Remove these ads by
Signing UpStep 1: Tools and Parts Needed
1 - Metal Strainer/Steamer
1 - USB WIFI Adaptor
1 - USB Extension Cable (I chose a 10ft long)
½” Drill Bit (I like to use stepper bits for metal)
Gorilla Glue (Epoxy works well too)
2 - Zip Ties
Visit Our Store »
Go Pro Today »
I do not know much about a DSL system, since I have cable internet.
Does the DSL have a router or does your mother have a router with the DSL system. I you can not send the signal via air or wireless, would you consider a wired system?
A Ethernet cable is able to carry the internet signal for 100 meters or about 330 feet without loss. You would need a router at your mothers house. Use one ethernet cable for your mothers system. Then use another ethernet cable from the router at your mothers house and run it to your place. Put the cable a few inches below ground, if you have to gross a driveway etc.put the cable in an electrical conduit so it does not get damaged.
There maybe an other option for wireless connections. Use of two external yagi antennas, one at your mothers house and one at your place. Something like that http://www.amazon.com/Cable-Wireless-Antenna-Booster-Bluetooth/dp/B0054MLMLA/ref=sr_1_2?s=electronics&ie=UTF8&qid=1357416794&sr=1-2&keywords=yagi+wifi+antenna
Just google yagi antenna for wifi.
You would need to mount it on a pole outside both house, the higher the better, Do it at your mother's place as well your place. Aim the antenna from your mother's place toward your place and vise versa.
Remember those yagi antennas are very directional so aiming must be exact to get the best signal.
Hope this helps.
you need a directional antenna.
go here: http://martybugs.net/wireless/biquad/
good directions, I have made 6 of these biQuads. any metal will make a good back plate.
you need to get a reverse sma antemma extender cable, cut off the connector not needed & solder its end in the biquad. I use one on the distant computer to bump the signal up 3 bars. the garage is not much an issue.
My hawking tech usb antenna has a removal antenna. I just screw in the biquad & aim.
your router may have a larger connector, so buy the cable & solder it in.
teh biquad will boost singals thru the wall & thru a window is steller!
I have made ALL the various antennas. the single Bi-Quad is my Fav!
Mr Steve
This ones my personal favorite. Picking up signals from hundreds of feet away is cool. Picking up wifi from a couple miles out.
Legendary.
http://www.ab9il.net/wlan-projects/wifi3.html
_______
l router l=------cable------(---- antena
l______l.....................dish
REPLY
[flag][delete]
ty
In my experiments I found paper clips to be more convenient because I could remove them to close the strainer for travel.
Also, if need be, you can also use the zip-ties/paper clips to lock the shape of the dish into a different parabolic shape which may better focus the "hotspot" of the signal for a particular wifi adapter.
Remember, the strainer used as a parabolic focusing device can also be used to increase the signal of a bluetooth device or a cellular phone, so the adjustable aspect of the parabolic shape of the strainer makes for some good experiments.
I disagree with hard-mounting the USB cable of the wifi adapter to the center of the strainer. Instead the hole in the center strainer should be based on the width of the wifi adapter, or even better, based on a small piece of plastic tubing which the adapter can snuggly slide back and forth in.
How one would make the hole is up to the individual and the tools at hand, but making four cuts with a pair of tin snips and carefully bending the pie-shaped pieces with pliers to hold either the adapter or a two inch long plastic tube to mount the adapter into is not rocket science.
Not only does this allow for the adapter to be tuned for best signal strength, it also makes the unit very portable and easily dis-assembled, and preserves the wifi adapter and its USB cable in their original condition for other applications.
Cheers
Gman
I think it would be easier to buy adapter for example from wireless adapter reviews website. It's only cost 10-20$
My favorite is Alfa AWU
You can find various reviews of best usb adapters here
We regularly spend time at our cottage where we are internet-less. As the crow flies, we are probably only about 1 km from an unsecured wifi network, but it is 10 minutes over rough roads, and it would be kinda obvious if we just parked outside. We also have an antenna tower on that side of the house doing nothing, since we have satellite.
Since I have a USB wifi adapter that's been sitting in a drawer doing nothing, I am definitely going to give this a try. I would be willing to climb partway up the tower with my laptop to connect to the 'net occasionally to be able to download weather forecasts and download/upload e-mail when we're there for longer spells. If it works, I'll post back with firmer data! Wish me luck!
try making an Cantenna out of a 46 oz. juice can.
if the probe making & construction is troublesome & it is.
teh simpler way is to
just take the can & measure 1.24" from the cans rear. cut a slot your existing ubs donagal antenna fits tightly into. shove it up inside an 1" to 1.3".
you will need a short usb extender cable.
play with it to find the HOTSPOT. aim the can & you will be amazed at the improved signal!!! cost of a can of juice.
I have made several, gave to friends .
Mr steve
_______
It is a good place to start on a wi-fi extender project, with many more different examples shown at http://redirectingat.com/?id=487X782&url=http%3A%2F%2Fwww.usbwifi.orcon.net.nz%2F .
The problem I found with this particular setup is the hard mounting of the USB cable, which is not only unnecessary, but also may be placing the USB adapter out of the parabolic "hot-spot".
A quick and easy way to find the hot-spot is to cut a piece of paper to the curve of the dish, then take it outside and point it at the sun. The focused sunlight will show the parabolic hot-spot of that dish. (there is also a mathematical method to calculate the hot-spot at the orcon.net.nz site above)
I think it may have been more advantageous for this project to have hard mounted a piece of plastic tubing of the apporopriate diameter to allow the USB adapter and cable to snuggly slide in or out to adjust reception.
This technique also would allow for further experiments with the same cable and adapter using other types of dishes.
Some photos and directions for the making of my variation of the (portable) wi-fi steamer can be seen in the comments at http://www.instructables.com/id/usb-wifi-antenna/?&sort=NEWEST&limit=50&offset=100 (October 12 2006).
I found that the five foot cable attached to the base of the USB adapter, could not only be removed from the base, but it was made at a 90 degree angle to the cable which meant that drilling out the steamer was unnecessary. As luck would have it, I found that the tip of the USB adapter was perfectly matched to the hot-spot. (beginners luck) All I needed to do was zip-tie the USB adapter and cable to the steamer and it was good to go, and totally portable. I even fashioned a spring tension coat-hanger base which held it open and allowed it to sit-up straight. (if I hung the steamer with a hook from its top, the petals stayed open by gravity)
When hung from the raingutter outside of my window, depending on which direction it faced the setup worked well enough to receive 17 to 20 wi-fi networks in my neighborhood, several of which were not password protected. I suppose that if it were mounted to a pole extending above the roof which could be rotated, I would receive many many more networks.
I had similar results in Bangkok, and elsewhere on the road. Just remember that your reception is always based on line of site.
As I said, this project by tm36usa is a good starter, and from there you will find other useful dishes/strainers/steamers/reflectors etc to play with.
I found a clamp-on work light with an aluminum reflector which works awesome for extending the reception of my home wi-fi network from three bars (very good), to five bars (excellent). This is through several walls and a distance of about 60 feet from the network router.
The veggie steamer has moved-on to its next job, as base station for my cell phone. My cell phone reception inside my home has always been terrible, one to two bars at best.
I mounted a piece of a coat hanger with a loop at its end to the center post of the steamer, and hung the steamer on the wall facing my window. Then, I hung the phone by its antenna from the wire loop and presto, four out of four bars reception! If I get a call, as long as I am in front of the dish the phone works great.
The nice thing is that if I take a trip, I can re-rig the steamer for wi-fi duty in about five minutes.
So again, if you want to do this project, think about hard mounting a piece of plastic tubing to the steamer instead of the female USB cable end, and you will likely find you can use the same tube/cable/USB adapter combination with other types of parabolic dishes too.
Have fun experimenting.
Thanks again tm36usa for this instructable, and thanks again Manuka for the great ideas at the orcon.net.nz. site.
Cheers
GM
This is still the ultimate winner for both simplicity and gain: www.freeantennas.com/projects/template2/index.html
www.usbwifi.orconhosting.net.nz/
The vege strainer might make a good hollywood prop for agent 007, but
like most attempts at a dish antenna, this one also does not have the adapter positioned at the focal point
You can easily calculate the focal point of any parabolic as follows
Focal point =the square of the diameter divided by the depth of the dish.
just modified the plastic a little and used zip ties
UrbanWireless.info
Works great, except rain & fog effect it. Some times the signal drops out in these conditions though not always.
cheers kiwi john.
nice work.
Where would I buy the strainer/steamer, like the one the photo????
Win XP:
Start>Connect To>Network connections, then find the one that your laptop is currently using, right click and click disable disable
Win Vista: (also works on XP)
Start>RIGHT CLICK Computer>Manage
Computer manager should come up on the list on the left, choose device manager, then go to the list on the right, and click on the + sign on network adapters, RIGHT click on the WiFi adapter and click disable,
and thats it!
thanks
If you have aluminum blinds or blinds made out of metal, just put your wireless USB antenna behind it and make sure they are closed. Find out where the strongest signal comes from and use that Blind. I have this set up downstairs using a laptop as a Bridge going to a PS3. Works awesome with internet and gaming. Upstairs I have the setup you see here with 3 USB chords together going all the way to my Master Bath. Signal isnt as strong because of the lenght of wire but, it does what its supposed to do, get internet. Oh and I have another PS3 upstairs in that bedroom so, my Girl and I can play online against each other. Hopefully I save some of you a few dollars.
I am going to try to make similar one.
All the best
I can't get wireless signal way over at the other end of the house from my wireless router when I am now safely grounded. Will this antenna pick my wireless signal up thru the walls of the house? I get little to no signal at the opposite end of the house from my router now. I can't plug into any closer plugs to get a better signal due to open grounds on electric plugs and lack of privacy/space.
Wave guide antennas (cantennas) also work great. Jefa tech sells the N connector with the small length of copper wire already soldered to it. So you can save your self the hassle of soldering. All you need to do is find a cantenna calculator so you know where to drill the hole in the can. Then mount the N connector to the can. You then hook up a pig tail (the shorter the better) to the N connector and the antenna connector on your wifi device. If you goggle cantenna you can find tons of info.
can i use this as an wifi extender
eg:
urbanwireless.info/index.php/antennas/dish-with-biquad-feed
This page helped me find the sweet spot.
UrbanWireless.info
really efficient directional antennas can be made with a TV satellite dishes, but this can be more complicated
and its really works...receive 20 sites so far ,wifi is so much faster! put a small
servo motor on it and u can scan all over the place~
Alright, here goes. Before I give up my results (as I have already tried this), I want some feedback. Will this work with a USB modem (aircard)??? I work at RadioShack and a co worker made this for his Wifi. He said it increased connectivity from 50% to 72% and he picked up 6+ routers that his comp never saw before so I thought maybe I could increase my signal stregnth so I made it and have seen what it does. Has anyone else done this or does anyone have any theories? Thanks for any feedback.
Bill
http://www.downeastmicrowave.com/PDF/dishfp.PDF
Colander Antenna
Good luck!
-Sunkicked
Btw, sticking the dongle in the middle of a 12" airconditioning duct works well too. :)
http://www.maxi-pedia.com
Cheap USB Wi-Fi Adapters on Ebay
http://www.metacafe.com/watch/1036998/how_to_make_a_wifi_antenna_to_boost_your_wifi_signal/
follow this link for the pdf form:
http://akimages.metacafe.com/i/RemovalForm.pdf
http://cgi.ebay.com/802-11g-54Mbps-Wireless-Wi-Fi-USB-2-0-LAN-Adapter-NEW_W0QQitemZ290217139775QQihZ019QQcategoryZ45002QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I have a black one of these but the white would be better as if you had it in a windown it would not get as hot from the sunlight.
I have 3 different 802.11G Wifi USB's and found this one to be the best and to my surprise the lowest price also. Range is really good.
http://cgi.ebay.com/802-11g-USB-Dongle-Adapter-WLAN-Wireless-54Mbps-WiFi_W0QQitemZ140220089071QQihZ004QQcategoryZ45002QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If you are look at others find one with simlar specs as this one also allows you to use it as a rounter if needed.
Remember when hooking up don't usew more then a 8 ft USB extension cord prefer 6 ft. This way you get it away from the interferance of the computers Fans & Harddrive spinning which reduce signal strength.
http://www.usbwifi.orconhosting.net.nz/
(see pic #'s 75 and 85). I like the detachable antenna for further antenna design flexibility. I'm looking at a parabolic antenna. Maybe an old Dish or an asian cooking strainer for reduced wind resistance. The site above has a bunch of great ideas.
Your are right, your USB Wi Fi at $15 including S&H is tempting. I think I'll pick it up. I mean what the heck, you could throw $15 into the street or a 12 pack.
Best,
Steve
Hawking has many Wi-Fi range extending products including Hi-Gain indoor and outdoor antennas, boosters, repeaters and adapters.
- I have built-in WiFi, but installed the USB dongle software but can't test it yet, b/c...
- my system won't recognize the adapter when used with the extension cord. It is fine plugged directly to the USB port, and with the extension gets power (the light comes on). I have tested the cord w 3 different USB devices - same issue.
- I'm using a 16 ft. cord - could that be part of the problem?
Thanks in advance. And *if* there was no need to override my internal WiFi in order for it to work (tho' I can't see how), please let me know.
Ciao!
</sarcasm>
http://en.wikipedia.org/wiki/Wifi
the speed of light / (2.4 gigahertz) = 4.91785528 inches
I hope this information has helped you try and figure out your best plan of attack. The best be would be to get another USB adapter. Just out of curiosity, how much did you pay for the first one? You should be able get them online for around $10 like I did. Let me know if you need anymore help.
The model usb wifi adaptor i have is a Hawking Technologies HWU54G Revision Z2. They are going for about $20 on ebay now and I haven't seen the deal at Micro Center for $10 in quite some time. Here is the hawking tech page to show you what the adpator should look like : http://www.hawkingtech.com/support/details.php?CatID=19&FamID=33&ProdID=175 . I have not tried any of the other revisions but I would just try and stick with the one that works. Hope that helps steer you toward what you want. As always, come back with any questions.
Try looking at the photos at the Wok-Fi site:
http://www.usbwifi.orcon.net.nz/
You will notice the shapes are all curved, which allows the signal coming in to be "Focused" at what is called the "Focal Point".
The photos will show how to make a suitable "dish shaped object" into a working antenna, and how to find the focal point.
Since your wastebasket has a flat bottom, it would not reflect the signal to a focal point.
You may be able to cut the mesh into an appropriate shape, but when you look at the photos, you will have some good ideas to work with.
But the only way to test one, is to build one.
You may want to start by purchasing the USB adapter.
Cheers
GM
Thanks for this thread.
I made a version that does not require drilling that worked very well.
My coathanger base provided the spring tension to hold it open.
Without the base or extension cable, it closes up enough so you could put it in your pants pocket.
Mine is the one at the bottom.
http://www.instructables.com/id/E8NV19KY8DEQZJI5IF/?ALLSTEPS
Many thanks to all who have posted on this subject.
Cheers to Stan in NZ.
GM
here's an example of what i'm thinking about:
http://www.angelfire.com/80s/shobhapardeshi/twelvesided.html
you can fold it and put it in your backpack. when you need to cook, you put the foil inside, when you want an antenna, you put the foil outside (to prevent risks of fires).
http://wildwoodsurvival.com/survival/fire/reflector/index.html
Paper print out antennas
with hard math
http://www.freeantennas.com/projects/template2/index.html
check out http://www.usbwifi.orcon.net.nz/ for a similar set up (doesn't use a USB 802.11 dongle, tho)
A couple things to keep in mind:
802.11b/g signals are 2.4Ghz so the diameter and curve of the dish matters a lot. Check out http://www.qsl.net/n1bwt/contents.htm for a bunch more detaiiled info. You might be able to tweak a few more dB outta your design!
He provides theory as how it works, as well as, statistics.
