 year plumber helper and let me tell you, bathroom sinks can be nasty. however, they do sell a plastic tool that slides in under your stopper and can pull all the gunk up with it. I've seen em at home depot, and carry them on my truck. They work great. And remember that sometimes taking apart the trap can he a horrible thing, and cost you big time. <br />
Those things are really only good for hair clogs and you can do the same thing with a bent clothes hanger.&nbsp; <br />
&nbsp;Great project!<br /> <br /> Two plumber's rules for a better life:<br /> <br /> 1) &nbsp;Poop flows downhill!<br /> <br /> 2) &nbsp; Don't eat with your fingers!<br />
So the million dollar question is this:&nbsp;Did you use the tooth brush afterwards?<br /> <br /> :)
After step 6, where you've removed the pop-up assembly, the classic mistake is to get into cleaning the drain from above with your toothbrush and then turn on the tap to rinse it all down the drain. Some of the spooge will inevitably flow out the now-open pop-up opening and into the back of your cabinet.<br /> <br /> Oh, and although foxfirekenzie tries to explain away this horrible mass with the Florida humidity, rest assured that your sink looks just as gnarly -- everybody's sink drain looks this gross.
Hi hollasch,<br /> I use that big wide tub and I&nbsp;do run the water down into it to clean the stopper right then and there.
No amount of money savings will make me clean something like that with a 10ft pole and bio hazard suit, specially if its not MY sink. I rather spend the 15 in Drayno. Still good instructable.<br />
Oh boy!&nbsp;You have the most gnarly sink I have ever seen!&nbsp;Great photos and if it works for you, it will work for anyone!&nbsp;:)<br /> I am off to do this to my own now. Thanks for the boost.<br /> Kenzie
Thanks foxfirekenzie! I meant to mention that I live in Florida and the humidity levels make for astoundingly microbial-friendly habitat. Enjoy your colony removal, and let us know how it went.
About This Instructable
780,695views
98favorites
License:
More by katmckee:Confetti Eggs (Cascarones) Sprouted wheat berry bread = 2 ingredients, 4 steps Make a Bah Humbug Paper Shadow Puppet
Add instructable to:
