Introduction: Unicorn Horn
uncorn horn on glitter headband
Step 1: Materials
cardboard
glitter ribbon
headband
hot glue
silver spraypaint
gold spraypaint (optional)
Step 2: Measure
measure the cardboard you rolled to 16 inches
Step 3: Spray Paint
spray paint horn silver
Step 4: Cut Out Circle
cut out a circle and twist it into a point
Step 5: Insert Point
put twisted point (that you taped to stay together) in the opening at the top of the horn
Step 6: Tape Creases
Tape the over the creases of the horn
Step 7: Sand
Sand the tape so that the edges are smooth. Then respray the horn silver.
To add texture, spray paint a little gold onto the horn along with the silver.
Step 8: Cut Ribbon
Cut a fairly long piece of sparkly ribbon in half
Step 9: Glue Ribbon
hot glue the newly cut ribbon onto the horn along the creases.
Step 10: Wrap Headband
Wrap a piece of non-cut ribbon around a large headband
To make the ribbon stay while you are wrapping, try to wrap the ribbon as tightly as possible and avoid hot gluing
Then tape the ends of the headband to make the ribbon stay
Step 11: Connect Headband to Horn
connect the horn to the headband by hot gluing
