3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Underwater/Stability Rig For GoPro Camera
In this instructable you can make a underwater and stability rig for the GoPro camera using some PVC pipes/connectors and the GoPro Tripod Mount.
I bought the GoPro, it is great how small the camera is, but that also makes it is hard to keep it stable. And because I go diving for 2 months in Indonesia next summer i needed a small lightweight rig. I only could find the normal heavy and expensive rigs, so i made one myself.
Also the rig can be extended by putting end caps on the handlebars, this would be nice for filming lights.
And don't worry about the tripod mount, you can still use it on a tripod ;)
Step 1Get Materials
For the rig you will need these things:
- GoPro Tripod Mount > $ 7,99 GoPro website
- About 50 cm  1" PVC pipe > about $ 2 (local hardware store)
- 2x 90º PVC elbows > about $ 2
- PVC Tee > about $ 1
- PVC End cap or PVC Male adapter (I used an old damaged adapter) > about $ 2
- PVC glue (or you should only use PVC pipes with fittings)
And to make it you will need this:
- Drill (with size 20/22 mm)
- Saw
- File
8 comments
May 11, 2012. 9:25 AMThe Ubiquitous Taco says:
Funnily enough, I had imagined an identical object for mounting a gopro for filming while scuba diving. I would imagine however, that water inside of the pipes would not drain easily when it is lifted out of the water, and that upon entry trapped air would give the rig a very awkward positive buoyancy. I imagine a rig with T-joints where you used L-joints, and perhaps holes drilled in the lateral pipe to further allow draining. Is there any actual cause for concern, from your perspective?
Dec 23, 2011. 2:35 AMcolincolin30 says:
Hi, would you buy a Gopro camera again.?
i am going on a trip and wonder if it would be good for video and stills at various tourist places.
regards
colinColin30
May 26, 2011. 8:56 AMchrisrunner55 says:
thanks for posting this build its is a great simple and cheap build. i was trying to find a a rig for my gopro when i go snorkeling and this is perfect. i actually sealed all the piping and it floats so i dont need to worry about it sinking and losing it. thanks again.
May 12, 2011. 6:29 PMsteveo625c6 says:
Great Build!
Have you looked into the "Chesty"? Its Go Pro's chest mount that I use and does pretty well. Its a tad awkward in the water to aim it but its one less item to fumble with.
This is my video of Myrtle Beach:
http://www.youtube.com/watch?v=KymOFrC00z8
May 16, 2011. 12:42 PMsteveo625c6 says:
Haha it was taken in 1080p but due to Youtubes condensing its not anywhere near as clear as what I have on my computer.
I actually looked into getting one of those LCD screens, if I get one I do very well see a point to your rig, I did hate how I always had to swim upright at times hoping I got the shot I wanted. If I get it I'll be back to copy the instructable ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:TomGeurts(Impian Anak)
