Step 6Getting there.
I'm attaching a repeat graphic here for emphasis and so I can talk about mounting the latches. I went a little overboard and routed some flats on the couplings in the locations of the latches so they would sit flat. I'm not sure if this was all that necessary but it adds a fine detail. If you don't have a router, you could probably do it with a rough file or a belt sander. Just make sure you clamp the cap to the housing so you're flattening the same spot between the cap and clamping ring in all three clamping locations.
Notice that in all cases, the mounting screws for the latches do not penatrate into the sealed housing. They are always backed by another layer. The 3/8" long screws will just barely get through the first 1/4" pipe layer.
I specified 6/32 x 3/8" machine screws but you could use sheet metal screws. It really shouldn't matter. Just make sure you pre-drill with a bit just barely big enough to get the threads started. WATCH the depth. I put a 1/4" depth stop on my bit to make sure I didn't ruin the whole project with one slip. It's a good idea to put a drop of epoxy in the holes and on the threads just before final assembly in case water makes it in.
I don't recall why I mounted the latches to the cap and the catches to the housing. I'd probably do it the other way around because I have to hold all three latches wide open as I'm putting the cap down.
comments
Add Comment
Add Comment
