3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Underwater Microphone (Hydrophone)
Step 4Soldering and Wrapping Connections
If your test was successful then you can solder your connections.
If it was not make sure that your wires are in the right spot and that they are well connected also check the volumes of your recording equiptment.
There are a lot of different ways that you can do this, but you need to insulate the wires so that they do not touch each other, the mic capsule, or water.
If I had access to a glue gun I would of sealed them that way instead I used plastic wrap, and indiviually wrapped the connections and then wrapped them all together.
After you do this its a good idea to test the mic one more time.
1 comment
Jun 8, 2008. 5:55 AMfib3roptix says:
Do you wrap the tip of the mic too????
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:action_owl
