Unicorn Rainbow Cookies Recipe
2,359
38
12
Published
Introduction: Unicorn Rainbow Cookies Recipe
About: I am powered by sugar and rainbows! For realz!
As a big fan of all things rainbow, I've been happy with the new (and still hopefully going strong) Unicorn fad. From Frapps to chocolate bark, I'm for all things rainbow and unicorn. I recently made some Unicorn Edible Cookie Dough to go along with the fad, but I knew I would also need to make cookies too!
After a disappointing miss on making these sugar-filled rainbow monstrosities, I came out the second time with a very tasty and adorable cookie! Enjoy these Unicorn Rainbow Cookies and even if you'd never even consider eating them, I hope you'll enjoy looking at them.
[This recipe is also great if, like myself, you still have most of your 2.5lbs of cereal marshmallows to use.]
If you are more interested in sugar cookies but still want to eat a rainbow, you should check out Unicorn Poop Cookies by kristylynn84 :)
Instructable 274
Step 1: Ingredients
The recipe I am using is from Show me the Yummy with some minor tweets. I made her recipe a few weeks ago and they turned out great so I knew I could trust it.
Ingredients:
  • 1c Butter (2 sticks) - I used cold butter like her, but I don't know if that is going to matter because of how much you work with it.
  • 3/4c Brown Sugar
  • 1/2c Sugar
  • 1 Tbsp Vanilla Extract
  • 3c Flour
  • 1 1/2 tsp salt
  • 1/4 tsp baking soda
  • 1 tsp baking powder
  • 2 Large Eggs - again I also used cold eggs but don't know how much it will affect our dough here
  • 2 Tbsp cornstarch
  • Food coloring - I am using red, orange, yellow, green, blue, and purple but you can use whatever you want
  • 1/2c White Chocolate Chips - I chopped these a bit after measuring them, but you don't have to do this.
  • 1 1/2c Cereal Marshmallows - yet another use for the 2.5lbs I bought - feel free to use more just don't go overboard or it could interfere with the cooking. I just did heaping 1/2 cups full when measuring them out.
  • 1c Mini Chocolate Chips - you can use regular chocolate chips, I just like mini better and I didn't want them to distract from the color or marshmallows so I thought mini helped there
Utensils:
  • Stand Mixer - if you have one to use it will be helpful especially when dealing with the cold butter and thick dough at the end, otherwise be prepared with a big bowl and spatula
  • 2 Baking Sheets - you'll need two if you bake them all at once and if you do them separate so you can avoid putting cold cookie dough on a hot pan
  • A separate baking sheet or large plate to put the dough in the fridge - I didn't want to use the same pan to bake that I put the dough on to chill because then I would be putting a cold pan in a very hot oven, didn't seem like a good idea.
  • 6 Bowls and 6 Spoons - this is for mixing the dyed dough so you'll need however many colors you are doing
  • Assorted Measuring Cups and Spoons
  • Bowls for mixing ingredients
  • Spatula for scraping down the sides of the mixer bowl
  • Parchment Paper - I used to use baking matsall the time but in an effort to try to get chewier cookies I've switched to parchment paper, use what works for you.
  • Cooling Racks
Step 2: Mix Your Dough
This is a pretty standard cookie procedure.
  1. Start by mixing up your butter until it is creamy.
  2. Then, add in your sugars and mix until incorporated.
  3. Add in your eggs and vanilla - you can mix these together first, but if you don't have a bowl or don't want to dirty another, I usually add the eggs and vanilla in and just kind of mix those together in the mixing bowl with my spatula, and then turn the mixer on and mix everything together.
  4. Mix your dry ingredients together (flour, salt, baking soda, baking powder, cornstarch, they should be premixed together to get even distribution).
  5. Slowly add the dry ingredients to the wet ingredients in the mixer.
  6. Stop when everything is mixed. We ARE NOT adding in the chocolate chips or marshmallows yet.
We are waiting for the mix-ins because it just seems like a pain to mix the color into the dough that already has everything in it.
Step 3: Color Dough and Mix in Tasty Bits
If you are dying your dough, separate evenly into bowls.
Carefully color the dough. I only used 2 drops and you can see I got a bright color, so don't overdo it. You can always add more.
Also, this gets super tiring to stir so good luck.
Once the color is mixed, you can evenly distribute your white chocolate, cereal marshmallows, and mini chocolate chips between all the bowls.
Then, mix those up.
Step 4: Make Cookie Balls!
I decided to stick with making 12 cookies like Show me the Yummy did to make things easier on myself. You can do more if you want, you'll just need to adjust your cooking time.
So, now you need to (to the best of your abilities) evenly distribute your colors between your 12 cookie balls (or however many cookies you are doing)
[Sorry I didn't get more pictures of this. It was messy and I didn't want to keep washing my hands to take pictures (and I forgot, I'm human). The last picture above is from the first time I tried to make these and failed but the process was still the same (more about that in Step 6).]
The way I did it was, I started with an extra cookie sheet (well, a pizza pan) and put some parchment paper on it. Then I took the red dough and I divided it out until I had 12 piles. Next, I moved onto each color one at a time and distributed it between my 12 piles.
You can try to have more distribution of the colors, but it will be more time-consuming. In order to do this, only use half of each color at first when creating your 12 piles. Then once you've added all your colors, go back through all the colors using up the rest. (Kind of like with my Rainbow Chocolate Bark how I used some of each color and kept going back through the colors.) So you will basically have two little mounds of each color on each cookie. This is already a time-consuming process so it's your call.
The piles may all look the same (with red and orange on the bottom, and blue and purple on top) but we can change that in the next step.
Once you have 12 complete piles and have used up all your cookie dough, stick these in the fridge. It is okay that they are messy, we will fix that when they firm up.
Step 5: Form Balls and Bake
Once they have sat in the fridge for at least half an hour (mine sat for a while because I only worked on them when my baby was napping), we are going to bake. Start by preheating your oven to 375 degrees Fahrenheit. While that is getting ready we are going to prep the cookie balls
To try to help prevent the spreading of the cookie, take each mound and squish it into a tight ball. Once they are all formed, put them back in the fridge on the same cold pan until it is time to bake.
Prep your pans by covering them with parchment paper. If you are doing one pan of cookies at a time, I recommend having two pans so that you won't be putting cold cookie dough on a hot pan for the second batch (I've read this can cause more spreading of the cookies while they bake because it melts the dough quicker). Or you can bake both trays at once if you feel comfortable with that (I really wanted them to turn out so I did 1 pan at a time).
Once your oven is ready. Take out 6 of your cookie balls and put them on your pan with parchment paper. Space them out, they are big cookies. Also, if you want different colors on top of the cookie, turn the cookie balls accordingly. As you can see, I tried to have different colors on top of the cookie.
Now, bake! I went with the recommended 18-22 minutes and found 20 worked for me. You want to make sure they are getting baked all the way through. Remember, they are pretty big.
The last image shows them after they came out.
I left them on the pan until I could safely pick them up with a spatula, then I moved them to a cooling rack.
Enjoy your cookies!
Step 6: Failed Cookies!
The first time I made these I used a regular old chocolate chip cookie recipe, used baking soda and baking powder that was expired, and this recipe (different than the one I used above) required room temperature butter and eggs and I used cold. So really, everything went wrong.
Sad cookies :(
Colors of the Rainbow Contest
This is an entry in the
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    1 Questions
    hey penny ... thanks for this adorable cookies .. but I need to ask you is the baking soda necessary for this or we can get the same cookies without it ... and what if I want at least 22 cookies should I add extra butter and all of the ingredients
    Because there is so little baking soda and the cookies also have baking powder and cornstarch I want to say you can just exclude it. But I'm not as familiar as I would like to be with ingredients to say that 100% though. There are recipes out there (such as this one from Cook's Country - you need to log in to see the whole thing) that only uses baking soda and if those cookies can get away with it, why not you :) Just remember you still need to use cold ingredients, chill the dough, and really form those dough balls to prevent spreading of the cookie.
    If you want to make more cookies you could either make the cookies smaller and bake them for a shorter amount of time or increase all of the ingredients equally. Depends if you want 22 very large cookies or 22 smaller cookies :)
    12 Comments
    Thanks for the recipe! I'm going to try making a half batch (I'm going to have to pick the marshmallows out of the cereal), and will let you know how they turn out. I appreciate your inclusion of the fail and why it went wrong, that helps me to know what not to do - I would have used cold eggs otherwise!
    Well for this recipe you do use cool eggs. My original recipe was completely different and was supposed to have room temp eggs :P I'll try to make that clearer, but I hope you like them regardless!
    Oh, okay, I missed that, sorry! :D
    No worries! It's confusing because I used two complelty different cookie recipes. My original intent was to work off the failed recipe, but then I learned about adding cornstarch to cookies and I just loved her recipe that I decided to work with something that already works. I'm not great at creating my own recipes from scratch, but I love to mess around with other peoples and concentrate more on how it looks rather than the ingredients that make it up :)
    If you want Unicorn Poop Cookies you can find those right here ;)
    I've never made them but they sure sound and look tasty to me!
    I know about those cookies! I love them, they are great, but my intent wasn't to be anything like them :) They use a sugar cookie dough, the construction of the cookies are different, and the toppings are all different. I used a chocolate chip cookie dough, died portions and just made traditional looking cookies rather than making swirl (poop) cookies and then I added in chips and marshmallows while she brushed hers with glitter and sprinkles :)
    Despite the fail :) that's one incredible process!! ---I'd like to try a batch with a little white (regular) dough in the mix to let the color accent
    Thanks! and I think a little regular dough in there would look great with the colors :)
