3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Underwater Camcorder Mod! With Video!
Step 3Build it!
Build it!
1. Using the Dremel, carefully cut out the hole. Place the camcorder back inside to double check and make sure the lens "sees" through the hole. Clean the area around the hole.
2. Cut a piece of plexiglass about 1/2" larger than the hole. Leave the protective plastic on for right now.
3. Make a bead of Marine Sealant around the hole and attach the plexiglass. I used a couple of lead weighted bean bags to keep the plexiglass in place until it completely cured. Fast Cure takes about 24 hours.
4. After attaching velcro to the camcorder base and your new "underwater housing", put the camcorder in and add the bean bags or other weight as ballasts to keep it in the water.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2399
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
