3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Underwater ROV
Underwater ROV
This instructable will show you the process of building a fully functional ROV capable of 60ft or more. I built this ROV with the help of my dad and several other people who have built ROVs before. This was a long project that took al summer and part of the beginning of the school year.
ROV Video.AVI(320x240) 48 MB
Step 1Design
Design
In order to keep the ROV stable in the water, you need a design that is weighted on the bottom and has floats on the top.
The first ROV was built by Steve of Homebuilt ROVs. His website has numerous ROV designs as well as links to other ROV websites. He also incorporates several How To instructions in his site. I found this site to be invaluable in building my ROV, and would recommend it to anyone interested in building their own
The second ROV was built be Jason Rollette at Rollette.com His design is a little different but still very effective.
For my ROV I decided on a large center tube with two smaller tube located on either side, slightly underneath the center tube.
183 comments
1-40 of 183next »
Apr 14, 2012. 12:42 PMmonty324 says:
when i was about 6 i liked to watch the diving programes because i thought rov's where soooo cool
Dec 10, 2011. 4:07 PMmwuchevich says:
Was wondering if their is any ill effect for use in cold ocean water... I just moved to norway and im currently evaluating what design parameters i will need to help me study the submarine geology in the current area. Any informaiton about cold water performance would be grately helpful. Considering rock retrival video and some type of sonic rebound reflective maping device.. just not finished with research.
Dec 10, 2011. 4:13 PMmwuchevich says:
also any ideas about cancling neutral boyncy after retreaving objects on a dive? sorry for the sp its late and brain not spiting out words to fingers correctly.
Jul 21, 2011. 8:07 PMgrundisimo says:
Try using pumps and ballast tanks to control weight.
Feb 16, 2011. 3:34 PMLegoman132 says:
I am building an ROV myself, and I was wondering ow far your lights penetrated in cloudy water. Also, I flound that the 1250 GPH bilge pump replacement cartridge from West Marine doesn't need cutting to get to the motor shaft, and I got some boat props from hobbytown that fit the shaft perfectly, just tighten the key and go. The only issue is they produce more thrust in one direction than the other. Do you have the same issue? I also find that mounting your motors with PVC pipe clamps (in the 1 1/2 inch realm I think) and some old bicycle inner tube around the motors holds them on solidly, and you then put some bolts through the frame PVC (assuming your frame isn't watertight). This forms a very solid mount(at least for me) that doesnt move. It also doesn't crush your pipe like pipe clamps do.
Jul 10, 2011. 9:08 AMUberNoober says:
Because of the shape and design of a propeller, and the way it's mounted on the motor, they produce more thrust in one way than the other. It's a problem all prop-driven ROV's must design around.
Apr 26, 2011. 4:25 PMR.A.T.M says:
CAN I BUY ONE FROM YOU
Feb 28, 2010. 4:22 PMnomejodaslavida says:
If you're going to use the submersible bilge pumps as motors, why not use them as they are, without propellers,  for jet propulsion?  You could even increase the force of the jet by by graduating the discharge down to a smaller size.
Apr 23, 2011. 7:14 AMberry120 says:
Propellers have the advantage that they can be run either way for forwards and backwards - they'll also give more thrust (though draw more current as a result.)
Oct 1, 2010. 8:05 PMMR JAMES says:
cool i want 1 of these lol
Jun 16, 2010. 4:05 AMghostrider2 says:
how much was the total cost of the project?
Jul 12, 2010. 9:09 PMrajeev.piyare says:
hi any idea if we can get the codes and circuit diagrams for this whole project so that we can implement as well please. Thanks
Feb 7, 2009. 2:05 PMBJMN says:
I have a quick question - I remember learning in school that water is opaque to IR. My wife is a certified IR photo tech, and I know that our IR camera won't show things even just a few millimeters under the surface of water. Is it really IR that these cameras use?
Feb 8, 2009. 8:44 PMBJMN says:
Hmm - just curiosity, since I don't doubt you've researched more than I! But to rephrase my question - since water is opaque to IR, wouldn't IR cameras be relatively useless underwater? If B&W cameras were IR sensitive, wouldn't they still just be picking up the visible light spectrum, since water emits an even IR level? Anyhow - not looking to troll this thread out - but still curious as to how an IR camera would function underwater!
Sep 3, 2009. 6:16 AMrrrmanion says:
maplin seem to be selling a camera that is apparently able to see up to 7m it has 12 IR LEDs, so it seems IR does work under-water so perhaps how you had it set up or something I don't know
Mar 26, 2010. 12:05 PMwheelerjp50 says:
Red light can penetrate up to 15 meters in water. Most b&w cameras pick up near infrared that is between red and true  infrared. So 7m sounds reasonable. Like any light it would be limited by suspended particles in the water.
Feb 22, 2010. 8:30 PMquesoman says:
is a video of the ROV in action possible?
Feb 22, 2010. 8:02 PMmyfixitshowcom says:
"This is plenum rated Cat 5, meaning that it can be pulled through walls using a fishtape."
...could be wrong, was couple times afore, but I think 'plenum' cable is cable which uses insulation that does not produce harmful vapors when burned. In some commercial buildings, a/c return-air is run (without ducts) in the space between the room ceiling and the floor above it, ie the 'plenum'. If a fire ever broke out, this specially-designed 'plenum' cable would not release toxic fumes into the a/c system air flow which would injure or kill all living creatures within the air conditioned space.
Other than that, thanks for the info here. I have been working on my own system, mostly to get live pics in the canals here in S. Fla. My interest is in getting the 'real' closeups of the many 'gators that live here; maybe one day I'll get some neat shots as my mini-cam gets swallowed whole!
myfixitshowcom
Sep 28, 2009. 5:16 PMyour dog says:
would be a good camera?
it also has infered so you would not have to buy lights
http://cgi.ebay.com/CCTV-Security-30-IR-LED-Waterproof-Camera-Power-Bracket_W0QQitemZ350211816960QQcmdZViewItem be a good camera?
Feb 21, 2010. 3:20 PMastrong0 says:
You spelled infra-red wrong
Sep 29, 2009. 4:20 PMyour dog says:
it says it is waterproof in the title-
Oct 30, 2009. 12:31 AMjumpup_dnb_dj says:
I think you are actually making reference to water resistant not waterproof as you state here.
Sep 27, 2009. 3:47 PMamaineman57 says:
Super Ible! The only comment I would make after viewing the video is the need of prop guards to keep the umbilical from fouling the props. Other than that, Good show!
Nov 16, 2008. 7:26 PMawang8 says:
where can you buy a cheap 12v camera?
Spark fun costs AUD50 which is way too much.
Dec 30, 2008. 8:42 AMPyrotechnic-Robot says:
Ebay! I got my first few cameras from ebay I know you dislike ebay but I found for a mini camera for about 30$ My first was 12$ but the prices really popped up The sub that I am making will have one of my old wireless camera
Dec 30, 2008. 2:26 PMawang8 says:
EBay eh? Sometimes they're fake cameras and I hate them. Like, they claim to be real cameras and you end up with a el cheapo dummy camera. ¡¡ŽPqÝ uo pyPoqŽÝž P Žnq o‡ ƒu1oƒ oP 1 Ýo1‡ ‡sPß Ýe‡ s1 s1e‡
Dec 30, 2008. 4:21 PMPyrotechnic-Robot says:
if you look for a mini spy camera you might find another camera. How did you type upside down? sweet.
Dec 31, 2008. 3:19 PMawang8 says:
How to type upside down.
1. Log on to www.ebay.com
2. Search "Keyboard" with the 2nd hand option.
3. Buy the cheapest one you can find.
4. There you go! You got successfully scammed and you should now be able to type upside down!
Just kidding
Aug 19, 2009. 8:35 AMclayball97 says:
serously though how do you type upside down
Aug 19, 2009. 10:39 AMPyrotechnic-Robot says:
‡1 Ý߃ooƒ
Dec 24, 2008. 1:04 AMdaniel2008 says:
well you cna get cheap 'spy' cams on ebay which run on anything round 9 V, you could have a 9V battery inside the housing connected to your camera and then run the video cables up to the surface
Dec 25, 2008. 8:55 PMawang8 says:
I'm not fond of ebay... It looks like i'm going for the Spark Fun. The webcam quality in my country is absolutely garbage.
Dec 30, 2008. 4:26 AMawang8 says:
Alright, I bought a $50 security camera with RCA output from DIck Smith Electronics. The downside is that I have to use an adapter. Stay tuned, my Intructable is coming!
1-40 of 183next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:SpaceShipOne
