3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Underwater Housing for miniDV
Step 8Updated Design (V2)
Updated Design (V2)
Ok, so the V1 housing is still working fine but as a do-it-yourselfer I couldn't leave well enough alone. The first housing left a lot of space the rear of the cam so it wasn't as compact as it could be. Here's V2, which basically replaces the rear removable cap assembly with a simple acrylic disk. Notice the draw latch catches are screwed right into the acrylic.
I've sold this prototype to a willing beta tester who's only had it down to 10ft so far. A full depth test will be done in early January 07. My next build will use 3/4" Acrylic for the end window but I'm not sure if the additional thickness is even necessary.
17 comments
May 8, 2009. 7:01 PMevoseano says:
What are you using for control knobs?
May 29, 2009. 7:30 AMdrew898 says:
im using a 40gig harddrive camcorder so aint worried about the footage lasting but my dives tend to last atleast an hour if not longer ( i dont breath lol) but will have to look at getting spare batteries then. thanks for the comments
Jun 1, 2009. 2:25 PMevoseano says:
I would like an on record off record and a zoom in zoom out I plan to use this baby during a hurricane do you have any sujestions I was looking at some plastic lever handles from irrigation equipment what do you think any one
Jun 2, 2009. 11:34 AMdrew898 says:
finding the controls aint a prob the prob i've come across is how to seal the perspex once i've put the rods through it
Jun 5, 2009. 5:13 PMevoseano says:
were do you get this hardware from I have looked everywere fro compressipn fitings and they are to big or not what I need if you know a website let me know Thanks Bob
May 27, 2009. 12:30 PMdrew898 says:
hi guys built something similar i guess but i used a 6lt CO2 fire extinguisher bottle as the walls are 5mm ally and internal dia is 108mm very good and been tested to 50m and still going strong after over 200+ dives only thing im strugerling on is setting up dials on the 1/2 inch perspex to control the camera so at the mo i switch it on before the dive and turn it off after so catch the hole dive lol does any1 have any ideas on controls for power and zoom
Feb 17, 2009. 12:52 PMjcub231 says:
i am willing to buy one how much do you want
Oct 12, 2007. 7:28 AMextraawesome says:
Oh, Yep, it's the polished edge, It looked like a metal ring going around the entire acrylic piece but it's just really good craftsmanship that made it look all shiny!
Oct 11, 2007. 7:36 PMextraawesome says:
What was the round metal piece that goes all the way around the outside called? I've been trying to find one but I don't know the name of it.
Jun 7, 2007. 10:43 AMcherbini says:
So, what were the results from Hawaii? Definitely going to start this one up. Trying to get to Cozumel or Cayman's later this year, and need to get the PV-GS250 set up. Have you ever tried different lenses inside the housing? I have a Raynox WA lens that really improves the FOV on the GS250, and am interested to see how well it may work underwater. Thanks for the great instructions! John C.
Jun 7, 2007. 11:24 AMcherbini says:
Yeah, I got you on the distance from lens to front window. Makes sense. One could put multiple mounting spots on the tray to accommodate different lens choices. So, what do you think on the version that I should try? I like the design and simplicity of v2, but it doesn't seem like it's had the testing that v1 has. Has anyone else built and tested v2? Thanks! JC
Jan 16, 2007. 3:13 PMchrisloco says:
Thanks, Bobby for the great design. I have ordered all parts, including 3/4 inch acrylic for the lens. From looking at the picture the latches are mounted right to the edge of the plexiglass using ss screws. Just wanted to make sure that is the right way to do it. I don't want to crack the acrylic. Also has version 2 been tested yet . Thanks tons for the help and all the legwork!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:Bobby_M
