3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Under $30 Light Table
Step 6Routing it
Routing it
I used the router with a 0.25 inch bit set to the depth of my plastic sheet and went around the edges of my cut. This was my first time ever using a router so i'm rather proud of the results, but when I tried to set the plastic sheet into the lip I'd created it still needed a little more off so I used the router a little against protocol by using the very tip of the bit and not the cutting part to get the corners. This resulted in a little burning as seen below, but now the plastic fit!
2 comments
Mar 22, 2008. 3:04 PMterren272 says:
The way to get the corners is with a chisel and hammer. It doesn't take very long. The other way is to round the corners off he plexi glass with a file... or woodblock+sandpaper. This will take longer than the chisel, but you get a rounded corner look that might impress.... someone. :)
Dec 30, 2009. 8:50 PMfiducianullus says:
 No, the way to get the corners is with a jig saw.
Jul 28, 2010. 8:01 PMbatvans46 says:
try harbor freight if theres one in your area, or craigslist. they come in handy for tons of stuff.
Feb 7, 2008. 7:11 PMkd1s says:
Ah very nice! Thanks for this tutorial, I'd like to make a light table for the SO.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:GraffitiBatman
