Step 4Open End Details
As noted on the drawing, the air gap between the body and the backing ring must exist otherwise the Oring will not seal. I laid the removable cap down on the bench and taped some pennies to this edge to create the air gap. Put a small section (a 1-2" ring) of coupling on the body of the housing with the factory edge facing the closure cap. Then put your O-ring on. Put your housing down into the cap (the pipe will now sit on the pennies). Push your Oring down to meet the coupling. Then push your 1-2" ring down to hit the O-ring. This represents the perfect placement for this ring and should be glued here. By the way, this is much easier said than done. PVC cement gives you about 30 seconds to work. It also gets squished out all over the place. Remember the tip about masking off your non-glued parts? You can't wipe PVC cement off because it immediately starts melting the pipe.
One more note on the O-ring sealing surfaces: Before you glue anything, you have to make sure these edges are beautifully smooth. I used the leftover piece of acrylic to make a large flat sanding block. With a little spray adhesive, I attached some 400 grit sandpaper. Then I rubbed these sealing edges in a random motion, turning it in my hand often, for about an hour each. Sometimes there is writing stamped on the ends. You can remove this first with a file so you don't spend too much time sanding them off. Either way, you might even want to look at this edge with a magnifying glass. Just one pit and your housing will leak.
4
comments
Add Comment
Add Comment
