3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Underwater Housing for miniDV
Step 2More shopping
More shopping
Head over to Mcmaster.com and order the latches and O-Ring:
Get three stainless compression spring latches #1794A43 for about $6 each. The O-ring you want for a 4" pipe is a #425 EPDM part number 9557K377. Unfortunately it's a 9-pack for $12. I bought mine elsewhere, but I forgot where.
The Acrylic ports were cut from 1/2" thick plates. I bought a 12"x12" piece from freckleface.com for dirt cheap. If you have another source, by all means.
7 comments
Jan 14, 2012. 4:45 PMDavid Catriel says:
Hi Bobby_m
Are you sure about the O ring part number being #425? I got it, and it's a good fit to go over the coupling pipes, not the 4" housing pipe (it's too big for that one). As per the schematics, the ring needs to fit right over the housing, so it has to be a bit smaller. Are you sure 425 is what you used?
Jan 10, 2012. 1:52 PMDavid Catriel says:
Having a hell of a time getting latches shipped to Canada. McMaster doesn't ship anything over here unless it's to an established customer. Tried Home Depot as well as local hardware stores, and they have nothing. Any other ideas? Otherwise I'm left with some guy from hong kong selling his stuff on ebay, and it's only listed as being made out of "metal" ...
Jan 11, 2012. 6:54 AMDavid Catriel says:
For anyone interested, I found that Fastenal has several stores in Canada, and sells pretty much the same stuff McMaster does. Hope this saves someone else some time!
Mar 1, 2010. 8:18 AMevolving_I says:
 looking at the first hardware site listed, mcmaster.com, I found a slightly better clasp a few lines down, #1794A54.  I say better because these are padlockable, so my idea was to put a pin (google:  5/16 dia. 1.00 grip, quick release pin, $2.18 each from amazon) each clasp, secured via elastic cord (1/16 dia. available from Amazon also, 5 yards for $1.59) to the opposite end of the housing.
This creates a redundant closure system , essential when the safety of your electronics is at stake. The clasps listed above leave it VERY easy to accidently open one of the clasps underwater if the edge of it catches on something like your BC, gloves, or wetsuit, whatever.
Feb 17, 2009. 11:55 AMjcub231 says:
Can you possibly find any latches at home depot
Jul 14, 2009. 1:29 PMjdpphotography says:
Found something similar on Lowe's website.... National Steel Draw Hasp Item #: 168962 Model: DPB35 $3.37 each
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:Bobby_M
