loading
Well, I took a good look at the possibility that I'd be diving again anytime soon and figured that since I already sold off all my dive gear, this housing was just on the shelf due to pride. In an effort to get some of my clutter out, I put the housing and camera up on Ebay so that someone else might enjoy it.  If interested check out http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260769233083
The auction ends on April 21. Good luck!
Scuba housings are not cheap to buy, but they are cheap to build. Home Depot parts + internet mail order + time = Housing for about $70 worth of parts. Start your cam recording, seal it in the housing, edit later.
This one has been down to 92 feet salt water and has made a total of 6 repeat dives with open/close cycles in between. In other words, I didn't just get lucky.
By the way, we also plan to use this at the beach and in the pool. Enjoy!
Step 1: Will your camera fit?
If you have one of those full size VHS shoulder mounted bazookas, you might want to skip this project. 10" diameter PVC is not easy to find.
Take your cam into Home Depot or plumbing supply of your choice and sticking it in 3, 4, or even 6" Schedule 40 PVC pipe. Note, it MUST NOT say "cellcore" or "not for pressure applications". This will not take the pressure. You need real, solid, PVC.
My design uses 4" and most of the new compact DV cams will fit, I think. The new JVC harddrive cams might even make it into 3" which is SWEET.
If it will fit in 4" with a little room to spare for the tray, cool. Get the 10 foot length of pipe, three 4" couplings, and a can each of PVC primer and cement.
You'll also need Devcon 5 minute epoxy (buy a few, they're cheap) (two part that mixes in the nozzle) in the glue section and twelve 6/32 x 3/8" stainless steel screws (or allen heads) from the specialty hardware drawers.
Step 2: More shopping
Head over to Mcmaster.com and order the latches and O-Ring:
Get three stainless compression spring latches #1794A43 for about $6 each. The O-ring you want for a 4" pipe is a #425 EPDM part number 9557K377. Unfortunately it's a 9-pack for $12. I bought mine elsewhere, but I forgot where.
The Acrylic ports were cut from 1/2" thick plates. I bought a 12"x12" piece from freckleface.com for dirt cheap. If you have another source, by all means.
Step 3: Overall Assembly
Since this is quite customized per camera, I can only give you general guidelines.
One end of the assembly gets an acrylic window glued in. This is the sealed or non-removable end (left in the diagram). This end requires a 1/2" thick acrylic disc cut into a nice circle. I put the 4" pipe on top of the acrylic and traced the circle twice, rough cut with a jig saw, then mounted it to the PVC pipe using double sided tape and used a pattern maker bit on my router table to make a perfect disc. I'm sure it doesn't have to be this perfect, but you'll use more epoxy if it fits into the coupling loosely. You might as well cut both discs at the same time.
Hint: leave the protective paper on the acrylic for as long as possible.
Make two of the following:
Insert the disc into the coupling until it hits the stop. Use a pencil to trace on the paper against the stop so you know how much paper backing to remove when you glue it in. I just used an exacto to cut that small ring of paper off. Run a thin bead of epoxy in the stop and also on the side of the coupling where the disc will sit. Push the disc in and put some weight on it. A can of soup works. Let it set up for 10 minutes, or overnight.
Keep in mind, I trimmed the length of my couplings but it's not exactly easy to make nice square cuts. If you think you want to trim them, Do it BEFORE you glue in the discs. NOTE, the faces where the Oring sits must be smooth so I used the factory edges of the coupling. Of course, if you have a milling machine, you can go nuts with this. My purpose was doing as much as possible with readily available garage tools.
One final tip on the gluing process. Use masking tape on all adjacent areas because the glue goes everywhere. It's much easier to peel the tape before the epoxy or cement starts setting.
Step 4: Open End Details
Notice that a short ring of 4" pipe is inserted on the opening end, just behind the acrylic disc. This serves as a backing because the water pressure wants to push this disc into the housing. In retrospect, it may have been better to mount the disc on the other side of the moulded in stop (hey, give it a shot).
As noted on the drawing, the air gap between the body and the backing ring must exist otherwise the Oring will not seal. I laid the removable cap down on the bench and taped some pennies to this edge to create the air gap. Put a small section (a 1-2" ring) of coupling on the body of the housing with the factory edge facing the closure cap. Then put your O-ring on. Put your housing down into the cap (the pipe will now sit on the pennies). Push your Oring down to meet the coupling. Then push your 1-2" ring down to hit the O-ring. This represents the perfect placement for this ring and should be glued here. By the way, this is much easier said than done. PVC cement gives you about 30 seconds to work. It also gets squished out all over the place. Remember the tip about masking off your non-glued parts? You can't wipe PVC cement off because it immediately starts melting the pipe.
One more note on the O-ring sealing surfaces: Before you glue anything, you have to make sure these edges are beautifully smooth. I used the leftover piece of acrylic to make a large flat sanding block. With a little spray adhesive, I attached some 400 grit sandpaper. Then I rubbed these sealing edges in a random motion, turning it in my hand often, for about an hour each. Sometimes there is writing stamped on the ends. You can remove this first with a file so you don't spend too much time sanding them off. Either way, you might even want to look at this edge with a magnifying glass. Just one pit and your housing will leak.
Step 5: Camera tray and retention rails
It's gonna take some trial and error to figure out how wide to make the tray. You want the camera to fit between the tray and the top of the pipe, but also leave a little gap at the bottom for the tripod mount bolt head. A piece of stiff cardboard makes a good trial and error template. Once you have the right width, choose your finished material. I used a piece of 1/8" thick PVC sheet I had laying around. You can use metal, lexan, acrylic. 1/8" aluminum sheet would be nice, but 1/8" thick acrylic would be nice too. I added a nice touch by chamfering the bottom edges so it matched the contour of the pipe. This is probably just a bit of DIY tool masturbation so you may skip it, unless you like that sort of thing.
Put some masking tape on the top and bottom edges of your tray and then place it in the tube (clamp it down to the tube from both ends with a C or quick clamp if you have it). Cut some strips of PVC and glue them to the pipe just resting on the top of the tray. Once it starts to set up, you might want to make sure your tray is free to slide out and has not been glued in.
Note: leave your tray long for now, you can trim it at the very last minute so that the cap closes.
This tray setup really needs to be done before you glue the fixed end cap on.
Step 6: Getting there.
The attached image shows what the housing should look like just after gluing the stationary cap to the housing body (simple PVC cement just as if you were doing some plumbing in the house).
I'm attaching a repeat graphic here for emphasis and so I can talk about mounting the latches. I went a little overboard and routed some flats on the couplings in the locations of the latches so they would sit flat. I'm not sure if this was all that necessary but it adds a fine detail. If you don't have a router, you could probably do it with a rough file or a belt sander. Just make sure you clamp the cap to the housing so you're flattening the same spot between the cap and clamping ring in all three clamping locations.
Notice that in all cases, the mounting screws for the latches do not penatrate into the sealed housing. They are always backed by another layer. The 3/8" long screws will just barely get through the first 1/4" pipe layer.
I specified 6/32 x 3/8" machine screws but you could use sheet metal screws. It really shouldn't matter. Just make sure you pre-drill with a bit just barely big enough to get the threads started. WATCH the depth. I put a 1/4" depth stop on my bit to make sure I didn't ruin the whole project with one slip. It's a good idea to put a drop of epoxy in the holes and on the threads just before final assembly in case water makes it in.
I don't recall why I mounted the latches to the cap and the catches to the housing. I'd probably do it the other way around because I have to hold all three latches wide open as I'm putting the cap down.
Step 7: More Stuff...
I didn't describe much about the handles because you can probably figure them out on your own. You can use gate handles for a super cheap solution. The truth is, once you get this in the water (and hopefuly close to neutral), it can be steadied with two fingers. The motorcycle style grips I have are overboard. They are made of 1/2" schedule 80 PVC nipples with Bell bicycle grips from Walmart. They are glued to a 1/2" male street L, which threads into half a threaded female adapter which is glued to the housing. Everyone is amazed that this glue joint holds up and so am I. I actually made a concave in the end of the adapter so that it made full contact on the housing. I roughed up both pieces thoroughly and used PVC cement. I added about a 1/3 pound of lead shot to handles for trim ballast and it actually makes the housing just slightly negative. I would actually remove a bit to make it neutral but I epoxied it in.
Before painting, it's a good idea to run a bead of 5-minute epoxy at all the joints. That is, inside and outside the Acrylic to PVC joints and even the latch ring to housing body joint because if water gets in here it can make it passed the O-ring.
The paint is just rustoleum. Lightly sand the PVC first, apply a primer, sand again, 4 light finish coats. It gets really beat up anyway so you might want to leave it white.
Finally added a length of 1/2" wide webbing and spring clip to keep the housing with me during rough seas. The additional female adapter glued to the bottom of the rig is for an arm to attach my light cannon.
Step 8: Updated Design (V2)
Ok, so the V1 housing is still working fine but as a do-it-yourselfer I couldn't leave well enough alone. The first housing left a lot of space the rear of the cam so it wasn't as compact as it could be. Here's V2, which basically replaces the rear removable cap assembly with a simple acrylic disk. Notice the draw latch catches are screwed right into the acrylic.
I've sold this prototype to a willing beta tester who's only had it down to 10ft so far. A full depth test will be done in early January 07. My next build will use 3/4" Acrylic for the end window but I'm not sure if the additional thickness is even necessary.
Step 9: End Cap Details for V2
The first picture is really the key to this design. It shows how a simple, non-machined, O-ring groove is created. Remember that water pressure is always trying to push the Oring into the housing so the inner wall must stop it. At the same time, you must maintain a gap between the acrylic window and the main body so that it only contacts the Oring. I'll add detailed notes to all images on this page.
Hi Bobby_m<br>Are you sure about the O ring part number being #425? I got it, and it's a good fit to go over the coupling pipes, not the 4&quot; housing pipe (it's too big for that one). As per the schematics, the ring needs to fit right over the housing, so it has to be a bit smaller. Are you sure 425 is what you used?
Wow, I'm really late in this reply but yes, I'm sure about the #425 ORING. 4&quot; schedule 40 PVC pipe has an ID of 4&quot; and an OD of 4.5&quot;. The #425 ORING has an ID of 4.5&quot; which should just slip over the 4&quot; PVC and mate properly with a 4&quot; coupling edge. If your oring slips OVER the coupling, it must be a #428 or similar or you ended up with some odd PVC that is measured in pipe OD (I'm not aware of any of this stuff).
Hi - I'm very excited to make this to project to lower underwater in the local pond with my kids to see what fish we can see (they love to fish with me). My camera won't fit the 4&quot; model described in the instructions - I bought 6&quot; PVC. <br>My questions: <br>1. The O-ring for 4&quot; (#425 EPDM 9557K377), on mcmasters.com has a listed and actual size described as 4.5&quot; and 5&quot;, respectively. Does that mean then that for a 6&quot; project, I should get #439 with listed and actual sizes of 6.5&quot; and 7&quot;, respectively? <br>2. freckleface.com, the recommended site for acrylic, advertises polycarbonate as much stronger than acrylic (it descrbes acrylic as 10x glass and polyC as 250x glass). Is there any reason (clarity, quality, etc.) if the local ponds/lakes are no more than 50' deep why it might be better to use polyC rather than acrylic? <br>Thanks for publishing such an awesome project to try! <br>-William
PVC pipe is rated for its inside diameter and for the most part, schedule 40 is about 1/4&quot; thick. A 6&quot; PVC pipe would be about 6.5&quot; OD. I'd go with a #438 which has an actual ID of about 6.25&quot; and it will easily stretch and stay securely in place. <br> <br>While polycarbonate is stronger, I think what feature they mostly associate with &quot;stronger&quot; at least in use for windows is that it is less likely to shatter. To achieve that, it is actually a little softer than acrylic which makes it more prone to scratching. If you don't mind buffing out scratches occasionally, it would be a fine choice. Don't set it down, window side down, onto any hard surfaces.
Oops, sorry.. Once you get to 6&quot; PVC (sched 40), the actual OD is closer to 6-5/8&quot; so your estimate of ORING #439 is a better fit afterall.
Hello Bobby, <br>Greetings from Germany. I'd just like to say &quot;thank you&quot;. <br> <br>I shot a wonderful total cut of 50min on a recent red sea dive safari. Among others, the housing went into the SS Thistlegorm. <br> <br>My housing dove down to 25.5m. I've noticed a tiny leakage when ascending from the depth to in between 7m-0m. Funny..an accompanying noise was audible on the video. That's the fact..still looking for a theory for the necessary side conditions. Didn't happen every dive. <br> <br>My Specs. <br>Inner pvc pipe: 120mm, 6.7mm thickness, 10bar <br>Outer pvc pipe: 140mm, 10mm thickness, 16bar <br>Acrylic ports: 12mm thickness <br>4x compression latches <br>Name: &quot;DeepSea Challenger mini&quot; in dei gloriam Mr. Cameron;-) <br> <br>Many thanks for this superb instruct able, <br>Martin <br> <br>Martin Streller <br>Berlin <br>
Hey is a cuboidal shape for the housing or a Cylindrical one capable of taking more pressure? And what is a good sealant for taking on high pressures of about 50m-60m. What will be a high pressure taking material other than pvc?<br>
Just wanted to say thx for the instructable. Finished building my housing, and am very happy with it. Didn't get to try it out under 10ft yet, but it looked promising in the tub and I'm confident with all the seals.<br><br>A couple of things I changed/noticed - the handles were filled with lead shot, but I found it easier to just plug it with a hot glue gun. Much easier to tear open later on if I need to. Also, the total weight of the housing remains negative even with the handles filled to the brim, so I guess I'll need to stick a pair of pliers or something heavy inside to add weight. I'm thinking of a zip lock (or two) that I can fill with sand right at the beach, and I can stick it under the shelf.<br><br>Lastly, I found a whole line of Rustoleum spray paint that had primer in it and was good for multiple surfaces, including plastic, so that saved me a step or two.<br><br>Lastly, just thx again for posting the instructable!
Having a hell of a time getting latches shipped to Canada. McMaster doesn't ship anything over here unless it's to an established customer. Tried Home Depot as well as local hardware stores, and they have nothing. Any other ideas? Otherwise I'm left with some guy from hong kong selling his stuff on ebay, and it's only listed as being made out of &quot;metal&quot; ...
For anyone interested, I found that Fastenal has several stores in Canada, and sells pretty much the same stuff McMaster does. Hope this saves someone else some time!
just out of curiosity how deep can it go because I'm going to use it on an under water robot<br>
I had it to about 95F but I'm sure it can go a couple hundred. I wouldn't put a camera in the first time you break depth limits empty first.
thanks to you Mr bobby_m <br> I already done half work of mine, and already tested to the 15 feet pool and succed ,a few changed from your plan I made and now i planning to make the operating button , i'm promise after done i'll pose the pic <br>many thanks bro, keep the good work <br>cheers
as im making mine i start to notice that it is kinda hard to take the coupling of the pipe once it goes all the way in. how do you easily remove the end coupling once its all done?
If you look at the drawing, the coupling that becomes the removable cap only overlaps the pipe about 1/4&quot; before the oring stops it. On mine, it provided no resistance to removal.
im using 6&quot; pvc, 1/4 into the coupling is very loose . thats making me worry. i want ~ 1 1/4&quot; in the coupling. any recommendations on longer latches? <br>
Well I decided I wanted to build this housing so I did, managed to gather all my parts without ordering online. Unfortunately I think this was the cause of my leaking housing. I ended up using a o-ring that I found at my local hardware store that was a smaller diameter than yours. My second issue was that I didn't have a machine which I could cut square edges with. Finally I think the sealing edges of my removable end needed to be angled differently. I used the existing smooth edge of 2 couplings to seal it, but the edges were rounded in towards the inside rather than flat. Either way the housing looks great, and I will definitely still use it as a crash cam case, for it feels indestructible. <br><br>I have a few questions for my second build which I will build at my friends machine shop. <br>1) How important is the diameter of the O-ring?<br>2) Wouldn't putting the acrylic disk on the &quot;outside&quot; of the coupling lip be beneficial for the non-removable side? (full socket depth for pipe=stronger)<br>3) What epoxy/ adhesive do you use for the acrylic to pvc bond? <br><br>I'm planning on making a window for the non removable side and then using an end cap with a glued in support ring for screws for the removable.
No need to build the 2nd version. My camera is small and my housing was too big, so I chopped the housing in half and eliminated the leaking window. Now I have an end cap sealing upon the coupling of the non removable side. It came out really small and solid.
OK, another question. I'm going to take your suggestion and install my acrylic disc on the "other side" of the molded-in stop, so that the stop itself, and not an inserted ring, supports the disc against the water pressure that wants to push the disc into the housing. If I do it that way, I wouldn't need the inner ring at all, correct? And if that's true, does the lack of an inner ring affect the gap in any way?
It introduces a few challenges. Notice the latches will have to be longer so that the screws penatrate into or in front of the acrylic. The backing ring provides more gluing/sealing surface for some piece of mind. Maybe it's not necessary but you'd have to experiment. The gap doesn't have to be exacting by the way, you just don't want the body bottoming out before the Oring is compressed well.
couldn't you still glue in a ring behind the molded in step? That way you wouldn't have to use longer latches.
Have you come across any issues with the refractive index of water causing issues against your flat viewing port - just curious ? Thanks.<br><br>Way cool build btw :)
Are the handles strong enough to tie a rope + weight to so that I can lower this assembly into my lake... I've always wanted to know what's down there....
A very good project, I just wanted to say that for any one in the UK I found Westward plastics in Bristol http://www.westwardplastics.co.uk/ to be a good supplier of material, they can also cut the acrylic discs for you and flame polish them, I have used them several times. Also if you can get there to pick up your material you may be able to have a look in their scrap bin for useful off cuts. Another supplier worth checking out is Kebrell Nuts &amp; Bolts Ltd, I have only used their Bristol depot but found them to have a wide range of stock and the people there to be very helpful.
Hi Great 'ible! As a kid I was obsessed with making things waterproof! There was a company back then call EWA-Marine who supplied everything you needed to build your own enclosure - O - rings , latches , glass lens portholes - stainless steel control rods which passed thru the enclosure with special seals for camera control Regarding polishing Acrylic (or Perspex) back to see-thru shiny: No need to introduce flame or torches which may cause nasty gases and can be hard to control....... I have made 3 electric guitars using acrylic for the bodies and headstock Here's how to get a mirror finish - once you sand the surface to the 'hazy' stage using progressively finer papers you can easily bring the acrylic to a mirror see-thru finish by then hand rubbing with Auto cutting compound and cloth! (we call it Cut and Polish Compound in Australia) Use the compound designed for heavy cutting rather than the final polish one Think of the acrylic as a really thick car acrylic clearcoat It works really fast and you'll get a perfect finish! cheers Neilmac
Instead of using an O-ring couldn't you use the threaded fittings, so you can screw the end on? I'm not sure on how water resistant it is to what depth etc. that would be. Just a thought. Nice instructable and it looks real professional.
You could probably get it to seal if you used a lot of thread sealant but you'd have to bring a strap-wrench on the boat with you to tighten. The latch design lets you load the camera in and be in the water within 5 minutes.
I have noticed that no firm solutions for controlling the camera have been offered. A company named Hypoxic offers a product called the Hypeye D. It is a single button, wired remote controller that works well in other sport applications (I personally use one on my skydiving helmet to control my Sony CX100). With sufficient waterproofing, it might do the trick...<br> <a href="http://www.gethypoxic.com/linkstore.html?page=shop.product_details&flypage=flypage.tpl&product_id=17" rel="nofollow">http://www.gethypoxic.com/linkstore.html?page=shop.product_details&amp;flypage=flypage.tpl&amp;product_id=17</a><br>
Great article! Kudos. I will add that I couldn't find the o-ring you described at any local home depot or ace hardware. I did find a site online that sells them $0.79 each which I think is fair. It was called <a href="http://www.rubberstore.com/catalog" rel="nofollow">TheRubberstore</a> here is the direct link for the <a href="http://www.rubberstore.com/catalog/epdm-oring-as568-0275-4475-p-1803.html" rel="nofollow">EPDM o-ring</a> mentioned in the article. I hope this helps, as this article has helped me.<br />
Just to let you know the website that you specified has a minimum order of 25 O-Rings. the total comes to around $18.00 for 25 O-Rings. Its still better than $12.00 for 9 O-Rings though, especially if your making more than one of these.
How about allorings.com? You can get THREE -425 rings in silicone for $5.88. I think silicone would be a good choice because it's softer and may make up for minor contamination like a spec of sand.
On my design, if I install the end cap without the o-ring in place,&nbsp;the o-ring can be pushed into the gap with just a small amount of force. Should I shave off some of the 4&quot; pipe to get a more snug fit?<br /> <br /> Steve<br />
Yes, absolutely. You want that gap to be too tight to even push the ORING in because when you start taking on pressure, you want the cap to be able to compress the oring as much as it wants to. You don't want the cap to bottom out on pipe. I'd say take 1/8&quot; off. Just my opinion.<br />
&nbsp;looking at the first hardware site listed, mcmaster.com, I found a slightly better clasp a few lines down, #1794A54. &nbsp;I say better because these are padlockable, so my idea was to put a pin (google:&nbsp;&nbsp;5/16 dia. 1.00 grip, quick release pin, $2.18 each from amazon)&nbsp;each clasp, secured via elastic cord (1/16 dia. available from Amazon also, 5 yards for $1.59) to the opposite end of the housing.&nbsp;<br /> <br /> This creates a redundant closure system , essential when the safety of your electronics is at stake. The clasps listed above leave it VERY easy to accidently open one of the clasps underwater if the edge of it catches on something like your BC, gloves, or wetsuit, whatever.&nbsp;<br /> <br /> <br /> <br />
The clasps don't open very easily at all because they use springs for tension. If you install the catch at the correct distance, it takes a bit of force to close the latch as well as open them.<br /> <br /> I have a lot of dives on this housing and I've never unlatched by accident. For sure, you can build any redundant safety into it as you'd like. <br />
**Alternate Latch: I'm using a flat, rubber, adjustable bungee strap (Home Depot)...the strap has reinforced holes every 2 inches or so...I cut a piece...add a loop of line to one end to make stretching easier. The strap attaches to stainless steel bolts. Simple, but very effective....I used this method to make a waterproof tube with 3" sched 40 pvc. I Glued one end cap on, on the other end...Cut a piece off of a coupling...slid this over the pipe about 1 1/2"...glued in place, slid on an o-ring...the cap attaches nicely with the above strap/ bungee method. I just ordered some clear pvc sched 40 from US plastics...unfortunately, must buy 10 feet, at over $13 per ft. **Note: I installed the bolts in the coupling piece mentioned above....and near the top of the cap, alternately, you could install 4 connection points (instead of 3) ...install bolts only in the coupling piece, and cross 2 straps over the top of the lid to stetch down and connect at the other side. 1st attempt, however, I did drill all the way through the cap...used 2 part epoxy to seal.
Used a JVC hard drive camcorder with extended battery - would record two entire dives with no problem. First time using was in May/June 09 in Philippines &amp; took it to 94' with no problems. Dove in Batangas with Aquaventure.<br/><br/>Thanks for the instructions!<br/><br/>Video (has a still of me on dive with housing):<br/><a rel="nofollow" href="http://www.youtube.com/watch?v=nmfSq1j1rjQ">http://www.youtube.com/watch?v=nmfSq1j1rjQ</a><br/>
Can you possibly find any latches at home depot
Found something similar on Lowe's website.... National Steel Draw Hasp Item #: 168962 Model: DPB35 $3.37 each
Plain steel will rust pretty quickly unless you wash it well with plain water and dry it quickly.
What are you using for control knobs?
Nothing. I start the recording about 5 minutes before I splash in, seal the housing and go. My battery and tape lasts 60 minutes and my dives are usually 45.
im using a 40gig harddrive camcorder so aint worried about the footage lasting but my dives tend to last atleast an hour if not longer ( i dont breath lol) but will have to look at getting spare batteries then. thanks for the comments
I would like an on record off record and a zoom in zoom out I plan to use this baby during a hurricane do you have any sujestions I was looking at some plastic lever handles from irrigation equipment what do you think any one
finding the controls aint a prob the prob i've come across is how to seal the perspex once i've put the rods through it
If you wanted to make your own controls, you can get some 1/8" stainless rod and a compression fitting with NPT threads. 1/4" NPT can be tapped into the acrylic or PVC. You'd remove the metal ferrule on the compression fitting and pack that cavity with some lubricated orings. Tighten the compression nut enough to stop water but not restrict the turning of the rod too much.
were do you get this hardware from I have looked everywere fro compressipn fitings and they are to big or not what I need if you know a website let me know Thanks Bob
Check out item 5533K433 at mcmaster.com You'd have to drill out the stop with a 1/8" bit and pack an oring or two in there but that would work.
hi guys built something similar i guess but i used a 6lt CO2 fire extinguisher bottle as the walls are 5mm ally and internal dia is 108mm very good and been tested to 50m and still going strong after over 200+ dives only thing im strugerling on is setting up dials on the 1/2 inch perspex to control the camera so at the mo i switch it on before the dive and turn it off after so catch the hole dive lol does any1 have any ideas on controls for power and zoom
Awesome! I am heading to the tropics for some diving and have always wanted to take my camcorder with me but can't justify the $1000 cases out there. I hope you are still reading this, I have a few questions. Have you observed any condensation when you used this beauty? Second, have you thought about any exterior controls? Start/Stop, zoom, on/off, etc? Is there a V3? Thanks again for taking the time to post this. It is very well done and much appreciated. If you need any future "beta" testers put my name on that list!
About This Instructable
127,479views
206favorites
License:
More by Bobby_M:Underwater Housing for miniDV
Add instructable to:
