To learn how to ride first one must acquire a unicycle. You can buy them online at
http://www.unicycle.com. I would suggest this unicycle to a first timing unicyclist
Sun 20". If you are willing to invest a bit more,
The Nimbus ISIS is a very good unicycle, and will not break on you! It is better because It has an ISIS spline drive. This means the cranks are less likely to become loose or break the hub. I strongly recommend it if you A. Plan on jumping down stuff or B. weigh over 150 pounds. If you want a higher quality unicycle, but you cannot spend two hundred, go with a
torker. Not ISIS, but the 48 spokes makes it strong as well. You can also get a unicycle through a local bike shop. I recommend checking the size and if it is right for you. When the pedals are vertical your leg should be slightly bent. Ask the Salesman to adjust the seat to your level, or if you buy it have them cut the seat post, this should be free. I also STRONGLY recommend a helmet when learning and riding. The best kind is the skate type, which although not as much venting as a bike helmet, its safer. While your there, check out the leg protection. This will save your legs from painful "pedal bites" (when a pedal slams into your shin or calf). you have some choices, but 661 or Kris Holms are the best. in my opinion.
661 Kris holm
