ROV Video.AVI(320x240) 48 MB
Remove these ads by
Signing UpStep 1: Design
The first ROV was built by Steve of Homebuilt ROVs. His website has numerous ROV designs as well as links to other ROV websites. He also incorporates several How To instructions in his site. I found this site to be invaluable in building my ROV, and would recommend it to anyone interested in building their own
The second ROV was built be Jason Rollette at Rollette.com His design is a little different but still very effective.
For my ROV I decided on a large center tube with two smaller tube located on either side, slightly underneath the center tube.
Visit Our Store »
Go Pro Today »
Good luck!
When retrieving items, you will either need powerful enough motors to lift the object or some kind of inflatable lift bag to give you the added buoyancy you need. Alternatively you could use a tether that has a lifting line which you could use to haul your ROV to the surface
...could be wrong, was couple times afore, but I think 'plenum' cable is cable which uses insulation that does not produce harmful vapors when burned. In some commercial buildings, a/c return-air is run (without ducts) in the space between the room ceiling and the floor above it, ie the 'plenum'. If a fire ever broke out, this specially-designed 'plenum' cable would not release toxic fumes into the a/c system air flow which would injure or kill all living creatures within the air conditioned space.
Other than that, thanks for the info here. I have been working on my own system, mostly to get live pics in the canals here in S. Fla. My interest is in getting the 'real' closeups of the many 'gators that live here; maybe one day I'll get some neat shots as my mini-cam gets swallowed whole!
myfixitshowcom
it also has infered so you would not have to buy lights
http://cgi.ebay.com/CCTV-Security-30-IR-LED-Waterproof-Camera-Power-Bracket_W0QQitemZ350211816960QQcmdZViewItem be a good camera?
Spark fun costs AUD50 which is way too much.
1. Log on to www.ebay.com
2. Search "Keyboard" with the 2nd hand option.
3. Buy the cheapest one you can find.
4. There you go! You got successfully scammed and you should now be able to type upside down!
Just kidding
FIrst you have to go to Zargos Robotics and get the compass sensor. it is located at their very bottom of the pagehttps://www.zagrosrobotics.com/Index.asp
then what I did is I made a little pcb board to fit the sensor and the lights and the output. I can give you the layout that I made if you would like it.
ʎɐʎ
Just to tell you this compass is very finicky.
remotely operated vehcile
My rov is a little different than all of the rov's I have seen. My rov has ballast tanks which fill up and drain out. I can give you all of the schmatics that I have used. I didn't use that many just a compass and 2 cat 6 jack boards.
Most rov's are nature buoyant so when placed in the water it barely floats and then a motor turns which propels the rov down. I am going to have 3 separate wires which propel the motors which moves the rov F B L R.
There is also a tube that connects to the ballast tanks.
Finally a cat 6 wire will run to the rov which caries camera, compass and lights
on the surfaces I have 2 toggle switches that move the rov and a video jack and also a main power switch and a light switch.
If you need anything specified in more detail just Reply.
Go here http://pyrotechnic-robot.webs.com/rov.htm
go to: http://www.instructables.com/group/ROV/
or check out my ROV project,i would love to work together on improving our ROV's
